aileron11
I Have Question About Contrails.
Mon Dec 11, 2006 10:01 am
I checked to see if this has been discussed before but did not find anything, so my question is, why does some airplanes have contrails that look like they skip, just today I saw three airplanes flying and instead of seeing long continues line I saw the contrail stop and then start again I looked as long as I could see the airplane and it kept happening. Just wondering if any else seen this or maybe even have an answer thanks.
Jersey Lou
steeler83
RE: I Have Question About Contrails.
Mon Dec 11, 2006 10:16 am
It has to do with atmospheric conditions aloft. There must be some little isolated pockets of very dry air aloft for this phenomenon to occur. With more humidity at F.L. 20-something-000 feet, the water vapor discharged from the jets will condense into clouds, or what we see as contrails. If the air is very dry aloft, the vapor cannot condense and crystalize. Therefore no contrail is seen.
Please somebody correct me if I am wrong! I read about contrails in "The National Audaban Society Field Guide to North American Weather. (I don't think Audaban is spelled right btw.) Anyway, that is my source. Did I misinterpret or misread something? Please tell me!!
Do not bring stranger girt into your room. The stranger girt is dangerous, it will hurt your life.
We're Nuts
Mon Dec 11, 2006 10:25 am
It's because they are spraying chemicals as part of a top secret government program.  shhh
Dear moderators: No.
aileron11
Mon Dec 11, 2006 10:36 am
Quoting Steeler83 (Reply 1):
Thanks for the info.
Quoting We're Nuts (Reply 2):
i had feeling something like that was happening.
Jersey Lou
steeler83
Mon Dec 11, 2006 10:41 am
Quoting Aileron11 (Reply 3):
Anytime. Although, I must say that I don't know how accurate that is. I did have a supreme interest in meteorology, but of course, that interest has shifted towards geography and planning.
Heheh, yeah this is true as well Big grin
I think that the increasing number of really bad drivers has something to do with this, and one royally bad driver practically ran my girlfriend and myself off the road just last night! If he could've gotten any closer to my girlfriend's trunk, he would've been in it...
Vref5
Mon Dec 11, 2006 10:50 am
Hahaha Big grin
Ahh, yes, the good ol' chemtrails.  Silly
You've got the rough idea, though there are actually two things that matters here:
1. Low temperature
AND
2. Vapor pressure
It's pretty cold up there every day, but not always the vapor pressure needed. That's why you don't always see contrails.
Basically, if you have sufficient vapor pressure, it will form a "cloud"... and if you don't, it won't. There, that's a bit of my aviation meteorological training put to some use. Big grin
graphic
Mon Dec 11, 2006 10:56 am
There needs to not only be enough water vapor (not as much as you'd think because jet engines themselves produce a large amount of water vaport), but there also needs to be sufficient nuclei for the vapor to condense on (microscopic dust, smoke particles). When the temperature is so cold that the air cannot hold the water vapor the engines produce, it will condense on the nuclei and a cloud will be visible.
Demand Media fails at life
steeler83
Mon Dec 11, 2006 11:06 am
Quoting Vref5 (Reply 5):
Thank you very much  Smile
Naturally I should've known about cold temperature, OF COURSE!!! Vapor pressure I didn't even think of! THANKS!!!
And good training put to good use at that!  Smile
bimmerkid19
Mon Dec 11, 2006 11:36 am
...and trails of the bluejuice  Wink
Last flights: LH 3738 MUC - ZRH , LH 3749 ZRH - MUC . Upcoming: EK 50 MUC - DXB 3-aug. and EK 322 DXB - ICN 7- Aug.
steeler83
Mon Dec 11, 2006 12:15 pm
Quoting Bimmerkid19 (Reply 8):
what about the WN kool-aid?  Wink
Pihero
Mon Dec 11, 2006 6:59 pm
All true, but if you both go just a bit further, it is a sure sign of clear air turbulence be it due to a wave or some drastic convective movements of the air mass.
Contrail designer
