A342
Airbus - What To Do With A300/310 Line
Wed Nov 22, 2006 5:41 am
The final A300 will be delivered in 2007. The fate of the assembly line - or its buildings - is uncertain yet.
So here's my question: How can Airbus put it to the best possible use ? The buildings seem too small to open another A330/340 line, and I doubt yet another A32S line is needed.
Might be the demolition of it be the best solution, so other facilities can be built there ? I know there was talk about this so the A350 line can be built, but I think this is not that urgent.
Exceptions confirm the rule.
NYC777
RE: Airbus - What To Do With A300/310 Line
Wed Nov 22, 2006 5:45 am
No brainer---A350 line. Nough said!
That which does not kill me makes me stronger.
N328KF
Wed Nov 22, 2006 5:46 am
Quoting A342 (Thread starter):
Seems to me that would be a perfect spot to put the A350. Besides which, do you honestly think that Airbus would let building size be an issue? When Boeing started the 777 project, do you think they let building size getin the way? Not a chance.
[Edited 2006-11-21 21:54:32]
NYC777
Wed Nov 22, 2006 5:54 am
Au contraire, I think it just as urgent as fixing the A380 production problems!! They need this plane and they need it out the hangar door as soon as possible.
A342
Wed Nov 22, 2006 6:06 am
Quoting NYC777 (Reply 3):
I did not suggest they did not need it. You are right, they need it, but first you have to design the aircraft, then you can start building the assembly line.
Maybe I should rephrase my question: How can they put it to temporary use ?
Stitch
Wed Nov 22, 2006 6:21 am
I imagine first France and Germany have to determine who gets final assembly rights to the A350XWB and who gets major sub-assembly rights.
If, for example, the A350XWB is assembled in Hamburg, then the A300/A310 building might work well as a "fuselage barrel integration" site.
Also, if all A380 sub-assembly works moves to TLS to join A380 final assembly, then perhaps that building could be used in support of that role.
BrettFromCLT
Wed Nov 22, 2006 6:25 am
Quoting A342 (Reply 4):
Big honkin car wash? Roller skating rink?  duck
gbfra
Wed Nov 22, 2006 6:45 am
The current state of discussions at EADS/Airbus is:
The assembly of the A380 will remain as it is.
The A350 will be assembled at Toulouse.
The assembly of the A330 could be moved to Hamburg as a small compensation for the A350, but I'm not sure that they will agree on this.
gbfra
The fundamental things apply as time goes by
acidradio
Crew
Wed Nov 22, 2006 3:00 pm
Do like we do with every other old building here in the states - make it into a condo and a Starbucks  Wink
Ich haben zwei Platzspielen und ein Microphone
DfwRevolution
Wed Nov 22, 2006 3:07 pm
IIRC, the A300 "line" is essentially a single assembly bay not much larger than a widebody hanger. I.E. too small for final assembly of any model they expect to deliver more than 1 unit/month.
The initial plan was to run the A350 down the same A330/A340 line, but changes in tooling have likely nixed those plans. If a new assembly bay is needed, then they will consider all the options and do what's best.
A.net has some very wise industry insiders, but I will be very surprised if there's anyone who can give you the answer you're looking for. This is a rather obscure (although somewhat interesting) topic, so it will likely remain confined to speculation. Hope that helps!
jonathan-l
Wed Nov 22, 2006 5:18 pm
Quoting NYC777 (Reply 1):
A very bold statement if you have actually seen the A300 line and its surroundings...
Quoting DfwRevolution (Reply 9):
The A300-A310 line was built by basically installing a roof over the two outside walls of the Caravelle and Concorde lines (which are today used for the ATR and A320).
As you say, it has nothing in common with the A380 and A330-A340 hangars: the aircraft are assembled, tested and finished in a line and all aircraft are moved at the same time. The A320 line is very similar.
The A330-A340 is fully modular: aircraft are put in multi-purpose bays and not physically moved once the main parts have been joined. The A380 line is similar.
scouseflyer
Wed Nov 22, 2006 5:49 pm
Quoting Jonathan-l (Reply 10):
Interesting so the "older" lines have more in common with the way that cars are built (and the T7)?
airbusA346
Wed Nov 22, 2006 6:48 pm
Does anybody have any pictures of the Airbus lines.
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
N328KF
Thu Nov 23, 2006 2:41 am
This makes me wonder what would occur if Finmeccanica succeeded in their bid for the 50% of ATR they don't own. Would EADS allow them to use that space, or would production have to be moved to an Alenia facility?
Qatara340
Thu Nov 23, 2006 3:38 am
What about making it an Aviation Museum? Surely it will look good as a museum.
لا اله الا الله محمد رسول الله
A342
Thu Nov 23, 2006 5:36 am
Thanks for all the replies !
Quoting QatarA340 (Reply 14):
France already has the big Le Bourget museum, so I think, unfortunately, that this historic spot of European aircraft production will not become a museum.
Gr8Circle
Thu Nov 23, 2006 5:41 am
Store unsold A380's.....  duck
Francoflier
Thu Nov 23, 2006 5:47 am
Paint hangar?
Inside Completion center for A330/340/350 or even A380?
Does a 380 even fit in there?
Develop some kind of third party Airbus maintenance contractor?
Indoor swimming pool for employees?
BAE146QT
Thu Nov 23, 2006 5:52 am
Leave it fallow. Distract the taxpayers, (who will in part have paid for it) by flying the A380 past them a few times. Wait for it to be forgotten then propose the site is used for the 2016 Olympics. Drink some Champagne.
Job done.
Todos mis dominós son totalmente pegajosos
