captainsimon
Emergency Exit Question
Sun Dec 03, 2006 5:03 am
Whilst on a recent flight on a B738, I was wondering if the over wing emergency exit doors could just be opened during flight or are they locked until the captain activates them for passenger emergency use if the aircraft gets into trouble.
If they are able to be opened during flight this could be catastrophic if some idiot plays with them.
Sorry if this is a silly question.
7474ever
RE: Emergency Exit Question
Sun Dec 03, 2006 5:18 am
Of course not. The emergency exit doors only can be opened after they have been avtivated from the flight deck.
EWRCabincrew
Sun Dec 03, 2006 6:12 am
Quoting 7474ever (Reply 1):
At no time does the flight deck have control over the opening of the doors. They do, however, have indicators that the doors/exits are opened. closed, armed and disarmed.
When the cabin is pressurised, the doors/exits cannot be opened. When the pressure is equal (i.e. on the ground or below cabin altitude) you can open doors/exits.
If the flight deck had control and they were incapacitated for any reason, it would render all exits useless.
This is where flight attendants come in. Flight attendants are placed at doors and exits.
When the cabin is pressurised, you cannot just simply "open a door or exit".
You can't cure stupid
7474ever
Sun Dec 03, 2006 6:27 am
Quoting EWRCabincrew (Reply 2):
We're talking about emergency exit doors, like the ones over the wings, not the regular passenger doors.
OPNLguy
Sun Dec 03, 2006 6:28 am
Nope.
Quoting Captainsimon (Thread starter):
The "gull-wing" emergency exit doors on the 737 NG family are held closed by mechanical locks and cabin air pressure. The lock system is designed to ensure that the flight lock will automatically lock during takeoff, inflight, and landing, and unlock on the ground to allow for opening of the door in emergency situations. The flight lock gets sensor input from various other systems on the aircraft.
Bottomline here is that the system protections are automatic, and that someone can't open them inflight. Worry not.
7474ever
Sun Dec 03, 2006 6:32 am
Quoting OPNLguy (Reply 4):
That means they can be open by the passengers while the plane is taxiing ?
nzrich
Sun Dec 03, 2006 6:33 am
Quoting 7474ever (Reply 3):
Quoting EWRCabincrew (Reply 2):At no time does the flight deck have control over the opening of the doors. They do, however, have indicators that the doors/exits are opened. closed, armed and disarmed.
Yes and everything EWRCabincrew said was 100% correct im also crew and the exits can not be opened during flight but can on the ground at any time... The captain/co pilot can not lock these doors at all...They are armed at all times and ready for any evacuation at any time as long as the plane is on the ground theses exits can be opened..
cheers NZrich crew on the 737
[Edited 2006-12-02 22:38:24]
"Pride of the pacific"
EWRCabincrew
Sun Dec 03, 2006 6:37 am
A door is a door is a door. Whether it is over the wing (DC-10, 747) or an auxiliary exit door just behind the wing (757-300, some 767-300/400), or an auxiliary door at the wing (A310), it is a door.
Then there are window exits.
Regardless, they are not 'activated' by the flight deck. They cannot be opened when the cabin is pressurised. There is no 'locking mechanism' that prevents inadvertent openings. Such openings happen from time to time.
Window exits can be opened at the gate, during taxi to and from runway and at anytime the the cabin is not pressurised.
OPNLguy
Sun Dec 03, 2006 6:38 am
Quoting 7474ever (Reply 5):
As I said, there are other sensors tied into the system, and I'm not going to get into specifics (for obvious reasons) other than to say that if the overwing exit doors needed to be used in an evacuation that they'd be readily available just as the entry and service doors would be.
7474ever
Sun Dec 03, 2006 6:39 am
Thanks for the info.
EWRCabincrew
Sun Dec 03, 2006 6:42 am
Quoting EWRCabincrew (Reply 7):
When passengers do this, it makes for delays and unhappy people.
EWRCabincrew
Sun Dec 03, 2006 6:50 am
This just happened this year in FLL. The guy opened the window exit during taxi...it happens.
http://www.keepmedia.com/pubs/MiamiH...1/23/1167093?extID=10037&oliID=229
OPNLguy
Sun Dec 03, 2006 6:55 am
Quoting EWRCabincrew (Reply 11):
Yes, it does, but that aircraft was a 737-300, and not a member of the NG family, which was the subject the OP asked about....
EWRCabincrew
Sun Dec 03, 2006 7:01 am
Quoting OPNLguy (Reply 12):
Fair enough, but the article was to relay that inadvertent exit openings happen. It could have easily happened on a NG aircraft. No special locking device to prevent it.
Follow the instructions and you have a lot of explaining to do to the authorities.
lincoln
I don't really have anything to add that hasn't been said except that if you're in the window seat you can usually hear the "locking mechanism" (I'm assuming it's a solenoid of some type) make a fairly loud click at the point at which the over wing exits are "locked" during taxi/takeoff and then again when they're "unloacked" during landing.
Lincoln
(A frequent occupant of seat 14F on CO's 738 and 73G)
We're Nuts
Sun Dec 03, 2006 7:59 am
And even if the cabin were not pressurized, the shear force of all that air rushing past the fuselage would make moving the exit impossible. They are idiot-proof by design.
Dear moderators: No.
EWRCabincrew
Sun Dec 03, 2006 8:04 am
Quoting We're Nuts (Reply 15):
When we had the 747 in our fleet, we had procedures for clearing smoke out of the cabin during flight.
Oerationally the flight would need to be under 10,000 ft, crack open door 1L and 5R to get a 'cross vent'. We always joked about that. Gratefully we never had to implement it.
Markhkg
Sun Dec 03, 2006 9:30 am
Actually, if for some reason the O/W locks are not functional on a 737-NG aircraft (or 747 upper deck exit), the exit can still be opened at low pressure differentials. I asked this question on the Tech/Ops page, and some responded that carriers will specifically place some sort of crewmember (could be ground staff) at these exits if these locks are not working to prevent inadvertant opening by pax.
Quoting EWRCabincrew (Reply 16):
And let's not forget the A330 Philippines Airlines aircraft that had Door 4R opened in mid-air (after the cabin was depressurized at a safe altitude intentionally) to let a hijacker jump off with his home-made parachute. The hijacker did not survive.
OPNLguy
Sun Dec 03, 2006 11:46 am
Quoting MarkHKG (Reply 17):
That may have been the case before, but the 737 MMEL (and subsequently, individual airline MELs) changed to delete the ability to defer them, and they're now no-go items. Used to be MEL 52-15, IIRC. Don't know about the 747, but I'd assume they lost MEL relief as well...
Markhkg
Sun Dec 03, 2006 2:46 pm
Quoting OPNLguy (Reply 18):
Somehow, that's kind of a relief to me.  Smile Thanks for the update.
zippyjet
Sun Dec 03, 2006 3:02 pm
Though it wasn't an emergency exit, James Bond between shagging Pussy Galore and saving the world in Goldfinger accidently shot out a window on an inflight Lockheed Jetstar and everything including the tub of lard Goldfinger got Hoovered out into the great wide open. Stuff for the movies. Just thought I'd take a flight down memory lane in regard to popping open an emergency exit whilist inflight.
I'm Zippyjet & I approve of this message!
OPNLguy
Sun Dec 03, 2006 3:10 pm
Quoting Zippyjet (Reply 20):
...except that an emergency exit can't open inflight due to the normal cabin pressure exerting force upon it (since it's a plug)...
lincoln
Sun Dec 03, 2006 3:37 pm
Quoting OPNLguy (Reply 21):
I could be wrong since I'm just a very enthusiastic exit-row pax, but my understanding was that the over-wing "gull wing" exits on the 737NG are not plug-type and that between this, the tension on the spring, and the internal pressure (when pressurized) opening of an over-wing exit on the 737NG in flight was, theoretically at least, possible hence the reason they have the locks.
Lincoln
iahcsr
Sun Dec 03, 2006 5:06 pm
Actually, if for some reason the O/W locks are not functional on a 737-NG aircraft (or 747 upper deck exit), the exit can still be opened at low pressure differentials. I asked this question on the Tech/Ops page, and some responded that carriers will specifically place some sort of crewmember (could be ground staff) at these exits if these locks are not working to prevent inadvertent opening by pax.
The requirement at CO is that a CO employee (any employee) MUST be seated at the exit if the lock is inop. A co-worker got paid to fly IAHBDL/Hotel/BDLIAH a few months ago for this reason.  crazy
Sun Dec 03, 2006 5:56 pm
Yeap, the same you can do on the MD-80 as well! Wonder me, if there is any othe a/c type...
well, complicated question- but it could be possible! to my knowledge, it depends on the engine-speed. as soon as the enginge have reached a special speed, the exits will be locked!
Quoting EWRCabincrew (Reply 10):
Well, this is true! But NOT that problem... You will have more problems on the B767, B757, A320 etc.- where the slide will be automatically activated over the wing! It happened in the past! Then a new slide is needed- and this takes looooooooong! Big grin  Big grin
sstsomeday
Sun Dec 03, 2006 6:12 pm
Is this true?
Or is the "click" you hear the door becoming "armed," so that the slide will automatically inflate and extend if the door is opened.
I'm hearing two different stories here, some saying that the doors (over wing) can be locked remotely (from cockpit, I assume), and some saying that they cannot.
I come in peace
Markhkg
Sun Dec 03, 2006 7:19 pm
Quoting SSTsomeday (Reply 25):
Is this true?
There is no overwing slide on the 737, even on the new gullwing design. The click noise is not an arming feature.
IFixPlanes
Sun Dec 03, 2006 7:27 pm
Or is the "click" you hear the door becoming "armed," so that the slide will automatically inflate and extend if the door is opened. ...
No Slide. You have to use the extended Flaps...
The Crew can not lock them remotely. It is done automaticly:
http://img273.imageshack.us/img273/1646/b737ngoverwinglockschematic3cz.jpg
yellow = Trust Lever (both) or
green = "AIR MODE" and
blue = at least one Engine running and
purple = 3 or more Doors closed
never tell an engineer he is wrong ;-)
nonfirm
Sun Dec 03, 2006 7:35 pm
Quoting Lincoln (Reply 14):
Correct.28v dc.
Not correct the handle if it can be open will also act like a vent.
that carriers will specifically place some sort of crew member (could be ground staff) at these exits if these locks are not working to prevent inadvertently opening by pax.
That is correct.It is when cabin psi is below 4 psi.
Not true.We still have that Mel and yes there has to be a crew member it as part of the Mel.
 airplane
OPNLguy
Sun Dec 03, 2006 11:04 pm
Quoting Nonfirm (Reply 28):
You are right, and I stand corrected. I mistakenly assumed it was changed in the MMEL, and according to Rev 49 of the MMEL, it's still in there. Obviously my airline chose to make its own MEL more restrictive than the MMEL...
(M)(O) May be inoperative provided:
a) Each affect exit is verified to be capable of being unlatched and opened before each departure, and
b) A person employed by the operator is designated to remain seated in the passenger seat nearest the affected exit when cabin differential pressure is less than 4.0 psi.
sstsomeday
Mon Dec 04, 2006 2:20 am
Quoting IFixPlanes (Reply 27):
Excellent graph. Thanks for clarifying.
I come in peace
