747400sp
A340F In DHL Fleet 10 Or 20 Years From Now?
Wed Dec 06, 2006 4:37 am
In 10 or 20 years airlines or going to start replacing their Airbus A340. That will leave a surplus of A340, and since DHL has A300 in their fleet, it would be a great ideal for them to get convert some A340's into freighters. The A340 has a large cargo capacity four engines, so they would not need to think about ETOP. Also if they get a used A340 500, they would have an aircraft with outstanding range. I like to see an Airbus A340 in DHL fleet and believe it help their over seas network, what do you think?
kaitak
Wed Dec 06, 2006 4:40 am
It wouldn't surprise me, particularly given the lack of success of the A340-5/600 in recent years. Once these aircraft leave pax service, what will happen to them; despite the lack of respect they often get, they are perfectly fine aircraft and I'm sure they could be made to work as freighters; better that than an early appointment at Marana ...
WINGS
Wed Dec 06, 2006 4:43 am
Quoting 747400sp (Thread starter):
I was not aware that Freighters had ETOPS issues. Either way I would love to see the A340 series ending up it's career with cargo operators, it will be the A330 series that will have the largest interest among cargo carries, mainly for the reason of the latter being a twin.
Wings
Aviation Is A Passion.
airtran737
Wed Dec 06, 2006 4:44 am
The thing with the A340 is that IMHO the only ones that could be used as freighters are the 500 and 600. The 200 and 300 are underpowered, and I am not sure that they would be an economically viable freighter. The 600 would be an awesome freighter, shes a big girl, with a lot of room. We'll see what happens.
Nice Trip Report!!! Great Pics, thanks for posting!!!! B747Forever
N328KF
You should put a question mark at the end of your title.
Are the A340s all that well suited for cargo? The street vibe is that the -200/-300 are underpowered, though I do not know myself. Certainly, the -500/-600 would be more bulk-oriented.
Magyarorszag
Wed Dec 06, 2006 4:48 am
Quoting Kaitak (Reply 1):
Perhaps you should look toward the MD-11 for an exemple.  Smile
Cheers.
WINGS
Wed Dec 06, 2006 4:52 am
Quoting AirTran737 (Reply 3):
Quoting N328KF (Reply 4):
This is a pure Airliners.net URBAN MYTH. (a very stupid one) if I may add. I have never seen any A342/3 falling from the skies, and I doubt that anyone has either. They don't even fall in the desert for that matter as all A342/3 are currently in service.except (1x A342 VIP)
The only issue involving the A342/3 is the slow climb rate. Apart from this, it is still a very capable and reliable airplane.
Wings
brendows
Wed Dec 06, 2006 4:54 am
A cargo aircraft have to handle a higher payload than a pax aircraft does, and that reduces the range dramatically, if you look at the 777F, 748F and A380F, the range of the freighter is about 60% of the range of the pax version. Why? Because it's more important to carry alot of cargo rather than carrying it for long distances, which requires more fuel.
ETOPS will not be a concern for a cargo carrier, since the routes aren't that long that they fly over such areas.
The A340 won't be an optimum freighter, it doesn't have a great internal volume compared to its weight, the A330 will be a much better freighter. When it comes to the A340NG, the older A340 are probably more suited.
Range isn't that important when carrying cargo, payload is.
DfwRevolution
Wed Dec 06, 2006 4:56 am
Some started in 1998  duck
Problem being, the 772ER will make a much more suitable freighter conversion than the A340. There are plenty of examples of passenger aircraft not making suitable cargo conversions, and the A340 doesn't have a lot working for it.
What would be more reasonable would be for DHL to peruse A332 conversions. The payload density and economics greatly favor the A332 over the A333, A343, or A345/A346.
Neither of those points are particularly significant.
Cargo aircraft typically fly as close to max payload as possible, which greatly reduce the range figures quoted for passenger variants. A loaded 777F (which is built from the 9,500 nm 772LR) only has a range of about 5,500 nm.
Mass ratios and lb economics are more important than raw still-air range figures. Keep in mind there are very few A345 even built and those are all very new. Not to mention, the A345 has an extremely high OEW and surprisingly low payload uplift (relative to its direct competitors)
As for ETOPS, since cargo is rarely flown on long-haul routings, there are very few ETOPS zones where a cargo aircraft would even venture. Maintaining ETOPS 138 is really a non-issue
Magyarorszag
Wed Dec 06, 2006 4:59 am
Quoting WINGS (Reply 6):
Or failed to take off! And I regularly see MK A343s takeoff very heavy for their long journey from GVA to MRU (9023 km).
Cheers.
[Edited 2006-12-05 21:04:51]
N328KF
Wed Dec 06, 2006 5:03 am
Quoting Magyarorszag (Reply 9):
That's not true at all. EK did have an A340-313X, I think it was, fall into a ditch at JNB.
Magyarorszag
Wed Dec 06, 2006 5:21 am
Quoting N328KF (Reply 10):
There's only one incident of an EK A340-313X hapening at JNB that I know (April 9th, 2004). In that case, the aircraft failed to lift off when it was expected, so the pilot had to apply TOGA power, thus making the aircraft takeoff 150m down the overrun area. Immediatly after, the crew decided to come back at JNB, and dumped fuel. From what I remember, its more a pilot error than an airframe problem, and the aircraft did not end up in a ditch. But you can correct me if I'm wrong.
I've just done a quick search and have found this article.
Emirates censured in Airbus A340 Johannesburg runway overrun probe
Cheers.
[Edited 2006-12-05 21:30:34]
ChiGB1973
Wed Dec 06, 2006 5:29 am
A300 in their fleet
What about their 757/767 fleet? Of course there are several airlines involved in hauling DHL's freight, but I am leaning towards a twin. The 777/333/332 will be front runners to anything with 4 engines.
M
Qantas744er
Wed Dec 06, 2006 5:31 am
Quoting Magyarorszag (Reply 11):
Correct the Pilot entered wrong FMC data and so the V1 Vr and V2 speed were wrong and so he pulled the plane to early, dragged the tail for around 150m and after applying TOGA he managed to lift off. Fuel was dumped and on landing the brakes failed after being damaged from the overunn but the plane managed to stop before the end of the runway.
Cheers Leo
You live and you die, by the FMA
