AV8AJET
ISP Is A Mess! No Glideslope No Planes!
Sat Dec 02, 2006 7:01 am
Trying to fly outta ISP isn't going to happen. Southwest, DL, US flights cancelled due to low ceilings and the glideslope out of service on Runway 24, the LOC only approach doesn't get the airplanes low enough. Now the winds and and rain are coming so inbounds later tonight could be in trouble also. If your flying out of ISP on DEC 2nd you might check it out before you go to bed! Goodluck!
"To fly or not to fly there is no question!"
OPNLguy
RE: ISP Is A Mess! No Glideslope No Planes!
Sat Dec 02, 2006 7:07 am
For what it's worth, the forecast shows the ceilings and precip gone after 10pm local time, so if that holds up, flights should be able to get in. Another forecast comes up in about 90 minutes from now...
FM0300 27020G35KT P6SM BKN025
FM0600 29015G25KT P6SM SCT030=
bravogolf
Sat Dec 02, 2006 7:25 am
Why is the glideslope out? How long has it been out?
flyingbronco05
Sat Dec 02, 2006 7:45 am
Quoting BravoGolf (Reply 2):
KISP LONG ISLAND MAC ARTHUR
11/014 - LOVES TWO STAR MEA ALB - ATHOS 8,000 EXCEPT FOR AIRCRAFT EQUIPPED WITH SUITABLE RNAV SYSTEM WITH GPS DUE TO ALB VOR RESTRICTION. WIE UNTIL UFN
10/050 - 24 ILS GP OTS 25 OCT 11:00 UNTIL 15 DEC 19:30
06/001 - 15L/33R CLSD OVR 12500 WIE UNTIL UFN
Never Trust Your Fuel Gauge
B6JFKH81
Sat Dec 02, 2006 7:52 am
Does ISP still have a curfew for 121 ops?
OPNLguy
Sat Dec 02, 2006 8:05 am
Quoting B6JFKH81 (Reply 4):
Not a blanket one, per se...
ARPT RSTRD 2300-0630 DAILY FOR ACFT INDICATING OVER 85DB APCH & 72DB TKOF EXCEPT EMERG/MERCY FLTS.
Tower closes, and you can land with it closed. The only major item is getting the ARFF folks to hang around, and they can only do so for so long...
