vikinga346
AKL Planespotting Advice
Sun Oct 29, 2006 1:09 am
I'm going to be in Auckland in a couple weeks and want to do some planespotting. I don't have a car so I'm quite keen on finding a place around the airport that can be accessed by foot and isn't too far off the main road. Any ideas of where I can go to get some good pics and the best time of day is?
...you will walk the earth with your eyes turned skyward, for there you have been and there you shall return
aerorobnz
RE: AKL Planespotting Advice
Sun Oct 29, 2006 6:11 am
From the International terminal head off towards domestic following the blue and white line, but instead of turning right towards the terminal walk straight towards the roundabout, cross the road and head towards the red and white striped hanger. go past that hanger and turn right down the next road. You'll see the runway at the end of the road. At the end of the road there is Air NZ maintenance carpark, where you can watch planes landing and taxiing.
For approach shotyou can walk it, but a car is more important for that spot.
Flown to 120 Airports in 44 Countries on 73 Operators. Visited 55 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
noelg
Sun Oct 29, 2006 6:17 am
Head to the Air NZ domestic terminal, there is a great viewing deck overlooking the apron. From here you can see all arrivals/departures, and get good photos in the right conditions.
Also, outside the QF Domestic terminal, turn left out of the terminal building and there is a fence within a short walk that brings you out right underneath one of the gates - but that's only really any use for stuff pulling onto that gate!
Noel
PureKiwi
Sun Oct 29, 2006 10:41 am
If you want to do just spotting if you go to the departures area before security there is a viewing deck but I can't remember how to get to it. I think its called the skydeck and theres a few signs pointing to it.
nzrich
Sun Oct 29, 2006 11:20 am
As said before 2 viewing decks one in the Air NZ domestic terminal and one in the international..
Domestic up the stairs to the right of the check in area and its at the top on the left outside..
International entrance is from the top floor above departures ..stairs to that entrance is right at the end of that floor easy to find if any trouble just ask any staff member..
"Pride of the pacific"
Sun Oct 29, 2006 5:12 pm
The best viewing area is really the new multi storey carpark across the road from the domestic terminal. If its not cold, you could stay here for hours! There's an escalator from the construction area between the QF and NZ domestic terminals leading up to the carpark. Take the lift to the top level and it gives unmatched view over the entire airport (well excluding the control tower). No glass to shoot through. The entire runway is in view.
Photo © Colin Hunter
These show the carpark that I'm talking about:
Best times of day would be the rush before lunch when all the Asian ones arrive(1000 to 1200), after lunch when they all leave (1300 onwards) and the later afternoon ones with Emirates and the flights to America coming in. Quite a few heavies, but with a good zoom lens the 737s and A320s are still there for the viewing.
777ER
Crew
Sun Oct 29, 2006 5:27 pm
Quoting Noelg (Reply 2):
That spot gets ruined a little bit when a B737 or A320 is parked directly in front of it. You have to take shots throu the glass thou at both the Domestic and International viewing decks.
I once took a pic of a QF B733 from that location and I didn't need to use the zoom on the digital
MyAviation.net photo:
Photo © Jason Alpine
Quoting PureKiwi (Reply 3):
Thats in the International terminal. On the public deparutres level (level 1) over towards the food court, beside the exit to Passport control/MAF and infront of the AIAL help desk are some stairs and escalators that leads up to level 2. Up there you can look down on the International passengers heading towards the gates after passing throu the customs/maf. There are some windows with seating on that level that also looks out towards the tarmac. Beside those window facing seats are some more stairs, go up those stairs and bingo your on the main viewing deck
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
vikinga346
Sun Oct 29, 2006 5:46 pm
Thanks for the advice - hopefully i'll get some good shots when im in Auckland mid-November!
