yegbey01
AC At BDL...whay Their Own Counters
Fri Sep 22, 2006 8:19 am
I just flew BDL-YYZ on AC Jazz and was surprised to see AC having its own check-in counters
Why not use UAL's counters...By the way, another strange thing is that UAL does not code share those flights!
Any idea why that is the case?
northstardc4m
RE: AC At BDL...whay Their Own Counters
Fri Sep 22, 2006 8:20 am
Well probably because they have been at BDL since before the STAR Alliance. Air Ontario was serving BDL in late 80s i believe.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
BDL2DCA
Fri Sep 22, 2006 8:42 am
AC is one of the three airlines left in Terminal B, along with AA and YX.
Originally, they were in Terminal B because that is where the old International Arrivals Hall was. That way, if the flights did not preclear for some reason, they could clear customs & immigration in Terminal B.
Since that time, the new IAB opened and BDL is trying to move everyone over to Terminal A. I'd imagine once the renovation finishes, they will move over to Terminal A and they might share gates with either UA or US. If they ever fail to preclear, however, they will have to drop the passengers off way over the other side of the airport at the IAB and then tow/taxi the plane back over to Terminal A for departure.
146,319,320,321,333,343,722,732,733,734,735,73G,738,744,752,762,763,772,ARJ,BE1,CRJ,D9S,D10,DH8,ERJ,E70,F100,S80
HVNandrew
Sat Sep 23, 2006 7:49 am
Do you know what is supposed to happen to Terminal B in the future?
MikeTheActuary
Sat Sep 23, 2006 8:04 am
Quoting HVNandrew (Reply 3):
Plans are for Terminal B to be demolished, and Terminal A to be expanded with a third concourse in the area of B14-B23. The new parking garage at Terminal A is also supposed to be doubled in size, by building it out westward.
If you're passing through BDL, a model of an early version of the plan can be seen where you exit the UA/US concourse / the east end of the hallway connecting Terminal A and Terminal B.
