TurkishWings
TK 737-800 "Eyebrow" Question
Mon Dec 04, 2006 12:33 am
While looking at some pictures of 737-800s of TK, I realized that the eyebrows of this particular airplane were removed... I know that the new ones are now being delivered without but why did they feel the need to remove the eyebrows that had been there for a long time already? Does it help with anything at all?
Before and after pics:
Photo © H. Meier
Photo © Viktor Dreger
Coffee - Tea or Me?
MCOflyer
RE: TK 737-800 "Eyebrow" Question
Mon Dec 04, 2006 12:43 am
I was wondering the same thing and can only assume one reason: It may have been in for MX and they decided to take them off.
MCOflyer
FoxBravo
Quoting TurkishWings (Thread starter):
Saves some weight--with fuel prices as high as they are, every little bit counts. There may be other reasons too.
Common sense is not so common. -Voltaire
Cadet57
Mon Dec 04, 2006 1:04 am
Quoting FoxBravo (Reply 2):
Well, WN is removing theirs for the maintenance cost so that could be the same for TK....
TK787
Mon Dec 04, 2006 1:08 am
I have heard that pilots don't use them anymore, and some cover them with newspapers to reduce glare.
abletofly
Mon Dec 04, 2006 1:55 am
All that I know of is that it was a 1960's requirement from the FAA of minimum windshield area and to increase visibility in banking maneurves.
But readucing glares and weight sounds fine to me. But actually how much weight is reduced by removing the "eyebrows"??
Cheers.
barney captain
Mon Dec 04, 2006 2:06 am
It has more to do with mx costs. As you can imagine, a piece of aluminum requires far less attention over time than an electrically heated piece of laminated glass. Plus it looks cool  Wink
Southeast Of Disorder
FoxBravo
Mon Dec 04, 2006 2:07 am
Quoting AbleToFly (Reply 5):
See http://www.boeing.com/news/releases/...05/photorelease/q1/pr_050126h.html
According to Boeing they save 20 lbs of weight and 300 hours of periodic inspections per aircraft.
luke7e7
Mon Dec 04, 2006 6:10 am
It is no longer needed due to advanced avionics, witch don't require so much light for the crew to do their job.
emrecan
Mon Dec 04, 2006 6:18 am
They are being removed to make some economy.
