JakTrax
This Iberia Plane Is Not As It Seems...
Sat Sep 23, 2006 1:19 am
Sitting at LHR yesterday I photographed the following Iberia aircraft.
Big version: Width: 3456 Height: 2304 File size: 1937kb
Nothing unusual, until I zoomed in and noticed it says 'MD-87' on the engine. This aircraft is clearly an MD-88 (inherited from Aviaco I believe, who didn't have any earlier MD-80 variants), so I'm wondering what the hell's going on here. I very much doubt that this is an MD-87 engine as the thrust would need to be greater for use on a stretched aircraft. Could it simply be the cowling from an MD-87?
Any answers, anyone?
Karl
Newark777
RE: This Iberia Plane Is Not As It Seems...
Sat Sep 23, 2006 1:24 am
That is indeed an MD-88, but it may just be a replacement engine cover from a different plane.
Harry
United787
Sat Sep 23, 2006 1:52 am
If you look at the cowling, it is much cleaner than parts around it, I would concur.
Stil
Sat Sep 23, 2006 2:04 am
Iberia's M87 and M88 uses EXACTLY the same engine
Both are P&W JT8D-217C
Stil
[Edited 2006-09-22 19:05:45]
....... Gueropppa! ......
JakTrax
Sat Sep 23, 2006 3:06 am
Same engine physically but surely uprated due to the extra weight?
And yes, that part of the cowl does look a lot newer.
Karl
Stil
Sat Sep 23, 2006 3:29 am
Only fuel control is different, M88's engines are slightly overpowered, but you can change one into other with a screwdriver. Anyway, is only to let you know. I'm sure iberia didn't have another spare engine cowling (or maybe the mech wrote a wrong part number  Wink )
Stil
