kaitak744
What Is HKG Tarmac Made Out Of?
Tue Nov 21, 2006 12:10 pm
It seems the the aircraft ramp is neither cement nor asphalt and HKG. Seems like some sort of brick. What exactly is this? And is it used anywhere else in the world?
picture:
http://www1.airliners.net/discussion...ral_aviation/read.main/3104699/#21
Carpethead
RE: What Is HKG Tarmac Made Out Of?
Tue Nov 21, 2006 12:18 pm
Probably concrete bricks but this sure must increase costs of laying it all down. Interesting indeed.
BreninTW
Tue Nov 21, 2006 12:21 pm
Those are indeed concrete paving bricks. They're more expensive to install, but I think cheaper to maintain. For example, if there's a problem beneath them (leaky pipe etc), you can pull up the paving bricks, fix the problem, and replace the paving bricks -- you don't have to pay to re-lay a substantial portion of the surface like you would with asphalt.
spacecadet
Tue Nov 21, 2006 1:17 pm
Jeeze, they look just like the conrete pavers you can buy for your driveway/patio/pathways at Home Depot! Same shape and everything. Can't possibly be the same, can they?
kwjlee
Tue Nov 21, 2006 1:53 pm
I work in HKG and no one can tell me why using concrete bricks for the apron. My guess is that it is for the ease of maintenance as Brenintw has pointed out, and also for the flexibility to add stuffs like pipes and cables running under the apron.
Here is a pic showing when the A380 visit HKG last saturday, they actually had to run extra power supply to the aircraft. The temporay power supply is the little tower underneath the airbridge, conned off, then run two yellow cables to the nose gear, along with the existing orange ones from the airbridge. The temp power supply tower was put there in one night, I guess the apron being built with concrete bricks helped.
http://i116.photobucket.com/albums/o19/kwjlee/PICT0151.jpg
FL370
Tue Nov 21, 2006 2:21 pm
yup i have similar bricks on my driveway, there expensive, and like brenintw said, cheaper to maintain, and there strong as hellL!!!!
fl370
ha763
Tue Nov 21, 2006 3:41 pm
Since HKG is built on reclaimed land, my guess would be that the use of those pavers reduce the maintenance costs and time if and when the land starts to settle and creates low spots.
SapphireLHR
Tue Nov 21, 2006 3:57 pm
Many stands at LHR, all the T1 Domestics for example are laid with brick pavers. They are excellent when maintainance is required as they are taken up and relaid very quickly with minimum stand closure time. No cement...no drying time.....
