Boeing Nut
AC's Executive First Class, Evacuation Risk?
Sat Oct 21, 2006 4:37 am
I got to wondering when I saw this photo in the database...
Photo © Youri Thonon - Contrails Aviation Photography
With this layout, it seems extremely difficult if passengers needed to progress from one side of the aircrfat to the other to evacuate. (Say a fire is on one side) Are there rules about this and if so, what would be the judgement on this?
Obviously it is legal or else it wouldn't be installed, but i was just wondering.
Boeing Nut
"the original one"
KLM685
RE: AC's Executive First Class, Evacuation Risk?
Sat Oct 21, 2006 5:10 am
IMHO, If there is a fire on one side of the aircraft, having passengers jumping to the other side of the aircraft ( on NOT this kind of business class) would be riskier than actually running on your aisle to the emergency exit or to the rear and front of the aircraft.
Just jumping over the seats might be even more harmful as there are pax stuff, arm rests, etc...
mspguy
Sat Oct 21, 2006 5:11 am
I'd rather get across to above pic versus 5 seats in coach!!!!!!!
If it ain't broke, DON'T touch it!!!!
Boeing Nut
Sat Oct 21, 2006 10:35 pm
Quoting KLM685 (Reply 1):
But in this configuration, cross access is totally blocked off.
In standard configurations, it is much more passable as there is much more access to the floor.
Photo © Magnus Trippler
FLYACYYZ
AC-777LR Introduction & Specs
Sat Oct 21, 2006 11:21 pm
There are enhanced "stowage" procedures worked out in cooperation between the MOT and AC, that will be adhered to. Pillows, bedding, coats, carry on bags, etc. have very specific requirements on this aircraft.
I don't see it as any different than an airline that operates a conventional 2-3-2 business (or economy) configuration. Being non-symmetrical, ultimately movement in one aisle is bound to be heavier than the other.
Above and Beyond
Boeing Nut
Sat Oct 21, 2006 11:29 pm
What I am getting at is with the Executive First Class, which is impressive BTW, there is a wall to climb over, while with the "standard class" there is not.
northstardc4m
Sun Oct 22, 2006 4:29 am
ok well lets think about this:
A> evacuation... people will be behaving either very calmly and organized or will be behaving like raving loons with no common sense. In the case of the latter no layout will work so we will hereby discount it.
B> Where the doors are, there is access from both aisles.
C> ExecFirst carries far fewer people per row than the back
I don't think it's a problem. the bottle neck is the same, its the bulkhead forward.
In the few cases i can think of that no evecuation was possible from one entire side of a plane on a widebody. The Galley space is where 50%+ of the people tried to cross between aisles anyways.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
ebbuk
Sun Oct 22, 2006 4:36 am
I totally see where you are coming from Boeing Nut.
I fear it might take a tragedy for them to see sense.
Door5Right
Sun Oct 22, 2006 5:31 am
You raise a very interesting question, Mr. Boeing Nut. The style and layout of these seats makes the cabin look very cramped I think and there certainly does seem to be a "wall" blocking acess between the rows. Call me old fashioned but I like to sit in a seat firmly facing forward no matter what class I am in.
My soul is in the sky...
Markhkg
Sun Oct 22, 2006 6:45 am
Quoting Boeing Nut (Reply 5):
During an evacuation, lower density seating areas will be faster to evacuate. This has always been the case aboard any aircraft, and is the reason why cabin crew in First or Business class need to let other crew know of "dried up exits" during the evacuation sequence. (IE Doors 1R and 1L will dry up before 2R and 2L).
Since cabin crew are trained to evacuate 1 pax per second through the door, it is safe to say that even with only 1 door available, all Executive Class pax can be out within 30 seconds once people start sliding (24 seats, right?). (And in "best case" Executive class pax have access to 4 doors in an emergency.) We can't say the same about those on Economy since density is much higher there. Bottlenecks tend to happen at the bulkhead rows or at the exits, which is more important than the cross access of seats.
We should be more concerned about the pax in high density seating since it is harder for them to get out...in addition to having to get more of them out compared to business class pax.
Viscount724
Sun Oct 22, 2006 8:27 am
Many B747s have been flying for decades with a longitudinal galley running the length of the B zone (between the 1st and 2nd doors) on the right side of the aircraft with a solid wall separating the galley from the seating area on the left size of the B zone. That cabin is at least as long as the J cabin on AC's 763.
If there was a safety issue with the new AC 763 layout (which there obviously isn't or it would never have been approved), then it should be even worse for 747s with the lengthwise galley. You certainly can't jump over that wall. And those seats are much further from the other side of the aircraft than on a 767 due to much wider 747 fuselage.
Many other aircraft, especially widebodies, often have quite a few rows of seats adjacent to galley/storage units or upper deck stairways etc. without easy access to the other side of the aircraft.
Photo of TG 744 below with the solid wall down the middle of the B zone with the galley to the right. KLM 747s have had that galley layout for decades, except they now have 41 economy seats in that area (5-abreast, 3-2).
Photo © Sam Chui
KL 744 all-passenger (combis are the same) seating chart illustrates the longitudinal galley layout.
http://www.klm.com/travel/ch_en/trav...on/on_board/seating_plans/b747.htm
ikramerica
Sun Oct 22, 2006 8:51 am
Quoting EbbUK (Reply 7):
Quite an irrational over reaction.
Any airline with a 'suite' product has this same situation. VS/NZ with theirs, AA, EK others. There are various forms of "solid wall" layouts on 330s, 767s, 747s, 777s and new offerings on the A380, 748, 787 and 350 as proposed.
Then you have all the people in the nose of a 747 that are completely trapped if there is a fire behind them. And same holds for people in ERJs behind the window exits, as they only have one way out.
A look at that AC jet, we are talking about 7-16 people having to get to doors 1 or 2 (depending on which side has the fire). They are going to get there WAY faster than the 42Y pax between doors 2 and 3 fighting to get across...
BAE146QT
Sun Oct 22, 2006 9:14 am
Quoting Door5Right (Reply 8):
A study was performed some years ago which determined that rearward-facing passengers had a far lower risk of injury - and a greater chance of escape - in survivable impact events.
The end result was that "people just didn't like it", so it wasn't adopted (except in some military applications).
What is your reasoning for wanting to face forward? Is it psychological or is there some practical reason?
Todos mis dominós son totalmente pegajosos
Markhkg
Sun Oct 22, 2006 9:52 am
Quoting BAe146QT (Reply 12):
Okay, these AC seats are actually fitted with AIR BAGS in the seat belts. This actually could make these seats safer than rear-facing ones. (Rear facing has its problems too, like having your face exposed to all the debris during a crash, needing to strengthen the seat, etc.)
chewingplastic
I also like to face forwards. My reasoning: your direction the plane goes, the seat should face. But maybe it's my personal psych. reason.
ebbuk
Sun Oct 22, 2006 10:12 am
Quoting Ikramerica (Reply 11):
Of course you are always right.
BAE146QT
Sun Oct 22, 2006 10:21 am
Mark,
It was a genuine and non-sarcastic question of course. And you're right, putting people backwards has its own challenges, (not least of which are the psychological ones).
But did you know that the main benefits of having people adopt the brace position are;
1) That it keeps their dentistry intact for identification purposes?
2) That having the neck bent in that position improves the chances of a clean kill against the seatback through severing the spinal cord?
Just a thought.
Markhkg
Sun Oct 22, 2006 11:01 am
Quoting BAe146QT (Reply 16):
I totally understand where you are coming from...I hear a lot of people say it. However, the truth is that the brace position DOES save lives; the dentistry/killing you by having you snap your neck intact thing is in fact, an urban legend.
The mythbusting on this has been extensively covered on other websites like
http://www.snopes.com/travel/airline/brace.asp
and even the program "Mythbusters". While it is true that flight attendant seats are safer (since some are rear facing), the brace position is designed to PROTECT your life, rather than end it.
I've read many position papers by the NTSB, FAA, UKAAIB, all of whom tell people that it saves lives. Futhermore, since all pax on board Scandinavian Airlines Flight 751 adopted the brace position, it is widely cited as the reason why no one was killed. (Moment before impact, passengers were instructed to "grab their knees" by the Senior Cabin Flight Attendant). There are also cases of people putting their heads between their legs because they felt sick or did it instinctively and survived.
I do believe a lot can be done to increase pax survival. But it requires a total redesign (i.e. no overhead cabin bins that can drop a suitcase on you, better restraints, etc.) and shift in thinking!!!
BAE146QT
Sun Oct 22, 2006 11:31 am
I have been a member of Snopes' forums for a number of years, and I have always disagreed with their treatment of this.
She (Barbara in this case) seems primarily concerned with one main idea. Namely that the legend comes from the fact that a dead passenger doesn't sue. Like dead passengers dont have family. Right.
Secondly, this business of flailing limbs. If that really was the primary concern of the FAA et. al., then the brace prosition should involve being belted in, with your heels on the seat and your arms around your head and lower legs. Much closer to the foetal position than with your heels on the floor. Better a broken arm or two than your nose pushed into your forebrain, as will often happen in a frontal impact when your forehead is against the seatback in front of you.
As for Kegworth, those seats actually became detached from the seat tracks. In many cases, the legs of the seats themselves collapsed or became detached. Having your feet on the floor at that time would not end well and did in fact cause dismemberment.
Of course I understand that I am disagreeing with a few august bodies here, but I don't trust their advice any more than I trust any other "one size fits all" advice that I get from government bodies and their agences.
walter747
Sun Oct 22, 2006 11:38 am
it would be difficult and especially if you enlarge the picture you can see how little space there is on the asile
Hussel, Hussel, Husel, Grind, Grind, Grind
Markhkg
Sun Oct 22, 2006 11:45 am
Truth be told, the brace position is a sad compromise between safe aircraft seating and restraint systems.
Quoting BAe146QT (Reply 18):
I think one of the problems with a crash is people smacking their head against the seat back. The head injury score reaches 1000 or even more in such a case. Pre-positioning the head on the seat back reduces the risk of such an impact (a reduction of up to 100 points, whereas an airbag can reduce it by 200), and the seat back is meant to be energy absorbing. (Unless you are in one of the AC or VS seats, which have no soft seat back, in which case that's the reason why have the airbag...CX will use a three point shoulder harness.)
That is a HUGE problem. The seats can be designed to absorb 16G, but if they get detached from the floor, what's the use?
If you have a report on that, I would love to read it. The Kegworth crash was the UKAAIB's intense research on the brace position. (Didn't the UKAAIB also recommend rear facing seats and three point shoulder belts?)
It's good to be skeptical.  Wink That way we get new ideas to improve cabin safety!
BAE146QT
Sun Oct 22, 2006 6:22 pm
Quoting MarkHKG (Reply 20):
That's the problem, all right. And as you say above;
...unless the cabin is redesigned - which eats into the airine's revenue - then a compromise is all you'll ever get.
To be more accurate, I believe it was amputations necessitated by crush injuries when the seats collapsed. The report was on some medical university site - I have the link at work and I'll dig it out when my boss isn't shoulder surfing me.
Door5Right
Sun Oct 22, 2006 11:07 pm
I just like seats that are parallel and facing forward. The angled/cocoon style of seating seems to me to lead to a very insular flight experience.
I am just as happy in rearward facing seats too. BEA's first Tridents had half the cabin rear facing and passengers seem to accept it. Sometimes when BCAL flew between BFS and LGW it was on a BAC1-11 which operated flights at the same time for the MOD and all seats were rearward facing. I think I am correct in saying the RAF VC10's had rear facing seats but the Tristars now in use have forward facing seats.
1stfl94
Mon Oct 23, 2006 3:34 am
It would be even more confusing if during your safety briefing you had five different types of brace position. Confusion would kill more people than the brace position, which does save lives.
Also, if your plane comes for a hard landing (not necessarily smashing into the ground) then the brace also protects you more from any cabin baggage crashing down.
A340600
Mon Oct 23, 2006 3:43 am
Don't be rediculous, do you not think it would have taken testing and consideration by people who knew more on the subject to approve the seats.
On a side note, what a truly hideous cabin, ugly colours and seat fabrics and there is a seriously plastic feel to it,
Sam
