LGWspeedbird
PTV's On BA's LGW/LHR 777 Fleet
Wed Nov 08, 2006 2:53 am
Hi All
Just wanted to know wether the screen size of the PTV is smaller on the triple 7's in Club World compared to the 747 fleet, and also is the PTV's different to the LHR fleet than the LGW fleet?
Any help would be greatly appreciated.
LGWspeedbird
edited to add club world
[Edited 2006-11-07 19:08:49]
upcoming flights LHR-LAX-HNL-SFO-LHR
MEACEDAR
RE: PTV's On BA's LGW/LHR 777 Fleet
Wed Nov 08, 2006 3:02 am
I think they are both the same size.
Richard28
Wed Nov 08, 2006 3:24 am
There is a mixture of Rockwell Collins and Marconi IFE on the 777.
I do not know the screen sizes, but IIRC the Marconi system (I think on GE powered 777's) has a much smaller screen.
Vasu
Wed Nov 08, 2006 3:29 am
Am I right in thinking the LGW 777s are the older ones, with the smaller PTVs?
Or have they all been updated?
anstar
Wed Nov 08, 2006 3:30 am
Not sure about LGW, but I travelled to AUH recently in F and we had the small style PTV's. (about2.5")
manny
Wed Nov 08, 2006 3:45 am
Quoting ANstar (Reply 4):
Did it come with a magnifying glass ?
anstar
Wed Nov 08, 2006 3:52 am
Quoting Manny (Reply 5):
Unfortunately not. I decided to watch a movie from the Library... which to my surprise came out on a portable DVD player!! (Rather than the DV tape that usually goes in the seat!)
fbgdavidson
Wed Nov 08, 2006 4:21 am
From Flyertalk.com
B-777-200IGW w/Marconi IFE (small screen):
G-ZZZA/B/C; G-RAES; G-VIIA/B/C/D/E/F/G/H/*/J/K/L/M/N/S.
B-777-200 w/Rockwell Collins systems:
G-YMMA/B/C/D/E/F/G/H/I/J/K/L/M/N/O/P; G-VIIO/P/R/T/U/V/W/X/Y.
Rockwell Collins system on 747 and some 777s:
MyAviation.net photo:
Photo © Fraser Davidson
Marconi System (If in First you'll also get a personal DVD player and library)
MEACEDAR
Wed Nov 08, 2006 12:08 pm
Yum......I am getting hungry already.
wrighbrothers
Thu Nov 09, 2006 7:56 am
Quoting LGWspeedbird (Thread starter):
Hi All
The screens are the same size aslong as they are the same make  Smile
Quoting Vasu (Reply 3):
There is a mix of Rockwell and Marconi at LGW, LHR is all Rockwell. Although this will no dobut be changed to all Rockwell when the LGW 777's go in for their IFE refits to AVOD.
wrighbrothers
yay, first post in 15 days !
fbgdavidson
Thu Nov 09, 2006 8:04 am
Quoting Wrighbrothers (Reply 9):
Not for sure. That post above with the Marconi was on an ex-LHR flight. It is the luck of the draw with the 777s.
According to a BA insider on Flyertalk apparently the GMIS system will not be upgraded. Only 25 of the 43 777s are getting an AVOD upgrade, so you'll end up with AVOD or a substandard 12 channel system  thumbsdown
http://www.flyertalk.com/forum/showthread.php?t=525853
wrighbrothers
Fri Nov 10, 2006 7:17 am
Quoting Fbgdavidson (Reply 10):
I see, I'm probably worng then.
Hmmm, sounds odd. Since they habe both GE and RR power aircrafts with the old IFE, it'd make scence to atleast one whole fleet, doesn't add up...
Wrightbrothers
edina
Fri Nov 10, 2006 7:48 am
The 3 LGW based ex-AML 777s have a non standard and non uprgradeable 12 channel Rockwell Collins system with Rockwell size screens.
Worked on - Caravelle Mercure A300 A320 F27 SD3-60 BAe146 747-100/200/400 DC10-30 767 777 737-400 757 A319 A321
planefixer
Fri Nov 10, 2006 8:06 am
The 3 ex AML aircraft have all been upgraded. When they had the Dusk mod, they also got the Rockwell TES system. 18 channels of movies and games in Club World and WT+.
There is not a "non-upgradeable" Rockwell Collins IFE system.
There are now 4 LGW based 777's with 3 classes, flying the routes that the AML aircraft used to fly. G-VIIO,P,R,T.
Vasu
Quoting Edina (Reply 12):
ex-AML
What does that mean?
planefixer
Fri Nov 10, 2006 8:08 am
AML stood for Airline Management Limited
It was basically a "paper" airline that operated certain flights on behalf of BA, they had BA flight crew, Flying Colours (then JMC) cabin crew, and the aircraft tech log was in the name of AML.
This lasted for a few years in the late 1990's Ceased operations in Nov 1998
[Edited 2006-11-10 00:17:26]
Richard28
Fri Nov 10, 2006 8:18 am
Hi All
are you sure? the Marconi screens look smaller to me:
Marconi:
Photo © Brady Anderson
Rockwell Collins:
Photo © Steve Hall
Vasu
Fri Nov 10, 2006 8:21 am
Quoting Planefixer (Reply 15):
Aha, yes! Weren't they the ones that operated 777s in 3-4-3 config?
planefixer
Fri Nov 10, 2006 8:26 am
Had them crammed in down the back. Rod Eddington made a point of bringing those routes back "in house" and making the config the same as standard 777's
I only ever flew them in Club, and only once since having the flat beds fitted.
edina
Sat Nov 11, 2006 2:05 am
Rockwell screens definitely larger than the GMIS ones.
AlanUK
Sat Nov 11, 2006 3:13 am
Quoting Edina (Reply 19):
Yes, definitely.
No! More like 6''! Which isn't a lot for a PVT, but I guess it depends how you use it...  flamed
wrighbrothers
Mon Nov 13, 2006 12:49 am
Quoting Richard28 (Reply 16):
That's because it is (by an inch or 2). What i meant, was that there was no difference in size between LHR Rockwell screens, and the LGW Rockwell screens.
Wasn't it flying colours, then it became JMC, and they were then taken over by someone else ?
Wrightbrothers
[Edited 2006-11-12 16:51:14]
captaink
Mon Nov 13, 2006 1:19 am
On what routes were the AML aircraft flown?
There is something special about planes....
wrighbrothers
Mon Nov 13, 2006 1:43 am
Quoting Captaink (Reply 22):
They flew (at some point) to
KIN
TAB
TPA
SJU
MBJ
CUN
SJO
Havana
Puerto Plata (Dominican Republic)
Hope that answers your question  Smile
Here's some other info: when BA stopped using Airline Management Limeted (AML) they operated 3 BA 777's (G-VIIO, G-VIIP and G-VIIR) in a 2 class 28J/355M configuration from LGW.
Before that, they operated 1 (later 3) BA DC-10's (G-BHDH,G-BHDI and G-NIUK) in a 32J/279M layout from LGW between March 1997/8 and March 1999
Wrightbrothers
