nijltje
Delta CDG-CVG From 777 To 767?
Thu Nov 02, 2006 10:57 pm
Hello, I booked my flight to CVG and just find out that it's not a 777 anymore but a 767? Why?
Maybe I'm wrong but wasn't air France also flying with their own metal on CVG?
I hope some Delta expert can help me...
ARGinLON
RE: Delta CDG-CVG From 777 To 767?
Thu Nov 02, 2006 11:04 pm
If I'm not wrong all 772 are gone from the European Markets. Only 763/4s from now on.
pnqiad
Thu Nov 02, 2006 11:40 pm
IIRC, DL moved 777 to their new non-stop JFK-BOM run and 767 to its former slot.
DAL767400ER
Thu Nov 02, 2006 11:49 pm
Quoting Nijltje (Thread starter):
Because it together with another 777 is needed for ATL-JFK-BOM. In exchange, CVG-CDG and another former 777 route will get the 763ERs previously used for ATL-CDG-BOM, which is being dropped.
AF only operates the route on a seasonal basis, which to AF means putting out a PR that they are dropping CVG, only to put out another PR 4 months later that they will return to CVG, though it looks like actually this time AF actually is gone for good from CVG.
Quoting ARGinLON (Reply 1):
Correct.
Cubsrule
Fri Nov 03, 2006 3:03 am
Quoting DAL767400ER (Reply 3):
Why?
DAL767400ER
Fri Nov 03, 2006 4:21 am
Quoting Cubsrule (Reply 4):
Why?
It's been mentioned here: AF Summer 2007 - 744 To ATL, 6th JFK And Others (by HB-IWC Oct 29 2006 in Civil Aviation)
Reason's probably the reduction of feed with the flight cuts at CVG, and/or feeding more pax through ATL or JFK.
goldorak
Fri Nov 03, 2006 6:58 am
Exactly. They're constantly changing plans for CVG service. May be they're gone for true but I hope they'll change their mind and send again a nice A343 there next summer.
AF used to serve the route year-round, but since about 2 or 3 years, they serve it with their own metal only during the spring/summer season. Otherwise, they code-share year-round on the other flight operated by DL. AF has used quite different A/C on this route since they started it : B747-200, A332, A343
worldtraveler
Fri Nov 03, 2006 11:17 am
ATLFRA remains a 777 for the winter.
DL also doesn't need as much feed into CDG since its India flights don't go through CDG anymore.
B4REAL
Fri Nov 03, 2006 11:23 am
Quoting WorldTraveler (Reply 7):
CDG is DL's best connection point for 2nd tier (that DL doesn't already server) and 3rd tier markets within Europe as well as many African and Middle East locales.
CDG is very important to DL for connections and feed!!!!!
But yes, the MAA route is finished and the BOM is direct from JFK with origin in ATL.
zsx81
Fri Nov 03, 2006 1:00 pm
Those beasts will be working much harder with the new..
DXB
BOM
ICN
and the existing
NRT
FRA
routes!
DAL767400ER
Fri Nov 03, 2006 7:11 pm
Quoting B4real (Reply 8):
CDG no doubt is still important, but not nearly as important as it used to be. Aside from the dropped India flights, DL's expansion of nonstop transatlantic flights that overfly the CDG hub also means a reduced need for feed into CDG. And it's not just Europe, but also Africa (ACC, DKR, JNB) as well as the Middle East with TLV and DXB. CDG will remain a main interest for Delta, but the more nonstop flights, the less pax Delta has to feed through CDG.
Plus, add the fact that DL and KL also this year started codesharing, which obviously means quite a few pax connect through AMS now instead of CDG (I know I will on my next US visit).
nijltje
Fri Nov 03, 2006 8:15 pm
Mmmm so what is the best to fly BRU-CVG? I really want to fly 340 or 777... Is an european carrier even flying to CVG directly?
goldorak
Sun Nov 05, 2006 8:33 am
Quoting Nijltje (Reply 11):
No, AF was the only EU carrier to fly there
Alitalia744
Sun Nov 05, 2006 8:58 am
Quoting Zsx81 (Reply 9):
DXB
BOM
ICN
and the existing
NRT
FRA
routes!
Add TLV take away FRA for next year.
Some see lines, others see between the lines.
