boac707
Belly Landing At FLL
Thu Nov 02, 2006 2:29 am
www.sun-sentinel.com/news/local/brow...58343.story?coll=sfla-news-broward
I searched and could not find anything...so here you go
smokey classics to the end of time
KFLLCFII
RE: Belly Landing At FLL
Thu Nov 02, 2006 4:05 am
Looks like N232TN:
http://flightaware.com/live/flight/N232TN
A/C type matches, arrival time matches.
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
flyinryan99
Thu Nov 02, 2006 5:13 am
Thanks Bry! There was a picture of it on one of the FLL news stations (10 I think). Wasn't ours  Smile
miamix707
Thu Nov 02, 2006 5:24 am
so which main runway is in use now at FLL? The only other runway barely big enough for big jets is the diagonal..
John
Thu Nov 02, 2006 12:27 pm
Runway 13 has been in use all day....it's 6931 feet long. Suitable enough for most of the traffic in and out of FLL.
irobertson
Thu Nov 02, 2006 4:05 pm
Apparently no one has taken a picture of this bird yet on A.net, as far as my own searching could tell.
ksonderling
Thu Nov 02, 2006 10:05 pm
All traffic was on 13 until about 1 or 2 yesterday, I think the last time that runway was used was this summer when a Gulfstream (CO) Beech 1900 landed with gear problems on 9.
gh123
Thu Nov 02, 2006 10:38 pm
WMUPilot
I just did a turn down to FLL the day after and we did indeed land on 13. Apparently when the plane landed he damaged the runway, as there where construction vehicles tearing up part of the runway.
JetBlue - Bringing humanity back to air travel
gh123
Thu Nov 02, 2006 10:39 pm
Sinlock
Thu Nov 02, 2006 11:16 pm
Quoting Ksonderling (Reply 6):
I'm not sure what makes you say that, They were still using 13 at 5:45 when I left the airport.
cessnapilot172
Fri Nov 03, 2006 12:13 am
***Not everyone was using 13 yesterday, several smaller twins and turboprops were able to LAHS of 31/13 on 9R. I followed a Shorts in late yesterday afternoon in my Seminole after holding for a little while south off the airport. Thanks for the pic's and extra info.
ksonderling
Fri Nov 03, 2006 1:30 am
When I was on 595 at 3 I swear I saw them coming in normally, but I wasn't at the airport so I will take your timing on this one
KFLLCFII
Fri Nov 03, 2006 1:34 am
FLL Press Release:
November 1, 2006
FLL Incident, Update #3, Wednesday November 1, 2006
As of 12 noon today here is the most accurate and recent information we have regarding the early morning incident at Ft. Lauderdale-Hollywood International Airport on Runway 9-Left
At 2:31 this morning an inbound charter plane from Mexico City landed on runway 9L, (our main runway at FLL). The aircraft was found with the landing gear not extended.
There was no prior alert to FLL regarding an incoming aircraft with any type of trouble; therefore emergency crews were not dispatched in advance.
There have been no reported injuries as a result of the incident. There were 2 crew members and 10 passengers.
The aircraft, a Hawker 700 was removed from the runway earlier this morning.
There was a significant amount of fuel spilled on runway 9L.
Specialized crews have been working to remove the spilled fuel. Other teams have been standing by and are now working on repairing a 30' by 75' section of the runway with new asphalt. We're told it takes about 90 minutes to "mill" the area and another 90 minutes to lay new asphalt. Then there is a cooling period necessary for the asphalt to harden. Weather permitting we hope to have the 9-Left runway back in full operation early this evening.
In the meantime, FLL is using runway 13/31 for air carrier operations. Because runway 13/31 is shorter than 9L, some long haul flights might be required to make a fuel stop enroute to their destination.
There have been some flight delays as a result of today's incident.
When 9-L is back on line, we will send another advisory
Gregory Meyer
Public Information Officer
Broward County Aviation Dept.
100 Aviation Boulevard
Ft. Lauderdale, Florida 33315
http://www.broward.org/airport/press_news_release.htm
