nycfly75
DL's Italy Schedule For Summer 2007
Wed Dec 06, 2006 6:22 am
Very Impressive..Italy is becoming a Hub of sorts for DL:
DL 148 JFK-FCO 17.10 07.55 (1234567) 763
DL 149 FCO-JFK 13.25 17.10 (1234567) 763
DL 160 JFK-FCO 18.55 09.55 (1234567) 763
DL 161 FCO-JFK 11.45 15.20 (1234567) 763
DL 32 CVG-FCO 19.30 10.45 (1234567) 764
DL 33 FCO-CVG 10.30 15.15 (1234567) 764
DL 76 ATL-FCO 16.40 08.25 (1234567) 764
DL 77 FCO-ATL 12.45 17.55 (1234567) 764
DL 70 ATL-FCO 19.20 11.10 (1234567) 763
DL 71 FCO-ATL 10.05 15.20 (1234567) 763
DL 136 JFK-PSA 20.15 11.00 (-23-5-7) 763
DL 137 PSA-JFK 13.35 17.05 (1-34-6-) 763
L 150 JFK-VCE 18.40 09.30 (1234567) 763
DL 151 VCE-JFK 11.30 15.00 (1234567) 763
DL 162 ATL-VCE 19.25 11.00 (-2-4-67) 763
DL 163 VCE-ATL 13.05 18.05 (1-3-5-7) 763
DL 84 JFK MXP 19.45 10.10 (1234567) 763
DL 85 MXP JFK 12.15 15.30 (1234567) 763
DL 74 ATL MXP 17.25 08.40 (1234567) 763
DL 75 MXP ATL 11.00 15.35 (1234567) 763
[Edited 2006-12-05 22:23:29]
LAXdude1023
RE: DL's Italy Schedule For Summer 2007
Wed Dec 06, 2006 6:27 am
Quoting Nycfly75 (Thread starter):
This should be on a 764. But the schedules are still early so maybe DL will upgrade.
It is what it is...
flyingdoctorwu
Wed Dec 06, 2006 6:35 am
impressive schedule...
I like the flights to PSA... tuscany is always great in the summer
panamair
Wed Dec 06, 2006 6:53 am
With this schedule, will Delta offer more U.S.- Italy flights than AZ? DL certainly offers the most number of US flights from FCO (and of course VCE and PSA since AZ doesn't fly transatlantic out of the latter two).
I've counted AZ's Italy - US flights next summer as follows:
1 FCO-EWR
2 FCO-JFK
1 FCO-BOS
1 MXP-JFK
1 MXP-EWR
1 MXP-MIA
1 MXP-ORD
1 MXP-BOS
DAL767400ER
Wed Dec 06, 2006 7:09 am
Quoting Panamair (Reply 3):
This should indeed be the case, unless of course AZ adds another flight. Seat capacity-wise, that'll be an interesting question, as AZ should normally have at least 2 777 flights to JFK. That said, I don't know how many seats AZ has on its 763s and 777s, so I can't compare the numbers.
LIPZ
Wed Dec 06, 2006 7:20 am
At least during the summer Italy (10 flights) seems to be the most served country in Europe by DL and Rome (5 daily flights) as well is becoming one of the most important airports in the Old Continent for DL.
Alitalia744
Wed Dec 06, 2006 7:35 am
Quoting DAL767400ER (Reply 4):
234 and 291 respectively.
[Edited 2006-12-05 23:37:50]
[Edited 2006-12-05 23:42:44]
Some see lines, others see between the lines.
stirling
Wed Dec 06, 2006 7:44 am
Looks like these aircraft do a scissors in FCO.
DL32 from CVG turns around and becomes DL77 back to ATL.
DL76 from ATL turns around and becomes DL33 back to CVG.
These two flights as well swap.
DL148 from JFK turns around and becomes DL71 back to ATL.
DL70 from ATL turns around and becomes DL149 back to JFK.
Best time to spot Delta in Rome will be from 0955 to 1005 When 3 Aircraft are on the ground at the same time.
Next best time will be thankfully longer, from 1110 to 1245 when again, FCO will have 3 Delta Aircraft on the ground at the same time!
Otherwise, most of the day, from 0825 until 1245 there are at least 2 Delta Aircraft on the ground at any one time.
Exciting stuff!
Delete this User
DAL767400ER
Wed Dec 06, 2006 7:56 am
Quoting Alitalia744 (Reply 6):
Thanks  Smile . Guess that puts AZ ahead of DL as far as the number seats goes, then.
Alitalia744
Wed Dec 06, 2006 8:08 am
Quoting DAL767400ER (Reply 8):
Thanks . Guess that puts AZ ahead of DL as far as the number seats goes, then.
yep by about 1000 seats a week given:
DL has about 14000 seats/week (6 daily 763, 2 daily 764 and 2x4weekly 763)
AZ has about 15400 seats/week (4 daily 777, 3 daily 763 and 2x5weekly 763)
Close tho and amazing that DL is almost up there in terms of flights to Italy. Will be interesting to see DL's next Italian announcement
[Edited 2006-12-06 00:12:15]
rwsea
Wed Dec 06, 2006 8:11 am
Will DL be using the reconfigured 764's with BizE on these routes?
As a side note, will all the 764's on the TATL flights have been reconfigured by then?
Alitalia744
Wed Dec 06, 2006 8:14 am
Quoting RwSEA (Reply 10):
The 764s on these routes will not be reconfigured and will be sold as all coach. The two aircraft do a scissor rotation as someone above mentioned.
DL can route BE traffic through ATL on the later flight and on both of JFKs flights.
From what I've heard the reconfigured 764s will be flying:
ATL-CDG
ATL-LGW
ATL-FRA
and possibly on JFK-LGW depending on how the flight goes...
TokyoNarita
Wed Dec 06, 2006 8:16 am
Kinda surprised CVG-FCO is a B764.
TokyoNarita.
LIPZ
Wed Dec 06, 2006 8:17 am
Quoting Alitalia744 (Reply 9):
AZ has about 15465 seats/week (4 daily 777, 3 daily 763 and 2x5weekly 763)
4 daily 777?
For me there are 3 777s flights to USA in the summer
MXP-JFK (AZ 604/605)
FCO-JFK (AZ 610/611)
FCO-EWR (AZ 644/645)
[Edited 2006-12-06 00:18:24]
panamair
Wed Dec 06, 2006 8:19 am
Quoting Alitalia744 (Reply 11):
ATL-CDG
ATL-LGW
ATL-FRA
So far, it looks like the reconfigured, BE-equipped 764s will already start flying this winter on:
ATL-CDG (DL22/21) - starting in January 2007
ATL-EZE (DL101/110) - starting in mid-February 2007
though DL22/21 on the 764 is only loaded through February so far.
For the summer, DL114 ATL-BCN has been designated so far for the BE-equipped 764s.
But as mentioned multiple times, these are all subject to change....
MAH4546
Wed Dec 06, 2006 8:28 am
Quoting LIPZ (Reply 13):
4 daily 777?
MIA-MXP does not convert to the "summer schedule" until the end of April (and returns to the winter schedule one month early as well, at the start of October), so for one month, it is a 772 before going to a 767 for May-September.
a.
Alitalia744
Wed Dec 06, 2006 8:30 am
4 daily 777?
You're right. I forgot 606/607 ops as a 763 year round now even in the summer! We all make mistakes Smile
Quoting Panamair (Reply 14):
Hadn't heard about BCN or EZE, thanks for the info. I'm still wondering when the TLV switch is going to happen...
Also - the 763 configs may change on DL given some movement up front...
panamair
Wed Dec 06, 2006 8:35 am
Quoting Alitalia744 (Reply 16):
Both have been loaded as such on delta.com and various CRS and the seat maps show the new config as well.
You mean removing one of the BE lavs and putting the FA crew rest seats there?
LIPZ
Wed Dec 06, 2006 8:47 am
Other flights to Italy are still possible for 2007?
I guess in a few weeks the next european summer timetable will be completely finalised and loaded up.
[Edited 2006-12-06 00:48:47]
LIPZ
Wed Dec 06, 2006 9:30 am
And according to this link provided by DL, route Nice-Atlanta will not come back in 2007.
Evan767
Wed Dec 06, 2006 10:36 am
I assume the wink means there will be one? If it's a new city, the only city left I can think of is Naples. Otherwise, it must be a flight from MXP-CVG?
Are they changing back to 48 seats up front with the mini cabin? That mini cabin was great with BE seats. Maybe put those extra Y seats they added on the TWA 757's and I'm sure they have some BE seats left over from the change to 36 seats a few years ago with a refreshed seat cover. Well, that's my guess.
LAXdude1023
Wed Dec 06, 2006 10:43 am
Quoting Evan767 (Reply 20):
I seriously doubt it.
I could see this happening at some point from JFK. JFK-NAP is exactly the kind of route DL would sink their teeth into. I would bet money that DL will try JFK-LED in the not too distant future as well.
It is what it is...
worldtraveler
Wed Dec 06, 2006 1:15 pm
ATLMUC is slated to get a BizElite 764 in the spring which probably says it will stay through the summer.
Most of the 764 summer schedule has not yet been released.
rwsea
Wed Dec 06, 2006 2:50 pm
Quoting LAXdude1023 (Reply 21):
Not to get off topic, but is DL done announcing their new TATL routes for Summer 2007?
panamair
Wed Dec 06, 2006 6:43 pm
Definitely not. If anything, the number of Business seats will go down with the implementation of the lie-flat seats.
Quoting LIPZ (Reply 19):
Yes, ATL-NCE is not returning - started cannibalizing JFK-NCE somewhat last summer; also didn't do too well on its own.
I am surprised to see ATL-SNN back though (DL156) together with the new nonstop JFK-SNN (DL102) standalone, (and both so far using the unconverted 'sold as all-Y" 764s), that's a lot of capacity to dump onto SNN. I believe ATL-SNN also struggled somewhat last summer.
sq452
Wed Dec 06, 2006 9:58 pm
Glad to see CVG gets FCO back again with a 764 this time around...
SIN > CVG > BOS
stirling
Thu Dec 07, 2006 12:03 am
Napoli is also Italy's 3rd Largest City
It would be nice to see them go south of Roma one day...maybe even Sicilia, there is certainly the population, but probably not the income. Income starts high in the north and gets lower as one goes south. (Napoli is notorious as a pick-pocket-paradiso.....scares some potential tourism away which is too bad as it is the gateway to Pompeii, Herculaneum, Mt Vesuvius, Positano, and the Amalfi Coast which is to die for beautiful!)
Torino, Genova, and the Bologna conurbation deserve consideration as much as Naples, plus they are business centers if not the huge tourist draws Delta has chosen for their new Italian line-up.
Here is a list of Italy's Largest Cities (NOT-Metro Areas)
In Millions: [Cities over 150,000]
2.649 Roma
1.306 Milano
1.047 Napoli
0.921 Torino
0.689 Palermo (Sicilia)
0.656 Genova
0.386 Bologna (Parma/Modena)
0.382 Firenze (Livorno[Pisa])
0.341 Catania (Sicilia)
0.335 Bari
0.297 Venezia
0.262 Messina (Sicilia)/(Reggio di Calabria)
0.254 Verona (Brescia)
0.252 Trieste
0.212 Taranto
0.190 Brescia (Verona)
0.180 Reggio di Calabria (Messina)
0.174 Modena (Bologna/Parma)
0.173 Cagliari (Sardinia)
0.168 Prato (Firenze Metro)
0.167 Parma (Modena/Bologna)
0.164 Livorno (Firenze[Pisa])
0.156 Foggia
Delete this User
sflaflight
Fri Dec 08, 2006 5:28 am
Add the metro areas and Napoli moves up quite ahead! Would be nice to see DL in Naples.
Well some has to instigate, maybe DL IS getting ready to become Italy's airline to the US once AZ.......... Kidding of course...
Or with the rumors of LH and China/CX and all, maybe DL is solidifying Italy for SkyTeam.
DAL767400ER
Fri Dec 08, 2006 5:43 am
Quoting Sflaflight (Reply 27):
Actually, that thinking is not that far off. By launching more non-FCO/MXP routes, DL allows Italians outside those cities regions to get to the US nonstop meaning one less stop plus connection time, which no doubt positions Delta well as a good alternative to Alitalia, even more so if DL is indeed to add a 5th destination in Italy.
OOer
Fri Dec 08, 2006 7:58 am
Any chance of DL taking over the customer service duties in VCE anytime soon?'
DTWAGENT
Fri Dec 08, 2006 12:37 pm
I have been reading in Business Weekly and in other news mag. that AZ is not doing to well. They are lossing their own goverments backing. The goverment is selling off they shares of the airline and at the same time they are about to lay off a large number of employees. Maybe DL is stepping in to take part or all of the AZ pass. Just a thought.
Chuck
worldtraveler
Fri Dec 08, 2006 12:43 pm
NAP only has an 8600 foot runway which is why they are unlikely to attract TATL service.
flyguy1
Fri Dec 08, 2006 12:46 pm
Quoting WorldTraveler (Reply 31):
How do GJ operate their NAP-JFK service than?
727, L1011, MD80, A300, 777-200, 737-300, 737-700, 747-400, 757-200, 737-800, A320. E190, E135, 767-200, CRJ9
