Minimum Connecting Time In CPH
Tue Oct 10, 2006 4:55 am
Dear al. I will arrive at 7:50 at CPH with Air Berlin from DUS and fly back with Air Berlin again at 8:40.
I have been assured by Air Berlin in Written form to get my boarding pass for the flight back already in the morning in DUS.
Therefore no need to check-in again. Will 50 Minutes be enough to connect in CPH? I have never been there, that's why I need the opinion of experienced travelers.
Do I need to leave the airside area or is there any transfer/connecting flight facitlity?
Thanks for your help
Frederic
Tristarsteve
RE: Minimum Connecting Time In CPH
Tue Oct 10, 2006 5:02 am
If you are going back on the same flight there is no need to leave the gate area. CPH does not have segregated arrivals and departures.
padster
If understand you correctly, you arrive on a DUS-CPH, then leave 50min later on a CPH-DUS, if so i think you will arrive and depart from the same gate I guess even on the same plane , there is no seperate arrival level at CPH, you may even have some time to do a bit of shopping.... that is if you have a boarding pass for the CPH - DUS leg...
Tue Oct 10, 2006 5:46 am
Thanks for the replies.
Yes, I arrive from DUS and fly back directly afterwards, I guess it will be the same plane, so that's absolutely good news. Now I'm assured that my Air Berlin Mileage run DUS-CPH-DUS-ZRH-DUS-ORY-DUS (one day) will work fine  Smile
