newagebird
I Came Close To A Jet Today!
Tue Oct 17, 2006 10:16 pm
Hey,
I fly around in Melbourne, australia on a regular basis in a C172(still training). I was enroute from moorabbin to Benalla which is about 80 miles north of MB. After getting a clearance to tract direct at 6500 feet to Benalla i had established myself on climb and was cruising at 6500 ft. I heard ML radar clear Virgin flight DJ 318 to 7000 feet and track direct to ML. that means they were taking a southwesterly track. The A?c was a B737
I didnt have any chance of noting their position as they had passed a waypoint only their charts had. suddenly they passed just above me at 500 feet higher than me. I couldn't believe how close we were...i could see the registration.
After he passed me ATC simply said clear of traffic..descend 4500 track direct ML.
Is it normal for ATC to clear two aircraft in such close proximity so close to each other? Isn;t there some restriction to wake turbulence and that kind.
Your thoughts appreciated and anyone whos come that close to a jet is welcome to share
IAHFLYR
RE: I Came Close To A Jet Today!
Tue Oct 17, 2006 11:23 pm
I sure don't have any knowledge of anything other than here in the States but 500' vertical separation from IFR to VFR traffic in Class B airspace is used daily. Since you refer to the airliner as B737, there would be only a wake turb advisory given, had it been a Heavy or B752 the 1,000' would have been required.
ATCGOD
Wed Oct 18, 2006 12:03 am
Quoting IAHFLYR (Reply 1):
Not totally sure of the ICAO rules on this, but here in the states wake turbulence calls are only required for a "heavy" aircraft. 737 is not a heavy, and all IFR/VFR only requires 500' of seperation.
Quoting Newagebird (Thread starter):
Yes, at least here in the States.
bond007
Wed Oct 18, 2006 12:31 am
Although it sounds a legal separation, it appears unusual that ATC didn't at least advise you of the traffic. You were in contact with ATC at the time correct? VFR flight following?
ATC had obviously advised the 737 of your position, otherwise they wouldn't have said 'clear of traffic', so the good news is that they knew where you were.
IMO ATC should have advised you of the traffic if you were in contact with them....not a legal requirement, but rather informational. Although 500' is a big distance for those IFR pilots who fly accurate altitudes every day ... it very easy for a low-time student pilot to bust 500' either side of assigned altitude, or to have the altimeter set with the wrong pressure.
Jimbo
falstaff
Wed Oct 18, 2006 12:45 am
Quoting ATCGOD (Reply 2):
737 is not a heavy,
A 737 may not be a heavy, but it sure looks like it next to a C172!
My mug slaketh over on Falstaff N503
ATCGOD
Wed Oct 18, 2006 12:53 am
Quoting Bond007 (Reply 3):
Actually, it is a legal requirement if you are operating at the minimum seperation. Not to mention the fact that merging target procedures call for mandatory traffic calls and they were obviously close enough to be considered merging targets. But we don't know if he was having flight following services provided...sounds more likely that he was just listening to the frequency. Traffic to one aircraft is traffic to another aircraft and someone messed up if he was getting FF and was never advised of the traffic.
Quoting Falstaff (Reply 4):
Very true...and funny!
IAHFLYR
Wed Oct 18, 2006 1:36 am
Gonna get into your stuff.... Smile Never said it was "required" just a cautionary advisory that IMO, there could be some nice wake for them, and nice to give so the Hawk pilot can choke the yoke a bit more!!!
Quoting ATCGOD (Reply 5):
Merging targets procedures apply when only1 aircraft is a turbojet or do they both have to be turbojet? Interesting interpretation of that paragraph! For if only 1 of them need to be a is a turbojet then you apply merging targets, if both must be turbojet to be required to apply merging targets then they must change the power plant in Australia of a C172?
 expressionless
ATCGOD
Wed Oct 18, 2006 2:00 am
Quoting IAHFLYR (Reply 6):
Gonna get into your stuff.... Never said it was "required" just a cautionary advisory that IMO, there could be some nice wake for them, and nice to give so the Hawk pilot can choke the yoke a bit more!!!
LOL, I know, in a perfect world it'd be nice to get a traffic call in this instance. But the controller is only required to give it on a "heavy" aircraft. I was just pointing that out...I just wanted to clarify what you were saying. I remember when I used to fly into the regional airport here I used to get "caution wake turbulence" calls from the controller behind B1900D's...absolutely funny, but you could tell when you were too close to one. I give them when I have time and when I am required, other than that the rules don't say I have to so I try to put some common sense on the pilot.
Merging target procedures are for turbojet aircraft, yes. But, if you're required to give the turbojet aircraft traffic you should also give the other aircraft traffic as well.
IAHFLYR
Wed Oct 18, 2006 2:09 am
Quoting ATCGOD (Reply 7):
Agreed......now I am going to go do that very thing!!! ahhhhh NOTAM out for sure!  Smile
Such as the phrase, "use caution upward prop-wash"?? I got banged around pretty good a few years ago when I turned into a close parallel runway slightly below and 1 or so behind a BE9F.....WOW, Magic Kingdom has nothing on the T tail 90! Smile
ATCGOD
Wed Oct 18, 2006 2:47 am
Quoting IAHFLYR (Reply 8):
 rotfl
newagebird
Wed Oct 18, 2006 8:45 am
Hey yeh
Thats right...i was never advised. All i heard was virgin 318 descend 7000 passing waypoint (whatever). We dont use IFR nav charts so i didnt have a clue which direction he was coming from. Just appeared out of nowhere in my 1oclock high.
Cheers newagebird
IAHFLYR
Wed Oct 18, 2006 8:49 am
Quoting Newagebird (Reply 10):
Or maybe you were on the "landline" and missed the traffic call!  Smile
roseflyer
Wed Oct 18, 2006 11:19 am
When I was training for my private pilot license, I was just purely amazed at how close planes do get to each other. I was on a parallel approach with a 767 at BFI and I was amazed at how close that heavy jet came to me in my little 172. I didn't even have warning either that there was a jet that close until he was right there on my left.
