1337Delta764
AA And Their A300 Replacement - 787-3 Possible?
Wed Sep 27, 2006 12:14 am
Many have told me that Delta will not order the 787-3 as a replacement for their non-ER 767-300s, but convert some 767-300ERs to domestic as 787-8s and 787-9s enter international service.
What about AA's A300 replacement? None of the routes served by AA's A300s require the range of the 787-8, and on the routes served by the A300, cargo is in high demand. The 767-300 has less cargo space than the A300. The 787-3 may be the perfect replacement for the A300 fleet. What are your thoughts on this?
dank
RE: AA And Their A300 Replacement - 787-3 Possible?
Wed Sep 27, 2006 1:12 am
Quoting 1337Delta764 (Thread starter):
But range = higher cargo. One of the big limitations of the 787-3 is that it cannot lift max payload at max range (it does one or the other). Which means that on the longer legs, the 787-3 will not be able to carry the lucrative cargo. I could easily see someone like AA saying that they will slightly abuse some 787-8s on some of these routes and use 763s that have been reassigned for the lower cargo and passenger demand routes. This also allows AA to reassign 787-8s (with appropriate pax configuration changes) when they need/want to.
cheers.
PRAirbus
Wed Sep 27, 2006 4:34 am
AA just extended the AB6 leases for another 2 years meaning they'll be around for a while longer at least past 2010.
777ER
Crew
Wed Sep 27, 2006 4:37 am
Quoting PRAirbus (Reply 2):
Which means they will be in service intill around the time the B787 is in airline service. AA might extend the leases for another two years till 2012, thats when the B787 line is booked out till. Unless AA can source some early production slots
Head Forum Moderator
moderators@airliners.net for all Moderator contact
jfk777
Wed Sep 27, 2006 5:05 am
AA should misuse 787-9 like the Asians misuse their 744 and 777's. Singapore call it, "intelligent misuse" of say a A345 from Singapore to Jakarta. ANA does it with 747-400D in domestic use when they are new for 4 years ands then they put a 3 class interior and you it for long haul routes.
MCIGuy
Wed Sep 27, 2006 5:09 am
The 783 is intended to be a niche aircraft for the Asian market. I still say none will be sold here, at least for a long time to come.
Airliners.net Moderator Team
fxramper
Wed Sep 27, 2006 5:11 am
The AB6 will be around for AA. The 787 they order will replace 762 that fly transcon.
Regards.
akizidy214
Wed Sep 27, 2006 5:47 am
AA is real big on simplification right now. Most likely they will only order the 787-9 and put a majority of them on the east coast MIA, JFK and SJU. That will give them the flexibility to move the 777's to DFW, ORD and LAX.
DCA
Shenzhen
Wed Sep 27, 2006 5:52 am
If AA intend on using the airplanes until they are retired, then they might purchase the -3. If they want to re-sale, they better pick the -8
akizidy214
Wed Sep 27, 2006 6:21 am
Quoting Shenzhen (Reply 8):
AA isn't in the business to re-sale. The 787-8 could in no way way replace the A300. In a AA configuration the 787-8 would be a huge decrease in available seats. Don't forget the A300's hold 267 passengers and most of the time those flights are filled to the rim and often over sold.
DCA
brendows
Wed Sep 27, 2006 6:39 am
Quoting Akizidy214 (Reply 9):
How can a 788 represent a decrease in capacity when it's larger than the A306? In a two class config, the 788 can seat about 280-295 pax.
The number Boeing use for seating (210-250) is for long haul, something the flights to and from the Caribbean aren't.
dank
Then AA better not buy a 787-3 since it shares identical cabin dimensions to the -8... A -3/8 would most likely seat a little more than the a300 with a similar mix of seats and one of the two is the likely replacement for some of their a300s. I think a mix of -8s and -9s are most likely for AA.
cheers.
[Edited 2006-09-26 23:40:27]
