Boston92
Quad-Engine Configuration
Mon Dec 11, 2006 7:36 am
Is there an a/c out there that has four engines; 2 rear and 2 under-wing. So kind of like a MD80 with two additional engines under the wing. With this configuration, you could have a large wide-body and have a more distributed weight than with a 747.
How long until an a/c manufacturer make an a/c with this configuration?
Any comments are welcome.
"Why does a slight tax increase cost you $200 and a substantial tax cut save you 30 cents?"
ebj1248650
RE: Quad-Engine Configuration
Mon Dec 11, 2006 7:48 am
Quoting Boston92 (Thread starter):
There's nothing out there ... yet ... like you described. The VC-10 and Super VC-10 have four engines in the rear, as does the IL-62. The L1011, DC-10, and MD-11 have one engine in the rear and one engine under each wing. I don't really think you're going to see an airliner designed with the configuration you're talking about. As large as engines are getting, it's likely all four engine layouts will mount 2 engines under each wing.
Dare to dream; dream big!
OldAeroGuy
Mon Dec 11, 2006 9:25 am
But you don't want to distribute the weight in this manner.
Keeping the all the engines on the wings will:
Make it easier to balance the airplane by keeping the zero fuel weight CG near the wing Aerodynamic Center (AC).
Provide bending moment relief for the wing, resulting in a lighter wing structure.
You do need to carefully design the outboard engine nacelle/strut and outboard wing to avoid excessive cruise drag though.
ChrisI1024
Mon Dec 11, 2006 10:26 am
Not a civil (or even a production) aircraft, but the Junkers Ju 287 had two forward-mounted engines on the fuselage and one under each forward-swept wing. It was a funny looking thing.
