UAEflyer
Converting 777 From Pax To Cargo
Thu Nov 09, 2006 1:30 pm
Now with the new program from boeing that convert the 747 from passenger configuration to a cargo. I was wondering is it possible to convert a passenger 777-200(ER) or 777-300 to a cargo aircraft? The 777 is in the market for more than a decade now, is it still new to be converted to a cargo?
If yes why it didn't happen yet? which airline would do it first?
ORDagent
RE: Converting 777 From Pax To Cargo
Thu Nov 09, 2006 1:54 pm
Any aircraft with enough engineering can be converted to cargo. It may well happen one day but not in the near term. Boeing can't push out enough 777 passenger aircraft to meet demand. The majority of the owners are very happy with the 777. I've recently flown on older UA 777s. They are a bit tatty but the rebranding will take care of that. That's just about the only age related issue out there yet.
Tod
Fri Nov 10, 2006 3:21 am
The value of existing 777 is too high to make a good business model for pax to freighter conversion. As soon as that changes a number of reconfig comanies will be all over it.
Tod
beech19
Fri Nov 10, 2006 3:33 am
You won't see see pax to cargo conversions until they have actually started producing 777F's. Once that is in place and they are delivering them i bet we will start seeing some of the origional 772's being converted within a few years. My guess is on 2010-2012 (15-17 years old for the oldest 772's).
Additionally... when the 767 line finally closes (3-10 years from now depending on USAF tanker order is my guess) we will see about the same time the 787F program will also be launched.
KPAE via KBVY
Tod
Fri Nov 10, 2006 5:35 am
Quoting Beech19 (Reply 3):
Why?
Tod
beech19
Fri Nov 10, 2006 6:00 am
Quoting Tod (Reply 4):
Because i said so...  Wink j/k
They would be potentially squashing early 777F orders by offering a 777BCF so quickly. They never have offered a BCF prior to a factory Freighter, why would they start now? Until they have completely got the bugs worked out of a 777F and are producing them you wouldn't want to put the extra energy into a BCF when you are already doing it for the real thing.
There WILL be a 777BCF, there will be a 787BCF and there will be a 748BCF... its just a matter of time, not if but when.
It will probably be only a matter of time after the 737-700C is out in the market before they start offereing 737BCF's.
KPAE via KBVY
lotsamiles
Fri Nov 10, 2006 6:19 am
Keep in mind that only Boeing makes the "BCF" (likely with the 777F door and systems). Others can enter this market to product 777SF's with their own designs.
The timing is driven by market forces of supply / demand / aircraft values and supplier interest as Tod points out.
Lotsamiles
DfwRevolution
Fri Nov 10, 2006 6:29 am
Quoting Beech19 (Reply 5):
Keep in mind that the 777F will carry much more cargo than any converted 777.
Consider the following max structural payloads:
772ER - 126,000 lbs (57,000 kg)
772LR - 141,000 lbs (64,000 kg)
777F - 229,000 lbs (104,000 kg)  weightlifter   wideeyed
If your business is general cargo, the 777F has significantly more value than a converted 772ER. The primary market for 772ER conversion will be parcel carriers who don't need the incredible payload density of the 777F.
Cargo density has been on an upward trend for some time, so I doubt availability of conversion will greatly mitigate the 777F.
Quoting UAEflyer (Thread starter):
The 772ER is the most likely candidate for freighter conversion. The 772ER should be an excellent MD-11 replacement, as well as a complement to the 777F.
The 772A and 773A would have a fairly low payload density (ratio between aircraft volume and the mass the aircraft can lift), but might find a market in the parcel sector. More likely, these fringe variants will either end up in desert or flying charters like todays DC-10 and L-1011.
The only problem I know of with a 777 conversion are the floor beams of the passenger 777. IIRC, the CFRP floor beams aren't strong enough to support a roller floor and container cargo, so any conversion would need to include floor reinforcement of some kind.
WestWing
Fri Nov 10, 2006 6:31 am
I was told that the 777 passenger main deck floor is not designed to take cargo loads -- so the main deck floor would have to be completely redesigned and retrofitted for a 777 passenger to cargo conversion.
[EDIT: DfwRevolution made the same comment while I was typing  Smile ]
[Edited 2006-11-09 22:36:19]
The best time to plant a tree is 40 years ago. The second best time is today.
beech19
Fri Nov 10, 2006 6:34 am
Quoting Lotsamiles (Reply 6):
Yes... hence why i was specifically talking about a BCF.
Regarding the 737 freighters there is lots of 734's being converted to SF's, which is obviously not a BCF, but i beleive that in time will come.
Here at KPAE, Goodrich does a lot of aircraft conversions. Most recently they converted a Ethiopian 752 to a 752PF.
Photo © Nick Goodwin
KPAE via KBVY
Lemurs
Fri Nov 10, 2006 6:59 am
Quoting DfwRevolution (Reply 7):
What determines those max structural payloads, Dfw? I find it hard to grasp why the gap between the LR and the F is so immense. Is it based on interior equipment, the floor loading for the pax floor, etc? That is truly an astonishing difference for what is essentially the same airplane. The gap between the 744BCF and and 744F aren't that big, are they?
There are 10 kinds of people in the world; those who understand binary, and those that don't.
lotsamiles
Fri Nov 10, 2006 7:17 am
This really is not any different than most other widebody conversions as they typically involve replacing all of the floorbeams (747, A300). I know that many MD11's were built with freighter beams so that aircraft is an exception.
Lotsamiles
Tod
Fri Nov 10, 2006 7:20 am
With Boeing holding the stress data very closely and the other problems relating to modifying the CFRP floor beams, this may prove to be the biggest challenge for the aftermarket companies.
Hey Beech19, how many of those 757 have been completed? Is Bill Wagner still involved?
Tod
[Edited 2006-11-09 23:22:42]
beech19
Fri Nov 10, 2006 7:25 am
Good point... and the floor beams would be an issue.
KPAE via KBVY
