gilesdavies
Could The A330 Be Extended Further In Length?
Sun Sep 24, 2006 8:13 pm
Bit of a hyperthetical question, now the A350 is on the drawing board...
With the A330-200/300 sharing the same size fusalages as the A340-200/300,and a lot of other commonality.
Would of it been possible to extend the A330 to the similar lengths of the A340-500/600?
ZBA320
RE: Could The A330 Be Extended Further In Length?
Sun Sep 24, 2006 10:08 pm
Would think it would be pointless seen as the A350 is now in full swing design. If it was to be lengthened then it would probably reduce the range quite a bit if was up to A346 size!!  Wink
An Engineer made a bet that a 747 Gear wouldn't retract in a Hangar. He lost the bet.
Oykie
Sun Sep 24, 2006 10:12 pm
Not even would it be possible, but Airbus has at one point tried to get customer interest in a stretched A330-400.
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
zvezda
Sun Sep 24, 2006 10:44 pm
It would have had the same issues with OEW and rigidity that the A340-600 has. To reasonably get to such lengths, one needs to either increase the vertical component of the fuselage cross section (as the A350 and B787 have done) or switch to an inherently lighter and more rigid material (as the B787 has done).
PHKLM
Sun Sep 24, 2006 11:37 pm
Big version: Width: 1513 Height: 797 File size: 51kb
Ok so I did a quick Photoshop job on the A330-400  Smile
It looks not unlike the 773; but the engines will be most likely to small to power this long bird.
A342
Sun Sep 24, 2006 11:46 pm
It would be possible, but the range would suffer. It would be in the A300 ballpark, so the best the A336 (?) could do then would be short/medium haul.
Exceptions confirm the rule.
Stitch
Sun Sep 24, 2006 11:50 pm
Quoting A342 (Reply 5):
I'm guessing engine thrust would be an issue, so MTOW would be "low" and that would preclude carrying sufficient fuel for longer missions?
Oykie
Sun Sep 24, 2006 11:59 pm
Quoting Stitch (Reply 6):
IIRC the A330-400 would have the same wings, as the A330-200/300 and therefore lack the same fuel load as the A340-500/600.
PADSpot
Mon Sep 25, 2006 12:05 am
Maybe it's more viable to take a look at this question from the opposite side: How would an A340-500/600 with just two GE90-115Bs perform?
PHKLM
Mon Sep 25, 2006 12:08 am
Quoting PADSpot (Reply 8):
This has been discussed here, the gear would need serious adjustments, as well as the wings and this new plane would enter the world of ETOPS issues; it makes much more sense stretching the 330; which will basically be done with the A350XWB.
PADSpot
Mon Sep 25, 2006 12:35 am
Quoting PHKLM (Reply 9):
Why? Weight wouldn't change much. Maybe the GE90 would need greater ground clearance and thus a longer undercarriage?
Point granted. It would need two new very strong mounting points but could do without the four existing mounts. At worst it would be weight-neutral. But the A345/6 wing has far more potential concerning fuel and aerodynamics ...
A new A330 variant would also need (ETOPS-) re-certification ... issues of crew training/certification and operational planning would be the same for a lengthened A330 or a two-engines A345/6. Production standards at Airbus are just as high for 4-holers as for two-engined aircraft.
[Edited 2006-09-24 17:36:46]
