SA7700
United In-Seat Power Supply
Wed Oct 25, 2006 12:36 am
What kind of adapter do I need to make use of of the in-seat power supply (laptop) on United's 744's, 757's (non-PS) and A320's? I see on Seatguru that the power type on United is EmPower - I am not familiar with this. Any additional information will be welcomed.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
MEACEDAR
RE: United In-Seat Power Supply
Wed Oct 25, 2006 2:01 am
I was on the A320 and they didn't offer that. I was flying from LAX-MCO on UA 272. I even upgraded to a higher class so I can get the in-seat power.
Go3Team
Wed Oct 25, 2006 2:21 am
Its a connector that offers around 12-16VDC like a cigarette lighter connection, only different:
http://www.the-gadgeteer.com/review/...repower_3500_series_adapter_review
Yay Pudding!
unitednrt
Wed Oct 25, 2006 3:24 am
Many aircraft have their power outlets covered up, i dont know the reason for this as it varies frame to frame.
"...That's a lovely name. My name's Milton; Milton Ettenheim, but my friends call me Bubbles."
Stitch
Wed Oct 25, 2006 3:30 am
United First and United Business on non-p.s. equipment use an Empower adapter and provide up to 70 watts.
iGo, Kensington and Targus (amongst others) make adapters for laptops, DVD players, MP3 players, and other devices.
As noted by UnitedNRT, often these units are either disabled or the ports are covered over. This is especially true in United First on the narrowbodies. You are most likely to find working ports in United First and United Business on the widebodies (especially three-class).
If the ports are off (no green light), politely ask the Flight Attendant to reset the circuit breaker (usually near Door 1L) as the system may work. However, in many cases, the system has been disabled for deferred maintenance.
SA7700
Wed Oct 25, 2006 3:51 am
Thanks for all the info thus far.  Smile UA870 from SYD-SFO (J-class) is going to be the longest flight of all the United sectors, while the rest will be in USA domestic First.
SA7700
N1120A
Wed Oct 25, 2006 3:54 am
Quoting SA7700 (Reply 5):
Your 744 flight should be no problem as far as EmPower is concerned, and it is possible that the F/As will even sell you an adapter
gh123
Wed Oct 25, 2006 3:58 am
I have had terrible trouble with the power supplies on the UA 777 business class. On AA you use the cigarette lighter plugs on united the other type.
When I flew on United last time the Flight Attendant tried my adapter on several seats and it worked on some and not on others.
Good luck!
daron4000
Wed Oct 25, 2006 7:31 am
Surprisingly, all the narrowbodies I've flown recently (757's and Airbii) have worked!
mohavewolfpup
Wed Oct 25, 2006 8:12 am
if it's 70 watts only, I guess I wouldn't be able to bring my laptop with a 130 watt power supply onboard? somehow I picture a 757 dipping and pulling up again in the air as the cabin lights flicker on and off while the pilots are trying to figure out the sudden power loss onboard :p
Stitch
Wed Oct 25, 2006 10:24 am
Quoting Mohavewolfpup (Reply 9):
Depends on the laptop.
My HP zd7000 desktop replacement (3.4GHz PIV / 17" LCD), which has a 135-watt AC PS, could not run from the port, but I could charge the battery if the laptop was off. Also, if I left the battery in and connected to emPower, it bounced back and forth between the two (emPower up to 70 watt load then battery for more).
UAL777UK
Wed Oct 25, 2006 8:49 pm
I bought an adaptor on a flight from LHR to SFO onboard when i was in F and that worked fine.
satx
Thu Oct 26, 2006 8:10 am
Quoting Stitch (Reply 10):
My job gave me one of those as well. It looked cool in the catalog, but that thing is huge. I would have never tried to use it anywhere outside of a sturdy desk. Why you would intentionally try to take that thing on an airplane is beyond me. I ended up trading mine back in for an nc6000 just so I had something that was small enough to use on a plane or on my lap. The 7000 series is just too big to lug around and unless you're trying to play games on it there's really no reason to buy such a hugely inefficient device.
Open Season on Consumer Protections is Just Around the Corner...
Stitch
Thu Oct 26, 2006 8:13 am
I wanted a desktop replacement (she replaced a laptop and a desktop) that would last years and would look great playing DVDs. But yes, she was a monster - especially with three batteries to try and keep her alive cross-country.
I'm a Mac user now, so I carry a MacBook 13" with me. They just released a MagSafe emPower adapter so now I'm good to go on UA.  Smile
SkyvanMan
Thu Oct 26, 2006 8:21 am
When flying on United's 744s you should have in seat power in J class. I've had it whenever I've flown UA internationally on 747s and 777 IN J Class.
The 3 best planes of all time: Shorts Skyvan, 330 and 360
SA7700
Thu Oct 26, 2006 5:38 pm
Thanks for the replies, I am looking forward to my first United longhaul flight  Smile The laptop will come in handy as inflight entertainment on this leg of my RTW.
SA7700
