FL370
What Is A B747BCF
Fri Oct 27, 2006 2:08 am
ive heard lots of people talk about the 747BCF. but when i look at one it looks no different than a regular 747-400! so whats the difference! and whhy is it called a B747BCF??
and sorry if this has been brought up before
fl370
ikramerica
RE: What Is A B747BCF
Fri Oct 27, 2006 2:12 am
It is the name for the Boeing led conversion program (versus third party conversions). Boeing still doesn't do the work, it's contracted out, but you "order" a BCF from Boeing, they find the old 747 (or you provide it), and then after a while and some "purpose reassignment surgery" you get a 747BCF to fly cargo around in.
airbusA346
Fri Oct 27, 2006 2:22 am
BCF = Boeing Converted Freighter
Photo © Enrico Pierobon SpotIT
Photo © Yuxiaobin
Photo © K.L.Yim
Photo © Sokol Ymeri
Most not if all are converted @ Xiamen, except the ones converted by another company, which as called BSF's
Photo © Erezms
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
NoWorries
Fri Oct 27, 2006 3:12 am
The hump on the BCF is so much longer that on a normal 747F, do carriers (such as FedEx, UPS?) make use of this extra space?
Would a 748i built as the freighter (with a much longer hump) be of any interest to a package carrier vis-a-vis the A380F?
airbusA346
Fri Oct 27, 2006 3:44 am
Quoting NoWorries (Reply 3):
A 744BCF is a ex Pax 744 which has had a Side cargo door fitted and a stronger floor fitted and all the windows on the lower deck plugged.
The rear section of the hump is empty, just after the upper deck door is the end of the upper deck which has been shorten, so there is northing at the end, no floor at all.
And FedEx and UPS dont own any. The only people who have them are:
-CX Cargo
-Korean Air Cargo
-Air China Cargo (BSF not BCF)
-JAL Cargo
-Dragonair Cargo
And I think Martinair Cargo has a few 744BCF's on order.
No, because there is no need, and I think it is more Aerodynamic and save weight to use the shorten Upper Deck AFAIK.
Tom.
[Edited 2006-10-26 20:47:09]
[Edited 2006-10-26 20:48:12]
beech19
Fri Oct 27, 2006 4:06 am
Quoting AirbusA346 (Reply 4):
Partly... but the main purpose is that because a 747 is a heavy hauler (not really a PF by default) they shorter the upper deck because of weight for sure, BUT the upperdeck shortens the ceiling height in the main floor by a few feet. If you remove the 23' of "extended upper deck" you get that much more height available for large cargo on the main floor.
KPAE via KBVY
wjcandee
Fri Oct 27, 2006 4:37 am
Quoting AirbusA346 (Reply 2):
Almost. 747-400BCF is the designation given to freighters converted through Boeing. Boeing manages the conversion from beginning to end. However, they have now blurred the line a little by selling "kits" to Singapore Airlines and Korean Air which allow those airlines to do the hands-on part of the conversions themselves (and still to call the thing a BCF, I believe), and to resell any so-converted aircraft to others if they wish.
The 747-400BDSF shown in the photo you posted is a whole different animal. BD stands for Bedek, which is a part of IAI, Israel Aircraft Industries. IAI/Bedek does a lot of conversions of aircraft from pax to freighter, both as a subcontractor to the manufacturer and also using its own STCs. Right now, it is interested in doing 747-400 conversions using its own engineering and STC, and will produce the 747-400BDSF, the prototype of which you posted. IAI/Bedek will presumably also retain (as Boeing did) shops other than its own to do the hands-on work if in fact it gets enough orders to need to outsource some of the work.
Hope this clears that up.
airbusA346
Fri Oct 27, 2006 4:42 am
Quoting Wjcandee (Reply 6):
prototype
That prototype is now flying with Air China Cargo, in there full livery.
Tom.
wjcandee
Fri Oct 27, 2006 4:43 am
As noted above, the floor of a substantial portion of the "hump" is removed in the conversion. This is because the floor of the hump impinges on the ceiling of the lower deck, although this isn't obvious in the passenger version because of the false (lowered) ceiling in the passenger cabin. When you strip out the passenger fittings, you see that the ceiling in the main part of the aircraft is higher than the floor of the upper deck. It is most advantageous, therefore, to dismantle the floor in the unnecessary part of the upper deck so as to permit the aircraft to carry a larger number of taller containers, and this is done. This is also why the "hump" on the 748 freighter is shorter than the hump on the 748 passenger version: the smaller hump allows more tall containers in the aircraft.
airbusA346
Fri Oct 27, 2006 4:47 am
I have just found a press release of Boeing's site saying that the 744BCF @ Xiamen in DragonAir Cargo colours, will be delivered to SQ and then will be sent to Dragonair, and they mentioned the conversion kits for SQ.
SEATTLE, Oct. 26, 2006 -- SEATTLE, Oct. 26, 2006 - Boeing [BA: NYSE] today announced that it recently delivered a completed 747-400 Boeing Converted Freighter to Singapore Airlines.
For this modification, Boeing managed every aspect of the conversion process from contract signing, design and production through redelivery. Boeing hired Taikoo (Xiamen) Aircraft Engineering Co., Ltd. (TAECO) in Xiamen, China, to perform the hands-on modification work on this airplane.
Singapore Airlines has sold the aircraft to Dragonair through a separate and previously announced arrangement.
This is the sixth 747-400 Boeing Converted Freighter that has been redelivered through Boeing to cargo operators.
In addition to supplying Singapore Airlines with one fully converted freighter, Boeing has a special agreement with the airline to provide six freighter conversion kits. SIA Engineering Company will use the kits to modify and certify passenger airplanes as freighters.
Tom.
wjcandee
Fri Oct 27, 2006 8:54 am
Quoting AirbusA346 (Reply 7):
Right. It was the combi-to-cargo conversion, for which they have received their STC. I don't think they have their STC yet for the pax-to-cargo 747-400BDSF conversion, unless they got it within the last month.
Boeing Nut
Fri Oct 27, 2006 1:12 pm
UPS dont own any.
Not yet, but they will soon as they have some on order but I forget how many.
airbusA346
Fri Oct 27, 2006 5:02 pm
Quoting Boeing Nut (Reply 11):
Do they?
Any source to back that up?
Tom.
Fri Oct 27, 2006 5:10 pm
Quoting Wjcandee (Reply 10):
I think I saw the CA one at AMS earlier in September, a shame it got rejected for the database on this website. On the fuselage the text Boeing 747-400SF was readable. (just 'SF').
wedgetail737
Fri Oct 27, 2006 9:22 pm
The "BCF" is the new name stemming from the old "SF" meaning Special Freighter. The BCF is engineered by Boeing but the touch-labor is done by sub-contractors as mentioned. The older 747-200SF and 747-300SF were actually engineered and converted by Boeing in Wichita when there was commercial mod center there. When Boeing Aircraft Services (BAS), at the time, closed down BAS Wichita, all of the engineering was transferred to Seattle.
A little later, the BCF name was adopted to replace the SF designation. I believe the BCF is done by Service Bulletins.
Also, Boeing Wichita still owns the STC's for the 747-200SF and the 747-300SF, which actually doesn't make a whole lot of sense to me.
Boeing Nut
Fri Oct 27, 2006 9:45 pm
Quoting AirbusA346 (Reply 12):
Do they?
Tom.
http://www.airliners.net/discussions...2552429&s=ups+747-400bcf#ID2552429
gh123
Fri Oct 27, 2006 9:53 pm
Obviously the main deck is for maximum cargo space. Does anyone have a picture of their stairs up to the upper deck on these cargo jets?
thanks in advance
airbusA346
Fri Oct 27, 2006 11:45 pm
Quoting Gh123 (Reply 16):
I haven't seen any photos of the interior of a BCF, but the photo below is of a 744ERF stairs.
Photo © Linze Folkeringa
Tom.
beech19
Sat Oct 28, 2006 12:21 am
My understanding is a few seats and then just some empty space and a lav. Anyone been up top of 744F to verify?
KPAE via KBVY
Tod
Sat Oct 28, 2006 12:45 am
Quoting Wjcandee (Reply 8):
Not true.
The top of the main deck curved ceiling panels is WL 296
The bottom of the upper deck floor beams is WL 300.25
Quoting Beech19 (Reply 18):
No, but some of my co-worker were involved with the design effort.
Lav, Galley, seats and bins similar to a regular 744 except it ends at the u/d doors.
Tod
airbusA346
Sat Oct 28, 2006 12:52 am
I'm no crew, but AFAIK on the upper deck of a 744F are:
- Crew Seats
- Crew Bunks
- Galley
- Lav
Tom.
beech19
Sat Oct 28, 2006 2:46 am
Quoting Tod (Reply 19):
Not true.
Um... yeah it is. But maybe Wjcandee phrased it correctly.
The ceiling in the main part of the aircraft is higher than the ceiling in the area underneath the hump.
View the image in Reply 17 or do a search for the inside of 744F's on a.net images. You will see tons of pics showing the difference in height.
KPAE via KBVY
Tod
Sat Oct 28, 2006 2:56 am
Quoting Beech19 (Reply 21):
Not true.
Oh I get it. Just a confusion of nomenclature.
The freighters definately do have available more available vertical space aft of the upperdeck floor beams.
The freighters do not have a "ceiling" in that area.
Tod
airbusA346
Sat Oct 28, 2006 5:01 am
Quoting Tod (Reply 22):
The new 744F's do have a ceiling in that area, it is just higher up and is right up against the piping and wires in the ceiling.
Tom.
beech19
Sat Oct 28, 2006 5:21 am
Quoting AirbusA346 (Reply 23):
I'll translate again...
Note he said "ceiling" in quotes. The 744F does not have a low ceiling all the way down the aircraft. ONLY in the front under the hump. Hence "no ceiling." Of course it has a ceiling, just much higher in the fues curve.
KPAE via KBVY
Tod
Sat Oct 28, 2006 5:58 am
Quoting Beech19 (Reply 24):
So does the new 744F have a lining below the air ducting and control cables?
If so, I wonder why?
Tod
airbusA346
Sat Oct 28, 2006 6:09 am
Quoting Tod (Reply 25):
Yes, see the photo in Reply 17.
Tom.
junior1970
Sat Oct 28, 2006 6:18 am
When are they scheduled to be delivered ?
Thx
Tod
Sat Oct 28, 2006 6:55 am
Quoting AirbusA346 (Reply 26):
 footinmouth  Doh  banghead
I still wonder why?
Maybe slightly less area to heat?
Tod
NoWorries
Mon Oct 30, 2006 10:22 pm
Drifting off topic a bit -- if/when there are pax A380 conversions to freighter, will they strengthen both decks, or remove the upper and just strengthen the lower?
Mon Oct 30, 2006 10:26 pm
Quoting Junior1970 (Reply 27):
First one expected Nov. 2006. Will become PH-MPP
