8herveg
British Airways @ Heathrow T3 Why Not Also At T2?
Fri Nov 03, 2006 9:52 pm
British Airways operate the Heathrow - Miami route out of Terminal 3, so they have a presence in the majority of the airport. But if this is the case, why do they not operate any flights out of Terminal 2?
[Edited 2006-11-03 13:58:37]
steve6666
RE: British Airways @ Heathrow T3 Why Not Also At T2?
Fri Nov 03, 2006 10:08 pm
Why on earth would they want to use T2 as well?
Miami was moved to T3 because there were many transfer passengers from Europe missing the connection due to having to get to T4, and presumably lack of space at T1 for a 744.
A306, A318, A319, A320, A321, A332, A333, A343, A346, A388, B722, B732, B733, B734, B735, B73G, B738, B742, B744, B752, B753, B762, B763, B764, B772, B773, B77W, B787-8, BAe-146, Cessna Something, DC-10, E175, E195, ERJ145, MD-11, MD-80, PA Something
jfk777
Fri Nov 03, 2006 10:27 pm
Being from Florida I have never understood the orphan that are the BA Miami flights. Years ago before T4 all BA 747 flights were through T3, except Miami who was then a Terminal 1. Why can't a flight to some random part of the world BA has limited operations to go from T3, like Barbados where most passenger are from London.
star_world
Fri Nov 03, 2006 10:42 pm
Quoting Jfk777 (Reply 2):
Because Barbados is operated from LGW, not LHR...
BA operate a flight from T3 because it gives them voting rights on how that terminal is used and allows them to be an influence in any changes that are made in the future. They most likely retain this because VS are based in T3.
dstc47
Fri Nov 03, 2006 11:18 pm
In the dim and distant past at LHR, it was broadly
Terminal One : European and British Isles flights, by British European Airways
(EI and a very few other UK carriers also)
Terminal Two: European Services, in the main, by European Carriers.
Terminal Three: Intercontinental flights by BOAC, amongst others.
Terminal Four: Did not exist then.
Thus BA (BEA & BOAC) were at One and Three and not Two.
BCAL
Sat Nov 04, 2006 12:50 am
Quoting Dstc47 (Reply 4):
But before Terminal 1 opened, BEA used Terminal Two, so BA (BEA & BOAC) has been in all terminals at some point.
 bigthumbsup
MOL on SRB's latest attack at BA: "It's like a little Chihuahua barking at a dying Labrador. Nobody cares."
trekster
Sat Nov 04, 2006 2:08 am
I also heard it was because of VS and we can keep an eye on them lol
Where does the time go???
jfk777
Sat Nov 04, 2006 3:17 am
While for years T1 was BA Europe, T2 was other European airlines & T3 was all the intercontinental airlines. When T4 opened in 1987 that changed everything, BA's 747 flights were mostly from T4 but KLM was there too. SAA & El Al moved to T1 as to be away from the other african airlines and because of the pesky Palestinian problem. SAS moved to T3 since it had a huge number of flights to Scandanavia from T2. Now even BA has 747 flights at T1 & more European flights from T4, why I don't know and can't figure out why. LJHR is just one big mess sometimes.
steve6666
Sat Nov 04, 2006 3:35 am
Quoting Jfk777 (Reply 7):
It's to make transfers easier. The long hauls from T1 have more than the average connecting passengers from within Europe and ditto the short hauls going into T4
planesarecool
Sat Nov 04, 2006 3:43 am
Quoting Steve6666 (Reply 1):
No, because BA would only want to connect people on their own flights, so unless you expect people to connect from Miami through LHR to Miami it wouldn't be that. I think what you are thinking of is when the LAX, SFO, JNB, NRT and HKG flights were moved to T1 in return for various European flights that went from T1 to T4. This was done to increase ease on connecting flights. Although the Miami flights are currently the only flights from T3, before 9/11, when BA had a LGW-MIA flight and only one daily LHR-MIA flight, BA also operated their LHR-CPT flight from T3
Though it wasn't that long ago that BA flew from T2...although it was only a codeshare with Crossair  Smile
Leezyjet
Sat Nov 04, 2006 6:02 am
Quoting Star_world (Reply 3):
 checkmark
They also get to retain gate slots there too, and now the new Terminal plans are known, once all the swapping around happens, they will also be using T3 for a few more flights as it will be the nearest terminal to T5 making connections shorter.
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
trintocan
Tue Nov 07, 2006 8:06 am
Not so long ago BA flew services to LOS from T3 as well. It was said that part of the reason for those services being there was to ensure the adequate lounge facilities for the many front-end passengers on both those services along with the need to keep a foothold in the terminal used by its largest home-grown rival.
Indeed, the only T2 service BA had in recent years was the codeshared flight to BSL.
TrinToCan.
Hop to it, fly for life!
SapphireLHR
Tue Nov 07, 2006 5:43 pm
Quoting Leezyjet (Reply 10):
Correct, and once T5 is operational and with T3 is occupied by One World Alliance Partners, I have been reliably informed, those Miami slots will be utilised by Qantas.
jfk777
Tue Nov 07, 2006 10:30 pm
I find it hard to believe the LAX & SFO flights are at T1. How different can their connection tarffic be then the rest of BA's USA routes ?
commavia
Tue Nov 07, 2006 10:32 pm
Quoting Jfk777 (Reply 13):
Believe it. They are, and both have been for months.
cornish
Tue Nov 07, 2006 11:04 pm
And also Hong Kong, Jo'burg and Tokyo of the long haul routes IIRC.
But yes as mentioned by one or two posters above - the reason for the T3 MIA service is predominantly to do with voting rights at the key terminal for the majority of their long haul rivals.
Just when I thought I could see light at the end of the tunnel, it was some B*****d with a torch bringing me more work
vv701
Wed Nov 08, 2006 12:13 am
It can be very different when they fill what would, on selected days of the week, be otherwise empty economy class seats with 'special' low price offers made through selected European travel agents or through local direct advertising. The advantage of this type of operation is that it can enable the airline to offer more premium class seats on selected routes while filling economy class seats and not diluting its economy class revenue on every day of the week. It can also vary the number of seats sold this way literally from day to day thus maximising revenue and profit.
An extreme example of this practice is the annual BA 'Dreamflight' to MCO for seriously ill and handicapped children. This year the (20th) Dreamflight flew LHR-MCO on 15 October. BA filled the return flight that departed MCO just after midnight on 16 October with one week excursion return flights offered locally in the Orlando area. All the passengers booking at the low, low fares had to return to the US on the aircraft that went to pick up the children just over a week later. In that way everyone gained and no one was disappointed.
