Pe@rson
Domestic Flights In Bolivia, Peru And Argentina
Thu Oct 19, 2006 12:02 am
Hi,
I'm after fare details - if you buy the ticket in the country, rather than expensively over the 'net in advance - for the following flights:
1) TDD-SRZ. Amadeus says 5L operates the route about twice-daily using D28s, but I can't find info. on 5L's website.
2) SRZ-CBB. Both LB and 5L operate this route numerous times daily using 727s.
3) CUZ-AQP. LP operates it once-daily using the 319 and has a further once-daily one-stop flight also using the 319.
4) USH-RGL. AR operates it once-daily using the M83.
5) IGR-AEP. Numerous daily flights by AR, A4, etc.
Thanks a lot!
RAFVC10
RE: Domestic Flights In Bolivia, Peru And Argentina
Thu Oct 19, 2006 12:16 am
Hi Pe@rson,
Quoting Pe@rson (Thread starter):
if you look carefully in the Aerosur web site, the domestic schedules are from 2003!!
LB operates daily a 100 from SRZ to CBB.
Very old aircraft and in a worst conditions. Good luck!!
A4 were out of business last year when they try to compete with AR and IB leasing 742 and 763!!
This route is now operated by Aerolineas Argentinas with M80 and 737 equipment; LAN Argentina operates with 737 and 320 equipment.
Will be nice to fly in LAN Argentina.
Gerard
El dia que los gilipollas vuelen, no podremos ver la luz del sol!
Pe@rson
Thu Oct 19, 2006 1:19 am
Thanks, G.
Why is Amadeus' info. so out-of-date, then?
Pe@rson
Thu Oct 19, 2006 1:54 am
Oooops. Sorry, I misread what you wrote.
Glad to see 5L's website is so up-to-date.  Silly
Any idea of the fares if purchased locally?
Thanks.  Smile
Cubsrule
Thu Oct 19, 2006 2:02 am
4M is $82 U.S. o/w with some advance purchase. If you go to lan.cl, you can buy in English with a credit card from wherever. Taxes on domestic flights aren't real high in South America, so it should easily be less than $200 r/t.
PHKLM
Thu Oct 19, 2006 2:22 am
Quoting Cubsrule (Reply 4):
This route is 100USD including taxes on both AR and 4M when bought by foreigners. You cannot buy domestic fares when you do not hold an Argentinean passport. So, if you buy thru lan.com in advance, select your appropriate country and don't go for the "Argentina" option, unless you are prepared to pay the difference at check-in.
Quoting RAFVC10 (Reply 1):
For heaven's sake! I don't know how you dare to insult Aerolineas, but obviously you've never been on an Austral or AR MD-80. They're fine and everything but old and "worst conditions".
The flight to Rio Gallegos will cost about 60USD, you'll have to pay additional airport taxes in USH. I don't know what you're planning to do in RGL, it's a sh*thole. Try to fly to FTE directly, if that's where you're heading next. When going north, try REL.
EDIT: If you mean LADE, instead of AR, I will take back my words. But in your post I read AR!
5L does not fly TDD-SRZ anymore. You can fly Amaszonas instead, but I've heard some doubtful stories about them. At least its cheap, for less than 70 USD you're done See http://www.amaszonas.com/
Happy flying, luckily FR doesn't mess around in South America, so you'll get to see something *different*. At last...
[Edited 2006-10-18 19:24:32]
RAFVC10
Thu Oct 19, 2006 3:00 am
Hi Pe@rson,
my sister stayed in Argentina last summer with my brother in love. She flew to EZE from MAD with IB and all the domestic flights were flown with AR.
The domestic flights are very expensive and the only chance you have to get these tickets more cheapest is to arrive from your foreign country with AR flights.
From Spain there are a reduction of 35% if you made all the flights with AR.
PHKLM
Thu Oct 19, 2006 4:43 am
Quoting RAFVC10 (Reply 6):
Well, if you book the tickets in Argentina, they are quite reasonably priced (i.e. for foreigners with hard currency).
AEP-IGU - 100 USD
AEP-USH - 150 USD
AEP-BRC - 200 USD
AEP-COR - 70 USD
USH-FTE - 70 USD
The only things that you need to look out for are low-fares for the peak travel times in December and January, especially when flying to USH. But from this year on, LAN Argentina is serving the heavily congested route AEP-BRC-FTE-USH with A320's, this should improve the situation a bit.
Furthermore, USH is connected to PUQ (Punta Arenas, Chile) with LA in summer...
Cubsrule
Thu Oct 19, 2006 8:04 am
Quoting PHKLM (Reply 5):
Thanks, PH-KLM. I had forgotten about that reg, and should have mentioned it. The $187 with taxes fare is for foreigners (and may be paid in Argentine or Chilean Pesos, American dollars, or Euros if that helps with credit card fees).
PHKLM
Thu Oct 19, 2006 5:38 pm
Quoting Cubsrule (Reply 8):
Well, maybe this is getting too detailed, but your statement is true and false.
If you book AEP-IGU well in advance thru LAN.com using "Other countries" you can book a 'web-special' fare of 82 USD. Including all taxes this is 93 USD. You can pay this online via all major creditcards, or in Argentina in peso's or US dollars. So if you are OneWorld FF and like the A320, this the way to go.
If you opt for AR or AU the same flight costs 365ARS, that's well over 100USD, but - now here's the crucial part - this ticket has to be bought WITHIN Argentina.
So Pe@arson if you want to book ahead go for LAN Argentina, you will have an e-ticket, pre seat-selection and on-line check-in and you are able to get the lowest possible fares and pay online.
Aerolineas is also fine but when you buy from abroad they charge you in USD instead of ARS (300% more expensive), so you'll need to wait till you are in Argentina and buy the tickets there.
On a final note; besides the tricky thing on buying tickets from abroad online , there is also a difference for tickets bought within Argentina, but they will never sell you a domestic fare unless you have an Argentinean passport. When you try to purchase a ticket online they will let you pay the price difference at check-in.
Ok hope this clears things up.
Ratypus
Thu Oct 19, 2006 10:03 pm
may have changed but when i was in peru i used to go down to the LAN offices a couple of days before i wanted to fly and book internal peruvian flights for about 40-50 dollars one way from cuzco to arequipa/arequipa to lima etc
Eirules
Thu Oct 19, 2006 10:32 pm
Quoting Ratypus (Reply 10):
I have been to S.America a few times, last in 2005 and this was the case. Just go to a local booking office or travel agent and the tickets are very cheap, think i paid abut $45 CUZ-AQP with LA and flew 2 internal Bolivian flights with LB and think they came to a combined $100. If I was you I would wait til you get there, but I have no experience of Argentina Im afraid
[Edited 2006-10-19 15:33:53]
Pe@rson
Thu Oct 19, 2006 11:31 pm
Thanks, folks. Nice to hear about those cheaper in-the-country fares. Anyone have any in-the-country info. re. those 5 routes I posted?
Eirules
Fri Oct 20, 2006 1:03 am
The only one of those particular routes I have flown was with LP AQP-CUZ return twice. Nice new A320, excellent views as you come into CUZ, particularly if you sit on the left side of the aircraft if I remember. Flight was cancelled on one my trips however due to "fog" but yet other aircraft were taking off. IMO was just due to lack of passengers but welcome to South America I suppose!
FLY2LIM
Fri Oct 20, 2006 4:13 am
The tax in Peru (IGV) is 18%, and that's considered high. There are also, most likely, airport charges.
Ha ha, I'm only correcting you because it was funny. Your sister's husband is your "brother in law," which is cunado in Spanish.
FLY2LIM
Faucett. La primera linea aerea del Peru.
