chrisnh
Do Airliners 'tanker' Fuel?
Sat Sep 23, 2006 5:07 am
Over on my Manchester Airport Yahoo Group we are discussing a couple of the morning United departures to Chicago...one a 733 and the other a 757. Apparently the cost of fuel is quite a bit less expensive at MHT than at ORD, and an observer noted that much more fuel was loaded aboard at MHT than a flight like that would otherwise need (wx was apparently good the whole way). They apparently needed 16,000 pounds and asked for almost 29,000. Price of the fuel was $2.58 @ ORD versus $1.91 at MHT. Is this a common practice, and is there a risk of the plane landing 'too heavy' at ORD with all that tankered fuel?
Chris in NH
OPNLguy
RE: Do Airliners 'tanker' Fuel?
Sat Sep 23, 2006 5:15 am
Tankering for fuel cost differential has been around for ages, and has increasingly become more important as the price of fuel has increased in recent years.
Our flight planning computer takes projected load info, as well as payload weights, and fuel prices, and suggests tankering when cost effective, and also how much to tanker (based on the aircraft's subsequent planned flights, and their payloads, etc.). Obviously, if we have a full aircraft, there's only so much one can tanker, and on short, landing weight-limited flights, there might not be room for any tanker fuel, but we do so when we can, since every little bit helps.
Last fall, in the aftermath of Katrina/Rita when the supplies in the central US were squeezed due to pipelines being out, the prices at midwest points such as MDW and STL were such that it still made economic sense to tanker in fuel in from SEA. I counted up the savings on one shift, and they ran about $7,000.
SlimChance
Sat Sep 23, 2006 5:18 am
Sounds perfectly reasonable to me. When I drive to Corpus Christi from San Antonio, I try to have just enough to get me there, because I know I can fill up in Corpus for $.30 less per gallon. Another thing is; these airlines know what they're doing. They're not going to overload a plane. Besides, if they were going to be burning 15-19k lbs in the air, I don't think they could be above landing weight when they got there. I guess the only risk would be if they had an issue in the early part of the flight and had to divert somewhere close.
GQfluffy
Sat Sep 23, 2006 5:23 am
GQ did this all the time to our EAS cities. They'd leave BIL during the evening back with topped off tanks, and when they'd come back the next morning after the RON, they'd only have a few hundred pounds left on board.
This isn't where I parked my car...
OPNLguy
Sat Sep 23, 2006 5:35 am
Quoting SlimChance (Reply 2):
I didn't specificly mention this, but that's another variable the the flight planning computer looks at, i.e. not exceeding the max landing weight.
About the only disadvantage to tankering fuel that readily comes to mind is that, sometimes, the aircraft that has the 10,000-15,000 lbs. of tanker fuel loaded on it has to cancel for mechanical reasons. The replacement aircraft that gets assigned will also be loaded to that same fuel load (reflecting the tanker fuel), but then you have that original aircraft sitting there with all that fuel. Once it gets repaired and is back in-service, it may then be too heavy to operate the flight the equipment folks want it on. If they don't have the option of assigning it to a really long flight (that would take, at least, the amount of fuel already onboard), it'll then be necessary to de-fuel the aircraft down to the amount needed to operate the new flight without being overweight.
[Edited 2006-09-22 22:36:34]
sv2008
Sat Sep 23, 2006 5:59 am
Landing weight aside, doesn't all that extra fuel increase fuel consumption due to the extra weight?
That would maybe make the cost difference not so great.
[Edited 2006-09-22 23:01:02]
OPNLguy
Sat Sep 23, 2006 6:05 am
Quoting Sv2008 (Reply 5):
True, and they're just two more variables that the computer looks at in order to make the tanker/do not tanker suggestion.
There some other variables that the computer doesn't consider, but the dispatcher does, like runway conditions, certain MEL items inop, etc.
FI642
Sat Sep 23, 2006 10:29 pm
I've seen a DC-10 tanker 150,000lb of fuel. Cost is one reason.
Another is when an aircraft goes into a U.S. Military base, there
is no concurrent fueling. If the aircraft is fueled, it cuts down on
ground time and saves money by fueling at a less expensive airport.
737MAX, Cool Planes for the Worlds Coolest Airline.
FlyDeltaJets
Sat Sep 23, 2006 10:33 pm
SY always topps off at JFK b/c this is according to the pilot the fuel is cheaper here than at MSP.
The only valid opinions are those based in facts
Sat Sep 23, 2006 10:48 pm
Quoting ChrisNH (Thread starter):
Tankering does happen for a number of reasons, it could be as your suggesting for cheaper fuel, can be due Wx, or can be due political reasons, e.g. if a country just happened to go into a military coup one would not be surprised to see a directive that you have to carry either return fuel or an out of country alternate.
Can also tanker fuel if for some reason the quality of the fuel is brought into question, this may be as simple as a formality in the paperwork.
The FCOM will have a graph in it giving you the fuel tankering savings that can be achieved.
Carriage of extra fuel costs fuel, it is common for flight plans to reflect the fuel cost for each extra tonne of mass.
At no time would one land over max landing weight due to fuel takering under normal operations.
flightopsguy
Sat Sep 23, 2006 10:57 pm
Variables such as cost of additional fuel burned, wear and tear on airframe/engines and of course weight restrictions are all taken into account when tankering. Tankering can save $$$ every day. Most airlines will have a fuel manager who figures all this out.
A300-330 BAC111/146/J31/41 B99/1900 CV580 B707-777 DC8/9/10 L188/1011 FH227/28/100 SB340 DO228 EMB2/170 CR2-900 SH330-60
Tristarsteve
Sat Sep 23, 2006 11:54 pm
One problem of tankering fuel is that the aircraft lands with the wing tanks full of cold fuel. With an air temp below 10degC and moisture in the air this will lead to ice forming on the wings, which will need deicing, which would not have happened if the fuel had not been tankered. Another cost aspect to the equation.
Our fuel planning system used to suggest fuel tankering into ARN for a very marginal saving. It was about a total of 50 UKL. If this needed deicing this cost us around 600 UKL.
We dont tanker here much nowadays.
N766UA
Sun Sep 24, 2006 12:00 am
You're getting jet-A for $1.91?!  Confused
It's running $5.34 a gallon at CLE.
This Website Censors Me
ShowerOfSparks
Sun Sep 24, 2006 12:04 am
Quoting TristarSteve (Reply 11):
If you arrive with the wings full of cold fuel and need to add more fuel first transfer the cold fuel from the wings to the center tank so you will be adding (warmer) fuel into the wings. This will often be sufficient to remove any frost which has formed on the wings.
SNATH
Sun Sep 24, 2006 12:05 am
Wasn't it the case that the Soviet planes (TUs / ILs) had pretty large fuel tanks to avoid fuelling outside USSR, whenever possible?
Tony
Nikon: we don't want more pixels, we want better pixels.
Goldenshield
Sun Sep 24, 2006 12:20 am
Quoting N766UA (Reply 12):
Airlines have contracts with fueling companies and buy in bulk.
Quoting ShowerOfSparks (Reply 13):
This is why some aircraft have optional heater blankets for the wings. Granted, it's not 100% effective, but it does the job.
pmurr
Sun Sep 24, 2006 4:28 am
Air Pacific tanker fuel from Australian ports all the time. Am unsure whether they do same from NZ.
twal1011727
Sun Sep 24, 2006 5:30 am
The $5.34/gallon price is at the local FBO... yes?
DL pays $2.02/gallon in MLB and $1.91 in ATL
Airlines(as already stated) buy their fuel in bulk and usually at hedged prices.
No airline could survive at $5.34/gallon very long...not even WN.
Quoting Goldenshield (Reply 15):
Heater blankets are only for tail mounted engine A/C (MD80s.)
The MD80s had a notorious ice shedding problem so they had heater blankets installed. These blankets were only installed on the wing root (close to the fuselage) not on the rest of the wings.
The other solution was to burn fuel from the wings first...then the center. That way when the A/C was refueled, the "warm" fuel added mixed with the cold fuel and hopefuly melted any wing root ice.
There have been several MD80s that have lost engines(A/C too!) because of ice shedding.
KD
nonfirm
Sun Sep 24, 2006 6:26 am
We are starting to tanker fuel fuel now on flts from sea.The company told us it was cheaper for them to tanker the fuel then refuel at some stations.We also can stop the tanker if during the cold weather season we have to de ice the 737 to much. airplane
Tristarsteve
Sun Sep 24, 2006 5:38 pm
Quoting TWAL1011727 (Reply 17):
This is not allowed in most airliners. You must use the wing fuel last. This is for structural purposes.
Dont usually have time for this on a 40 min turnround!. Ittakes time to set up. Steps up to the refuel panel, then into the flight deck and put on the pumps and X-feed valves, then the bowser arrives. Not very practical.
Quoting Nonfirm (Reply 18):
I found that a B734 arriving with 4000kg on board does not grow ice on the upper wing. Come in with 5000kg and it does. This only works om a B737 due to the design of the collector tanks. MD80 are the worst, they always produce ice.
