boacvc10
Which Airlines Can I Use To Fly DCA-ACY
Fri Oct 20, 2006 3:57 pm
I tried to lookup flights on both Comair and Spirit, but was unable to find any days where I could fly easily from DCA to ACY. Is there any alternative carrier that covers either IAD, DCA, BWI to ACY ? I need to go back/forth several times in the next few months on business and travel by car (3.5 to 4.5 hours + tolls), bus (4.5 hours with transfers), train (3.0 to 4.5 hours with change) really eats up the whole day. What cities are directly connected to ACY ?
BOACVC10
Up, up and Away!
COEWRNJ
RE: Which Airlines Can I Use To Fly DCA-ACY
Fri Oct 20, 2006 8:20 pm
It may wind up being quicker to drive. I thought DL Conection had a few weekly flights from IAD or DCA to ACY but they may have been cut. ACY has the following service that I am aware of.
NK:
DTW
MCO
PBI (Seasonal)
FLL
MYR
TPA
DL:
ATL
CVG (Soon to be cut if it already hasn't been.)
MCO
Your best bet is on DL but the timings sort of kill the day and it will take you much longer than it would to make the drive. The routing would be IAD/DCA-ATL-ACY.
Hope that helps!
AirScoot
Fri Oct 20, 2006 9:05 pm
DL did run a flight DCA-ACY for a while but it quietly disappeared. This was about two years ago. Right now, your only option is to do the DCA-ATL-ACY which will involve a forced connection and about 5-6 hours travel time (slightly more than driving it if you hit traffic just right). Are you headed up there for the Tech Center?
ANCFlyer
Fri Oct 20, 2006 9:33 pm
There's no non-stops on any carrier.
If you MUST fly, unfortunately DL via ATL is your only really decent option.
Try this: www.amtrak.com
Washington Union Station through 30th Street Station in Philly and on to Atlantic City . . .
Better Ride, Same amount of time generally, much less headache.
[Edited 2006-10-20 14:33:42]
AirScoot
Fri Oct 20, 2006 9:50 pm
Quoting ANCFlyer (Reply 3):
Then there's this.  Smile I was going to mention it but the whole aviation website thing.... Big grin
Just remember.. if it snows, you're stuck in Philly. The connection to Atlantic City is on NJ Transit and has a tendancy to not go if there's a lot of snow in the Pinelands.
STT757
Fri Oct 20, 2006 10:16 pm
You can take Amtrak to 30th Street Station in Philadelphia and transfer to New Jersey Transit's Atlantic City Rail line to Atlantic City.
ANCFlyer
Fri Oct 20, 2006 10:23 pm
Quoting STT757 (Reply 5):
Is there an echo in here?  wink
BigOrange
Sat Oct 21, 2006 1:15 am
If you don't want to drive all the way, you could fly DCA-PHL and drive the rest of the way, or take Septa from PHL-30th St then NJ Transit 30th St-AC
Zudnic
Sat Oct 21, 2006 1:29 am
Quoting BigOrange (Reply 7):
could fly DCA-PHL
Why bother? That's barely 100 nm.
AirScoot
Sat Oct 21, 2006 1:48 am
For the amount of time and hassle to fly DCA-PHL then get a transfer to 30th St Station, then get on the NJ Transit Train, you might as well have driven it. DCA-PHL is nice and expensive as well which doesn't help.  Sad
