scaredflyer21
Commuter Aircraft Batteries
Tue Oct 31, 2006 2:03 am
Let's say a B1900 is overnighting at an airport with no external power capabilities. I assume that, since there is no apu on the aircraft, that the plane is started with battery power? What happens if the aircraft requires multiple start attempts and there is not sufficient battery supply; what happens in this case?
Additionally, when boarding the aircraft is all of the power just from the batteries (e.g. reading lamps, etc.)? It just seems like these aux. items would drain the battery very fast.
Thanks for the replies!
Scaredflyer21
Ralgha
RE: Commuter Aircraft Batteries
Tue Oct 31, 2006 2:09 am
It would be very poor business planning to intentionally overnight an airplane with no APU at a station with no external power. I'm not familiar with the 1900, but you'll probably only get one shot to start an engine, and that doesn't even count the first flight checklists and boarding which may not leave enough juice for even one attempt.
EMBQA
Tue Oct 31, 2006 2:55 am
The batteries on board are more then capable of several start attempts. On the down side, with most engines if you don't get it started on the third attempt your down for maintenance and the engine must be inspected. Also, battery starts give you a much better start then ground power, but before you can start the second engine you must wait for the amps to draw down and that can take a few minutes.
Also, batteries only power the ESC BUS.. which only powers essential items. Reading lights are not one of them.
[Edited 2006-10-30 19:00:36]
PhilSquares
Tue Oct 31, 2006 3:02 am
Quoting EMBQA (Reply 2):
That's a new one on me! I've never heard or read anything like that, but I've only been flying for 30+ years......
Fly fast, live slow
scaredflyer21
Tue Oct 31, 2006 4:04 am
How typical is it for an aircraft to take 2+ attempts to start? Is it typical for this to occur on the first start of the day, or in colder weather?
Also, if a start attempt fails, must the crew wait for the prop to stop spinning or can they simply reengage the starter? What are the procedures for this?
Scaredflyer21
EMBQA
Tue Oct 31, 2006 4:12 am
Quoting Scaredflyer21 (Reply 4):
Very-very rare. I've had it happen twice in 12 years of running airplanes. Jet engines love cold weather and start much better in it.
You need to wait. The PGB by spinning is also driving the starter to turn, so you don't want to re-engauge it or you might break the shaft.
KELPkid
Tue Oct 31, 2006 4:43 am
Quoting EMBQA (Reply 5):
I've heard, off-handed, that the PWC PT6 is notoriously hard to start when there's a tail wind on the ramp...you have to be on your guard against a hot start. Of course, I have no practical operating experience with any turbine power plant  Wink So, refute as necessary.
EMBQA
Tue Oct 31, 2006 4:59 am
Quoting KELPkid (Reply 6):
Not so sure about that because the PT-6 is mounted backwards. The exhaust is in front, the intake in the rear. The air passes into the intake and is then routed to the rear of the engine where it enters the engine, then goes forward to the turbine. The PT-6 is also a free-flow turbine, so unless it was hurricane forced winds I doubt it would effect its starting.
aviopic
Tue Oct 31, 2006 5:38 am
Quoting Scaredflyer21 (Thread starter):
Even if there is an apu it does not always mean that it is capable of delivering enough power for an engine start.
On some they are just capable to supply other systems of enough power but an engine start is done on battery power anyway.
Don't know about the B1900 though.
For example this Connie which does feature an apu.
Photo © Willem Honders
Depends on A/C type.
Besides if there is no apu running and no external power availble you have no choice then to use battery power also for internal lights.
In which case the AC bus is fed by an inverter.
Like on this F27.
The truth lives in one’s mind, it doesn’t really exist
FlyHoss
Tue Oct 31, 2006 5:45 am
Quoting EMBQA (Reply 7):
Difficult to start in a tailwind, yes, if that tailwind was greater than 10 knots.
When I flew PT-6 powered aircraft, if the wind was more than 10 knots I'd consider parking into the wind and if the wind was more than 15 knots, I'd definitely park facing into the wind.
The PT-6 is a reverse flow engine as stated above. A tailwind can and will enter the engine through the exhaust stacks (at the forward part of the engine) and interfere with the start.
I've flown nearly 10,000 hours behind PT-6 power and still regard this engine family to be the best all around turboprop engine family.
A little bit louder now, a lil bit louder now...
KELPkid
Tue Oct 31, 2006 6:43 am
Quoting FlyHoss (Reply 9):
What would you do when the lineboy was trying to marshall you into the parking area in front of the FBO, pointed the "proper" way (for rolling out the red carpet for a VIP aircraft) Big grin Enquiring former lineboys would like to know  Smile
lowrider
Tue Oct 31, 2006 7:27 am
Quoting KELPkid (Reply 10):
What would you do when the lineboy was trying to marshall you into the parking area in front of the FBO, pointed the "proper" way (for rolling out the red carpet for a VIP aircraft) Enquiring former lineboys would like to know
Not to be rude, but if an FBO marshaller is giving me improper directions, I will go with what is right. I had one at an Atlantic actually git in my face and yell at me, but a quick chat with his manager settled him down nicely.
Not the case with the PT6. The starter only turns the gas generator section. There is not physical connection between the gas generator and the power turbine, which turns the prop gear box. This is why it is sometimes refered to as a free turbine engine. Theroretically, you could tie off the the prop, and just run the gas gen. Sometimes you will see a PT6 windmilling in one direction, only to slowly stop and reverse directions as the starter builds rpms.
I have never heard this with regards to the PT6. The only limiting factor I know of is the starter duty cycle, which will vary with application. Now if a turbine engine does not start after 3 attempts, the odds are good that something is broken.
Depends on how cold. You may get lower starting temps, you will also build rpms much slower. If you have a weak starter it may take two attempts just to get the min rpm to attempt a light off.
Battery or external DC power
Hope you packed a good book, you might be there a while.
These batteries are more robust than your typical Sears Diehards. That said, a smart crew will be very disciplined about battery usage if external power is not available. There are several lighting configurations which can be used for boarding in the 1900. They range from all the lights on to just 2 lights on.
Proud OOTSK member
scaredflyer21
Tue Oct 31, 2006 7:38 am
What regional aircraft actually have aux. power units? Does the E120? ATR?
Scaredflyer21
lowrider
Tue Oct 31, 2006 7:51 am
Quoting Scaredflyer21 (Reply 12):
All the RJ's, the E120s, Dornier 328 turboprops, and Dash 8s. The ATRs can use a prop brake system where they can run the right engine without turning the prop. A few Saab 340's have APUs, but I think they are all in corporate service. I am not sure about the Britsh Aerospace ATP.
Proud OOTSK member
EMBQA
Tue Oct 31, 2006 8:01 am
Quoting Lowrider (Reply 13):
Correct.. there are only 3 that have it and all are corporate.
Ralgha
Tue Oct 31, 2006 8:11 am
You are referring only to the 1900 right? Because basically that entire statement doesn't apply to an EMB 120.
APFPilot1985
Tue Oct 31, 2006 8:13 am
Quoting Lowrider (Reply 11):
While the directions may be improper from a wind point of view, shouldn't you consider that maybe the reason that they were pointing you in a direction was due to other concerns such as moving aircraft, trying to avoid blasting others or vehicles on the ramp. Wouldn't the more professional option be to follow the directions of the individual who can see the whole picture (unless it is something that is causing an immediate and obvious risk?) and then ask to be spun around before start?
Stand Up and Be Counted Visit Site Related to Voice your opinion
lowrider
Tue Oct 31, 2006 8:34 am
Quoting APFPilot1985 (Reply 16):
Depends. You think I am not aware of these other factors? I have seen so many blatantly wrong directions from FBO marshallers that I no longer trust them. If I don't think I can safely complete a maneuver, I will set the parking brake and, if necessary, shut down and get out to sort it out there. Most of the time, there is no guarantee that the FBO has a tug capable of moving my aircraft. Since I will bear the blame for damaging the aircraft or delaying a flight, I will decide if the spot the FBO has in mind is acceptable.
Proud OOTSK member
APFPilot1985
Tue Oct 31, 2006 8:38 am
Quoting Lowrider (Reply 17):
now that I agree with, however I have seen plenty of pilots just completely disregard what the marshaller is saying and then proceed to taxi into parked cars, block in other aircraft, once one even blasted a pax off steps and into a nasty fall.
aerowrench
Tue Oct 31, 2006 9:06 am
Mesa Airlines Dash 8 200's do not have APUs installed.
CRJonBeez
Tue Oct 31, 2006 9:08 am
understandable. how many cities have you stopped in that don't have a tug capable of moving your plane? i can't speak for all the other FBO facilities out there, but if for god knows what reason we have no tugs available, we WILL figure something out for you. in fact, a group of us had to actually push a citation 2 by hand a few years ago. all turbine powered a/c go into the wind as far as i'm concerned, unless otherwise requested enroute. however, there are times when it seems i can't win no matter what. we had a G4 (not a very friendly fortune 500 pilot) in quite a while ago. the pilot refused to leave the a/c in it's current spot. the a/c was parked in front of the FBO facing east, door pointed at the building. the light wind was out of the north, deflected by the building and hangar itself. we assured the pilot that if the winds changed, we would reposition the a/c and be sure they blew into the fans. that was not enough. we had to move the a/c to the far corner of the ramp, only to watch the pilot put the engine covers on for 3 hours of down time. aside from concerns of FOD, what's the purpose? weather was clear, winds calm. we had never seen the company in town, so there were no negative experiences.
however, there are many outside factors that several pilots have not been aware of. ramp design always comes to mind. we try our best to make sure you are parked on the ramp in a spot where you or your passengers aren't required to walk through rain. how about other a/c enroute that will need to be moved, but you take up too much space in the spot you're trying to get to. unless you monitor every conversation held through the FBO on the phones, the unicom, and on the ground, there will always be an outside factor you aren't aware of. like i said before, we do our damn best to make sure all jets face the wind, but when you start collecting multiple gulfstreams on the ramp, things can get a bit hairy.
just because you have sharp eyes on the ramp does not mean everybody else does. it's good to know you take proper care when on the ground, but not every pilot is as alert as you seem to be. i understand you must think that everybody on the ground doesn't know what they're doing for safety purposes, but we must treat the a/c coming and going the same.
lowrider
Tue Oct 31, 2006 9:26 am
Quoting CRJonBeez (Reply 20):
As it is somewhat of an oddball a/c, most do not. I worry less about the wind as I can usually find some combination of ground power or downwind engine being masked by the fuselage, and more about being able to get out of the ramp. We try our best to communicate our needs to FBOs ahead of time, but unfortunately things don't always work so smoothly.
Proud OOTSK member
474218
Quoting Aviopic (Reply 8):
Where is the APU on a Constellation?
APFPilot1985
Tue Oct 31, 2006 9:32 am
Quoting Lowrider (Reply 21):
care to share the type?
lowrider
Tue Oct 31, 2006 9:38 am
Quoting APFPilot1985 (Reply 23):
No offense, but no. My employer would become readily apparent, and I am not always the most PC.
Proud OOTSK member
FlyHoss
Tue Oct 31, 2006 9:49 am
Good question. In my General Aviation days (various models of King Airs) I don't recall ever being faced with this situation. In my Regional Airline days, I recall notifying the station (via the company radio frequency) of our intent to park into the wind. The station was always able to accommodate our plan.
charlienorth
Tue Oct 31, 2006 9:50 am
Quoting Lowrider (Reply 24):
It would be a difficult towbar to find!
When I started a PT6 with a tailwind I would let it spin up a little higher before I fed in the fuel and fire,don't know if it it hepled much.
Scaredflyer21
Scaredflyer21[/quote]
AMR Eagle actually came out with plans for that in 1994,needless to say it didn't happen,the prop brake system was marginal at best.
Work hard fly right..don't understand it
CRJonBeez
Tue Oct 31, 2006 2:20 pm
i suppose in that situation, i can understand. of all the biz jets i have seen myself, the only one we didn't have a towbar for was the BBJ. that's certainly not to say that all FBO's are equipped as well as we are though.
it seems to me that you would probably play it safe, but if you haven't thought about it, i certainly recommend calling in advance on the unicom frequency to advise the line guys of your aircraft type.
APFPilot1985
Tue Oct 31, 2006 2:50 pm
Quoting CRJonBeez (Reply 27):
all you need is a big bad lektro
CRJonBeez
Tue Oct 31, 2006 3:46 pm
Quoting APFPilot1985 (Reply 28):
ante up the money for it! we're only an FBO. we've got a tug capable of pushing it on hand, we just don't have the bar for it. those things are EXPENSIVE!!!
aviopic
Tue Oct 31, 2006 5:54 pm
Quoting 474218 (Reply 22):
We have a little 2 cylinder engine in the back of the fuselage because this 749 Connie is infact a militairy C121 which as far as I know all had an APU onboard.
