WINGS
Airbus A310- A Tribute By Wings
Fri Nov 03, 2006 3:16 am
The Airbus A310 is a medium to long-range widebody twin airliner, manufactured by Airbus Industries (Airbus SAS). The A310 was the second model to be introduced by Airbus after the A300, of which 255 frames were delivered.
Launched in July 1978 with orders from both Lufthansa and Swissair. The A310 was referred to as the A300B10 in the early design stage. The A310 is 13 frames shorter than the A300B4, but shares the same 5.64m fuselage diameter.
The aircraft is of mainly high strength aluminium alloy construction with some sections of carbon fibre or glass fibre re-inforced plastic composites.
The wing is structurally similar to that of the A300, but aerodynamically it is a completely new design. It has a higher aspect ratio, but less span and less area. The A310 also featured a smaller vertical fin.
The A310 competed head-on with the Boeing 767. It's major strenght vs the B767 was mainly due to the A310 wider fuselage which allowed for 8 abreast in a typical seating configuration vs the narrower B767 which could only accommodate 7 abreast seating. It's wider fuselage would also play a major role in terms of cargo capabilities. It could carry two industry standard LD3 cargo containers side by side in the underfloor cargo compartment, the same containers used on the DC10/MD11, 747 and the L1011 Tristar.
The assembly of the A310 took place on the same production line as the A300 in Toulouse. The first A310 was the 162nd Airbus off the production line. The A310 made its maiden flight in April 1982 powered by Pratt & Whitney JT9D engines. The A310-200 entered service with Swissair and Lufthansa a year later. The last A310 to role out of the line would be in June 1998, when Uzbequistan Airways too the last example.
COCKPIT AND INTERIOR:
The A310 has an advanced digital flight deck built by EADS France (formerly Aerospatiale Matra) and accommodating the pilot and co-pilot. The flight deck displays include an aircraft monitoring system, flight guidance, navigation and engine, management and monitoring. The flight deck also houses the electronic flight instrument system (EFIS) and a flight data recorder. The aircraft's digital automatic flight control system contains a flight control computer, a thrust control computer and a duplicated augmentation computer. The flight control computer provides autopilot, flight director and speed reference functions.
The Airbus A310 cabin can accommodate 6,7,8 or 9 abreast seating in a double aisle layout. There are four passenger doors at the port and starboard side to the front and rear of the cabin. A typical 2 class seating arrangement accommodates 220 passengers.
CHARACTERISTICS:
* (Airbus A310-200)
Flight Crew: 2
Passengers: 220 (Two class configuration)
Empty weight: 83,100 kg (80,142 kg ) *
MTOW: 164,000 kg (141,974 kg)*
Fuel capacity: 75,470 litres (55,200 litres)*
Operating range: 9,600 km (6,800 km)*
Cruising speed:[b] Mach 0.80
[b]Maximum speed:[b] Mach 0.83
[b]Ceiling:[b] 12,500 m
[b]Length
46.66 m
Wingspan 43.9 m
Tail height 15.8 m
Powerplants 2 X PW4156 or 2 X CF6-80C2 (2 x PWJT9D or 2 X CF6-80A3)*
Only one variant of the A310 was built, although it did have several versions.
A310-200:
The standard version is the A310-200. It was available with General Electric CF6-80A3 and Pratt & Whitney JT9D engines.
A310-200C:
One A310-200C (Convertible) was built for Dutch charter airline Martinair. This version permitted easy removal of the seat so that cargo can be placed on the main deck. The A310-300 was also offered with convertible option.
A310-300:
The Airbus A310-300 is a long-range version with higher weights and increased fuel capacity. First flown in July 1985, the increased range was provided by additional centre and horizontal stabilizer (trim-tank) fuel tanks. This model also introduced wingtip fences to improve aerodynamic efficiency, a feature that has since been retrofitted to some -200s. It was offered with the PW400 or the GE CF6-80C2 power plant.
A310-200/300F
No production freighters of the A310 were produced. Although some cargo carriers have opted to convert some passenger models into freighters. The first A310-200F freighter was delivered to launch customer Federal Express in 1994.
A310MRTT
The A310 is currently being offered as a Multi Role Tanker Transport (MRTT).The aircraft are manufactured and modified by EADS/Airbus. The conversion involves the following,
*Installation of two AAR pods under each wing
*Four additional fuel tanks (extra 28,000 kg)---giving total capacity of almost 78,000 kg.
*Fuel Operator Station (FOS) to control fuel offload, cameras etc, military radios and exterior lighting. For MRTT, a remote surveillance of approaching/refueling process with a night-vision capable video system had to be developed. This system (developed by a small company called VIDAIR) allows operation both with visible light and also near-infrared radiation.
*Reinforced wings and aircraft floor and some minor cockpit modifications.
ACCIDENTS:
To this present date the Airbus A310 has experienced six hull loss, with a total of 518 fatalities.
31 July 1992; Thai International A310-300; near Katmandu, Nepal: The aircraft had a controlled flight into terrain about 22.5 miles (36 km) from the airport after apparently using an incorrect procedure for a missed approach. All 14 crew and 99 passengers were killed.
22 March 1994; Russian International Airways A310; near Novokuznetsk, Russia: Lost control and crashed after the captain had allowed at least one child to manipulate the flight controls. All 12 crew and 63 passengers were killed
31 March 1995; Tarom Romanian Airlines A310; near Balotesti, Romania: Aircraft crashed shortly after taking off in a snowstorm. All 10 crew and 50 passengers were killed.
11 December 1998; Thai Airways International A310-200; near Surat Thani, Thailand: During its third landing attempt, the aircraft crashed just outside the Surat Thani airport. The aircraft was on a domestic flight from Bangkok to Surat Thani. There were 90 fatalities among the 132 passengers and 11 fatalities among the 14 crew members.
30 January 2000; Kenya Airways A310-300; near Abidjan, Ivory Coast: The aircraft crashed into the Atlantic Ocean shortly after taking off at night for a flight from Abidjan to Lagos, Nigeria. All 11 crew members and 158 of the 168 passengers were killed.
9 July 2006; Sibir Airlines A310-300; Irkutsk, Russia: The aircraft was on a scheduled flight from Moscow to Irkutsk. Weather at Irkutsk included a low overcast, rain, and thunderstorms in the area. The aircraft landed on the runway, but was unable to stop on the runway. After departing the runway, the aircraft collided with a concrete structure, broke up, and caught fire. Five of the eight crew members, and 119 of the 195 passengers were killed.
INTERESTING FACTS:
-The A310 has the widest cabin for its length of any airplane ever manufactured by Airbus. The A310 is only 8 feet longer than an A321 but much chubbier
-A Rolls-Royce powered A310 was proposed although this version was never built.
-An A310-100 was a proposed short-range version, which was never built.
To this present date 226 A310's are still in active service. Mainly with cargo carriers. Now that passenger service of this plane is reaching the end, I'm confident that many will find a home as freighters.
SOURCES:
http://www.airbus.com
http://www.airsafe.com
http://widebodyaircraft.nl/a310.
http://en.wikipedia.org/wiki/Airbus_A310
http://www.aerospace-technology.com/projects/a310/
http://www.aerospace-technology.com/projects/a310-200f/
I hope that everyone has enjoyed this small tribute to the Airbus A310.  Smile
Wings
Aviation Is A Passion.
mk777
RE: Airbus A310- A Tribute By Wings
Fri Nov 03, 2006 3:29 am
Nice pics.
What airlines besides TK, AI AND PK use the A310?
come fly with me
kiramakora
Fri Nov 03, 2006 3:37 am
Quoting Mk777 (Reply 1):
AFAIR: MU, OK, FDX, TP, BG, TS, RJ, LN, HY, OM, KU, AH, MB, IR, S7, W5, A7.
[Edited 2006-11-02 19:39:36]
keesje
Fri Nov 03, 2006 3:42 am
Thnx Wings, another great tribute!
One of my best flying experiences was on a A310 in the late eighties, doing touch & goes and aborted landings /take-offs for hours sitting in the seat behind the captain in the roomy A10 cockpit over a dark Amsterdam Schiphol Area.
I remember a hard landing and the captain could immediately check on the multi function display if it was within limits & push the throttles for another powerful A310 take off. I was very impressed by the glass cockpit & smooth control.
A310 of the airline I will leave (voluntary) tomorrow after many good years.  worried . KLM Used them on high density / middle east routes. I flew them to Porto/Lissabon also.
Photo © Pedro Aragão
Alibo5NGN
Fri Nov 03, 2006 3:43 am
Thanks for the tribute. A fine plane.
The Nigerian Government (Military Dictators at the time) bought 4 new A310-222 for then State owned Nigeria Airways in much the same way that the Angolan Government is currently buying B777's and B737's for State owned TAAG. Due to corruption, mismanagement and acts of gross incompetence by Nigeria Airways management (Political appointees offcourse), the planes all met premature end of service life.
On time payment of maintenance and airport fees and dues was the main problem. The planes were 5N-AUG which became a bar in Belgium, 5N-AUF(?) caught fire at Ilorin Airport Nigeria during a training flight and 5NAUE/5N-AUH which are rotting away at LOS.
It takes knowledge to make a career. It takes wisdom to live a life.
Stitch
Fri Nov 03, 2006 3:44 am
Really sharp-looking bird in that TAP livery.
A very capable plane, indeed. I am guessing her lack of range relative to the 767ER family is what kept her to "only" 255 sales, as she certainly had the edge in passenger and payload capacity and very advanced avionics.
stylo777
Fri Nov 03, 2006 3:46 am
I really love this bird! It is for me one of these few "revolutionary" aircrafts ever built.
gabo787
Fri Nov 03, 2006 3:48 am
Quoting Kiramakora (Reply 2):
Don't forget AR  Wink
kiramakora
Fri Nov 03, 2006 3:52 am
Quoting Stylo777 (Reply 6):
I would not term the 310 "revolutionary." However, I would call the 310 a versatile, under-rated aircraft that got the job done. Some of my favourite earlier memories were flying the 313 on AI's BOM-NBO segment. I remember flying over Sudan and the little promotional items AI used to have - postcards, 313 stickers, 313 fact sheets, etc. I remember making several cockpit visits and a pilot telling me that the 313 could glide without engines and all other random things.
scbriml
Still plenty of these flying pax service in the Middle East and Asia. DXB is a bit of an A310 magnet.
Photo © Steve Brimley
[Edited 2006-11-02 19:56:18]
Magyarorszag
Fri Nov 03, 2006 3:54 am
Quoting Alibo5NGN (Reply 4):
The one that became a bar was 5N-AUG, and the aircraft that caught fire at Ilorin was 5N-ANR, a DC-10-30 that overran the runway on landing January 10th, 1987.
Cheers.
desediez
Fri Nov 03, 2006 3:55 am
TS, HF, Uzbekistan Airways, OK, IR, not sure about AR, S7, Biman Bangladesh, AI, RJ, ASA African Safari, SATA Acores, Air Plus Comet, not sure about Mongolian, Mahan Air.......
WINGS
Fri Nov 03, 2006 4:00 am
Here is the list of the current A310 operators.
# Aerolineas Argentinas
# Switzerland African Safari Airways
# Algeria Air Algerie
# India Air India
# Kazakhstan Air Kokshetau
# Macau Air Macau
# Spain Air Madrid
# Spain Air Plus Comet
# Canada Air Transat
# Afghanistan Ariana Afghan Airlines
# Bangladesh Biman Bangladesh Airlines
# People's Republic of China China Eastern Airlines
# Czech Republic CSA Czech Airlines
# Uganda Eagle Aviation
# United States FedEx
# Germany Hapagfly
# Iran Iran Air
# Jordan Jordan Aviation
# Kuwait Kuwait Airways
# Libya Libyan Arab Airlines
# Iran Mahan Air
# Mongolia MIAT Mongolian Airlines
# Turkey MNG Airlines
# Pakistan Pakistan International Airlines
# Qatar Qatar Airways
# Jordan Royal Jordanian Airlines
# Russia S7 Airlines
# Portugal SATA International
# France Star Airlines
# Sudan Sudan Airways
# Portugal TAP Portugal
# Turkey Turkish Airlines
# Belgium TNT Airways
# Uzbekistan Uzbekistan Airlines
# Portugal White
# Yemen Yemenia
Wings
leelaw
Fri Nov 03, 2006 4:09 am
Quoting Keesje (Reply 3):
I wish you well in your future endeavors. Hopefully your departure isn't prompted by personal difficulties, and you will continue to work in this industry that you obviously have a strong passion for, or you've decided to embark on another career which excites you even more.  thumbsup
Lex Ancilla Justitiae
jacobin777
Fri Nov 03, 2006 7:17 am
Here's mine.. Smile
"Up the Irons!"
viasa
Fri Nov 03, 2006 7:32 am
Quoting WINGS (Reply 12):
Here is the exact list:
http://www.ch-aviation.ch/aircraft.p...ch&operator=AND&ac_ac=A310&start=0
The hottest news about the A310 are:
- Air Bagan has it's first aircraft now in service (full colors).
- Mahan Air has give back one A310 to it's operator (Saga Airlines)
- Air Atlanta's A310 is now back from Air Algerié and stored
- TAP Portugal has the former Royal Jordanian A310 now in service.
OldAeroGuy
Fri Nov 03, 2006 7:58 am
Wings, what is your criteria for a tribute?
With the exception of the 727, it seems to be out of production with fewer than 300 frames manufactured.
Lumberton
Fri Nov 03, 2006 8:35 am
Let me add my compliments to you, Wings, for your fine efforts WRT these "tribute" threads. I have come to thoroughly enjoy them.
I'm curious as to why FEDEX opted for a freighter version, when the larger capacity A300-600F is/was available? (I'm sure this was discussed to death on threads past, but please accept my apologies, and I would be grateful if someone could provide the rationale).
"When all is said and done, more will be said than done".
LAXintl
Fri Nov 03, 2006 8:51 am
As some one that has lots of experience with the A310 type from a management perspective the type offered fantastic versatility being able to economically serve both dense short 1 hour sectors and medium ~8hr sectors very successfully while also having room for cargo.
Definately type ahead of its time when it arrived on the scene during the early 80s offering airlines something between the then typical B727s and DC-10 size aircraft.
Along with the 767, the A310 was also a pioneer in Atlantic ETOPS operations changing the face of city-pair markets which prior were restricted to much larger widebodies.
A310, Thank you for your services
Leskova
Fri Nov 03, 2006 11:52 am
Thanks for this tribute - while the A310, along with the A300, are my least favorite Airbus planes, they certainly played a big role as the foundation of the company.
Incidentally, I was on the A310 that's pictured at the top of this thread (TAP's CS-TEX), arriving just where it's landing in that photo (FNC) 6 days after that picture was made...
Sorry to hear that, but I guess that since you're leaving voluntarily you're heading towards another job. In any case, good luck.
Smile - it confuses people!
YVRLTN
Fri Nov 03, 2006 3:35 pm
There are also some military operators too - apart from the Luftwaffe as pictured (with 7), we have 5 here operated by the Canadian Forces as the CC150 Polaris, Belgium have 2, Spain have 2 and the French L'Armee De L'Air have 3. There may be others too of course.
Photo © Tibor Mester
Follow me on twitter for YVR movements @vernonYVR
WINGS
Fri Nov 03, 2006 5:26 pm
Quoting OldAeroGuy (Reply 16):
Hi OldAeroGuy,
Well to be sincere I don't really have a definite criteria, apart for the fact that all tributes are for out of production airplanes. I believe that just because an airplane has not been a run away sucess in terms of sales, it does not make it less worth of such a Tribute. All of the planes which I have made tributes to have in some way or form molded aviation as we know now.
I have also tried to make tributes to various airplanes manufactures. So far I have done so for Tupolev (TU-144) Lockheed (L1011) Boeing (727) Dassault (Mercure), Bristol (Britannia) and now Airbus with the (A310).
Wings
teva
Fri Nov 03, 2006 7:22 pm
Quoting Lumberton (Reply 17):
That's pretty simple. At that time, FX started to receive its first A300s from Toulouse.The first idea was to use them to replace 727. But at the time they started to join the fleet, it appeared they were too big for some markets. And with the growth in the mid 90s, they created their own market. Intial orders (including the options ) were around 100 frames. It would take too long to receive them and match the current model. Then FX started to look at the 310 conversion: smaller, can be delivered faster, can use the same crew, cheaper.
So, instead of converting all the options, they choose the 310.
And if you look at the current Airbus fleet at FX, it is close to the 100 initial target.
Teva
Ecoute les orgues, Elles jouent pour toi...C'est le requiem pour un con
MCOflyer
Fri Nov 03, 2006 8:37 pm
Wings,
Great post. I've never flown on one, but have seen them land and can tell you it makes me wonder if Airbus should've offered an extended version. ( besides the 300)
Who flies the MP 200C example?
MCOflyer
ImperialEagle
Fri Nov 03, 2006 9:09 pm
Back in the 1990's I had the great pleasure of flying on some of DL's and JM's 310's.
Wonderful memories of a very powerful aircraft----you never felt like lack of power would EVER be a problem.
I had not experienced such exciting take-offs since the last 720-B I flew on!
One day , sitting in the crew lounge here at ATL, I had a conversation with some 310 cockpit crew. I was not surprised to hear they rarely ever used any rudder with the aircraft as the differential thrust available was so powerful.
I'd love to experience another take-off on a 310 again.
Like a ride on the Space Shuttle!
Yeeee-hawwww!
Thanks WINGS!
"If everything seems under control, you're just not going fast enough!"
vivekman2006
Fri Nov 03, 2006 9:42 pm
Nice write-up and some lovely pics. I have had the opportunity to fly an A310 on Air India and I was amazed at how wide the cabin was considering it looks small from outside.
distanthorizon
Fri Nov 03, 2006 9:46 pm
Thanks Wings.
A great post, indeed. For a great aircraft.
I hope I can still fly on it for many, many time do come.
DH
Nelson SE
mxp
Fri Nov 03, 2006 10:13 pm
Very interesting and well done.
I will try the A310 for the first time next time with IR from CGN-THR for the airevents tour
After this tribute i have more data of the aircraft i will fly on.
Alberto
madairdrie
Fri Nov 03, 2006 10:27 pm
Always love reading your tributes wings thanks again.
Kenneth
vsflyer747400
Fri Nov 03, 2006 10:30 pm
I thought EK still had some, 1 in passenger service and some in cargo?
My 1st ever flight on airbus equipment was an AF A310 LHR/CDG - seems like such a long time ago, only other A310 flights were LHR/FRA with LH. Is a nice plane to be on.
Excellent tribute - keep up the good work.
Being on: (in no order) VS BA AA EK CX MH DL EI BD KL HV NW RC LH AF DA TG QF US FR LX AC SK AZ PG SQ UA PA
CF188A
Fri Nov 03, 2006 10:51 pm
is it possible we will see the A310/ A300 reign in Cargo operations in the next 20-30 years? Seeing as how there are so flippin many of them... the 310 is about the closest one will get to the demanding 757. Possible? They are still great aircraft from a fuel/cargo standpoint. If airbus was selling them until this year ... and orders were still being fulfilled, obviously it cannot be that bad right?
Dream as if you'll live forever. Live as if you'll die tomorrow~ RIP ... LJFM
jonty
Sat Nov 04, 2006 12:51 am
really enjoy the tributes. i think you should do one for the A300 as well!
WINGS
Sat Nov 04, 2006 1:03 am
Thank you all for the positive feedback. It sure makes the effort even more worth while.  Smile
Quoting VSFLYER747400 (Reply 29):
I believe that Emirates has 1 x A310-300 Pax and 3x A310-300F. It is my understanding that Emirates only pax A313 will be converted into the freighter model.
Wings
GDB
Sat Nov 04, 2006 4:16 am
Another job of work, combined with a labour of love.
Great tribute, good picture choices and new insight into a vital 2nd step for Airbus.
mirrodie
Sat Nov 04, 2006 7:47 am
WINGS,
One of the things that drew me to this website was the exchange of ideas and the potential for learning. That said, I really appreciate and love this thread!
I only developed an interest in this a/c in June 2006 when I noted how unique the underbelly of the plane is. Up until that point, I only liked the 330 and 340s.
Thanks for sharing the knowledge and I look forward to these threads!
Too bad AA didnt pick a few up instead of the 300  Smile
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
atnight
Sat Nov 04, 2006 9:43 am
I still remember when Ecuatoriana got their two brand new A310s... they were great planes and Ecuatoriana had a great color scheme.... too bad the airline no longer exists and those birds went somewhere else... which makes me wonder, does anyone have information on these particular birds? which airline did they end up? how long did Ecuatoriana kept them and where are they now... thanks.... and great post WINGS!
B707 B727 B733/5/7/8/9 B742/4 B752/3 B763/4 B772 A310 A318/319/320 A332 A343 MD80 DC9/10 CRJ200 ERJ145 ERJ-170 Be1900 Da
WINGS
Sat Nov 04, 2006 5:23 pm
Quoting Atnight (Reply 35):
Hi Atnight,
Well if you take a look at the Airliners.net photo database you will find several photos of Ecuatoriana's A313.
I will try to find out any info in regards to these birds.
Again I would like to thank everyone for the positive feedback.
Wings
FlySSC
Sat Nov 04, 2006 6:30 pm
One aircraft (TF-ELR) was on a short term lease from Islandflug from Dec.2005 to May 2006.
Photo © Joel Vogt
Some A310 are/were also regularly leased briefly from partner airline Air Transat, but French Star Airlines never operated the A310 by itself.
Quoting YVRLTN (Reply 20):
They are used with "République Française" title, for V.I.P transport but also for troops.
2 of them were bought second hand from Royal Jordanian (F-RADA & F-RADB), the third one comes from THY Turkish Airlines but was initially delivered to Wardair Canada in 1988 !).
Photo © Joel Vogt
2travel2know
Sun Nov 05, 2006 2:49 am
JM gave up their A310 for the A340, just a move to gain prestige, IMHO.
Twice daily Jamaica - London and once daily Jamaica - MAN with A310 would have been better than that current A340 service.
I don't work for COPA Airlines!
atnight
Sun Nov 05, 2006 11:20 pm
Quoting WINGS (Reply 36):
Thanks WINGS for the pics and the topic... if you do find out what happened to the birds, please let me know and thanks in advance for whatever info you can provide.......
MEA-707
Mon Nov 06, 2006 12:01 am
Quoting Atnight (Reply 39):
HC-BRA (574) is now UK-31001 with Uzbekistan Airways
HC-BRB (576) also went to Uzbekistan Airways as UK-31002
Photo © YK
Photo © Andrei Pechenkin
PP-SFH (552) was a 2nd hand airframe which was ex F-GKTD from TEA and Sudan Airways, went to Etihad and is now N817FD with FedEx. FedEx now has 61 second hand A-310s and will pick up many more in the next few years.
source: www.airlinerlist.com
Photo © D. Miguel Ruiz
Photo © Michel Gilliand
Photo © Johan Ljungdahl
Photo © Carlos Moreira
nobody has ever died from hard work, but why take the risk?
Magyarorszag
Mon Nov 06, 2006 12:07 am
Here it is. Three links to the Ecuatoriana A310-300s. The first two were originally intended for PA, but the airline was obviously in such a financial shape that the order was cancelled.
http://www.planespotters.net/Production_List/Airbus/A310/574.html
http://www.planespotters.net/Production_List/Airbus/A310/576.html
http://www.planespotters.net/Production_List/Airbus/A310/552.html
Cheers.
WINGS
Mon Nov 06, 2006 6:22 pm
Hi Atnight, You more than welcome. In regards to the ex Ecuatoriana's A313 destiny, MEA-707 did a pretty good job in finding out.  Smile
Wings
atnight
Mon Nov 06, 2006 11:44 pm
Quoting WINGS (Reply 42):
Thanks MEA-707.... like WINGS said, great job! Thank you for the info which is greatly appreciated.... I am glad to see that those birds are flying somewhere....I remember being in Ecuador at the time they were delivered, they were great looking birds!.... Thanks again!
