gpeso8
How Do I Get Load Factors!?!?!
Thu Nov 02, 2006 7:30 am
How does one find load factors for a flight, and can I look at the stats over a month/year?
Thanks a ton!
SJUSXM
RE: How Do I Get Load Factors!?!?!
Thu Nov 02, 2006 8:18 am
As far as i know load factors are only available to those who have access to an airlines reservation system. (SABRE, APPOLO...) I may be wrong but im pretty sure.
AT7, ER3, ER4, ER5, CR7, E70, E75, F100, M82, M83, 722, 732, 738, 752, 762, 763, AB6, 320, 321, 772, 77W
kwcarolma
Thu Nov 02, 2006 8:21 am
You probably need to know some insiders, perfectly from revenue department of the airlines you're looking at.
Cadet57
Thu Nov 02, 2006 8:26 am
Just go ask the Westjet CEO!
 duck
SJCRRPAX
Thu Nov 02, 2006 8:30 am
If I was running an airline, I would want to keep my load factors secret. Why let the competetion in on a good thing, they can do their own market research.
FDXmech
Thu Nov 02, 2006 8:31 am
You'd like the old Peoplexpress mx logbook. It would list each flight and pax count.
gpeso8
Thu Nov 02, 2006 9:05 am
I'm doing a research report for my High School on the domestic traffic in the West Coast of the U.S.... (California, Nevada, Arizona)....is there any way i can find the number of passengers whom flight between these areas!
Thanks a ton,
Gpeso
777STL
Thu Nov 02, 2006 10:16 am
Quoting SJCRRPAX (Reply 4):
That's exactly what they do, it's proprietary information for the most part. Unless you're an employee or a travel agent or something, it's gonna prove pretty difficult.
PHX based
iowaman
Thu Nov 02, 2006 10:26 am
Quoting Gpeso8 (Reply 6):
www.faremeasure.com, and the DOT has more updated numbers on their website.
Quoting 777STL (Reply 7):
You can get a general idea from the seat maps on the airlines' websites, although they aren't the most accurate.
KingAir200
Thu Nov 02, 2006 10:37 am
Many airlines post month to date and daily load factors in their employee news letters and you can check flight loads on internal systems. If you happen to know an airline employee, they can probably hook you up. Other than that, they are hard to find.
777STL
Thu Nov 02, 2006 10:51 am
Quoting Iowaman (Reply 8):
Actually, ask any frequent flyer, those are awful for determining load factors.
PHX based
spyderz
Thu Nov 02, 2006 12:03 pm
Load factors can easily be obtained for historical data (i.e. last year) since the load factor is simply RPM's divided by ASM's, which are readily available data. Month-by-month and route-by-route is about as detailed of information that is available. DoT provides great sources of data for domestic and US international routes. Additionally, databases are available that can provide this for air carrier information wordwide. Contrary to some people's beliefs, all airlines have such databases that enabled them to compare load factors per month on various city pairs. Of course in the airline industry, the load factor plays a small role in an airline's profitability - yield is the most important thing. (RASM - CASM)
spyderz
Thu Nov 02, 2006 12:04 pm
Load factors can easily be obtained for historical data (i.e. last year) since the load factor is simply RPM's divided by ASM's, which are readily available data. Month-by-month and route-by-route is about as detailed of information that is available. DoT provides great sources of data for domestic and US international routes. Additionally, databases are available that can provide this for air carrier information wordwide. If you have any particular routes that you are interested in, I'd be happy to provide you with load factors as I have access to such a databse.
Busrep319
Thu Nov 02, 2006 12:39 pm
Go to the airlines website, or various financial websites (yahoo finance is a good one) and take a look at the 10-Q financial filings. It takes a bit of sifting, but midway through the reporting section is last quarter's load factors.
Never, ever moon a werewolf!
bkkair
Thu Nov 02, 2006 1:34 pm
Try this site from the Bureau of Transportation Statistics of the US Govt. It's not that easy but you can download spreadsheets and then do your best to interpret the data:
Go to the reports for Air Carrier Statistics (Domestic and Foreign).
http://www.transtats.bts.gov/databas...1&Mode_Desc=Aviation&Subject_ID2=0
If there is an easier way, I hope someone will let me know too!
Good luck.
knope2001
Thu Nov 02, 2006 4:55 pm
Watch out when using Faremeasure.com. See this link for details:
http://www.airliners.net/discussions...general_aviation/read.main/3048697
For the same data, only in a more recent and accurate format, go to this site:
http://ostpxweb.dot.gov/aviation/X-5...le_files/consumerairfarereport.htm
Table 6 is the same data as FareMeasure. If you care to compare FareMeasure to these quarterly tables you'll see the data on FareMeasure is several quarters old. Also, take a look at more than one quarter to get an idea of the seasonality of travel. That's something FareMeasure doesn't take into account or disclose to the user at all.
Finally...and I hope I can explain this clearly enough if this is new to you, the datasources talked about in this thread give two related but *different* pieces of information on routes.
The DoT stats shown in the consumer air fare report (which is the same stuff as FareMeasure, only newer and better-defined) talks about the TOTAL MARKET for travel between two cities. This information is quarter-by-quarter. Let's use San Diego-Seattle as an example to illustrate what this data is and what makes it distinctive. This datasource will tell you how many people flew each day where SAN was their origin and SEA was their final destination, and vice versa. Doesn't matter if they bought a ticket for an Alaska nonstop, or if they took a Southwest flight stopping in Oakland, or bought a Southwest ticket that required changing planes in Sacramento, or a USAirways ticket that required changing planes in Phoenix, or whatever. So what this datasource is trying to capture is the demand for air travel between two cities. (It has nothing to do with telling you how many people are onboard airplanes or what load factor is.)
The other widely-used data source mentioned in this thread are the T100's. They are at this link:
http://www.transtats.bts.gov/Tables....riers&DB_Short_Name=Air%20Carriers
The T100's are all about flight segments and reported data on them like the cargo carried, passengers carried, aircraft type, etc. It is month by month. This is the best datasource to find load factor (how full aircraft were) because you can pull seats and passengers and do the math. This data is under the link T-100 Domestic Segment (US Carriers). Let's go back to the San Diego-Seattle example. This data will tell you, for a given month, how many people were onboard planes the took off from San Diego and landed nonstop in Seattle. That is NOT the same number as the total people whose total trip started in San Diego and ended in Seattle. Not everybody starting out in SAN and ending in SEA flew on nonstop flights for various reasons (cheaper fare, nonstops sold out, preferred a different flight time, airline brand preference, etc.) The flip side of the coin is not everybody sitting onboard a SAN-SEA nonstop was actually flying just from San Diedo to Seattle. They could have been flying SAN-SEA-Anchorage, or SAN-SEA-Spokane, or SAN-SEA-Tokyo, etc. Or maybe even flying from Mexico to Seattle via SAN.
So it depends on what you're looking for, whether the T100 or the DoT quarterly stats really have what you are looking for.
A final word on using the T100's. The files can easily get too large to work with, so you're best off choosing one month at a time and one state at a time. I prefer to open then with Excel, and that can only handle about 65,000 records. If you try to pull a whole year, or data for all the states in one file, the file may get too big. And finally, there is usually about a four month lag on the data, so for example you will get an empty file if you ask for OSeptember 2006 right now. I think July 2006 is the most recent out there at this time.
Why are these two different?
knope2001
Fri Nov 03, 2006 12:29 am
Quoting Knope2001 (Reply 15):
Please ignore this last comment in the above message. It was a note to myself to remember to talk about why the two are different as I was composing the message, but I forgot to delete it.
It is something that should have been deleted -- not a question to the group.
On a related note, if anyone knows how to modify or edit your own item already posted, I'd love to know what happened to that function. In the past I've been able to go back and clean up a mistake like this but can't find that function anymore.
Poitin
Fri Nov 03, 2006 12:51 am
Quoting Knope2001 (Reply 16):
You can edit once posted, but only for 30 minutes.
Now so, have ye time fer a pint?
