UAEflyer
Why No A346HGW For VS
Fri Dec 15, 2006 8:36 pm
While i was looking at the latest photo uploaded from TLS, i came across a Virgin Atlantic A340-600, i notice that it is not High Gross Weight (HGW).
Didn't Airbus stop producing the normal A340, arent they producing the HGW only?
if not why VS did not order the HGW, it is better than the original one.
scouseflyer
RE: Why No A346HGW For VS
Fri Dec 15, 2006 8:48 pm
VSs deliveries started before the HGW was availble - their later planes being deliverd now are HGW but the early ones aren't
Don't know if you can "HGW" a pre-update plane - I suspect not
brendows
Fri Dec 15, 2006 9:33 pm
Quoting Scouseflyer (Reply 1):
Correct, that's not possible  checkmark
UAEflyer
Fri Dec 15, 2006 11:13 pm
Do you mean that a normal A346 cant be turned to HGW?
brendows
Sat Dec 16, 2006 12:51 am
Quoting UAEflyer (Reply 3):
Yes, that's what Scouseflyer says. The A346HGW isn't just a simple MTOW increase on paper from the MTOW of the A346, there are structural differences between the two that prevents such a thing from being done.
sevenheavy
Sat Dec 16, 2006 1:08 am
Correct.
None of the 17 currently delivered A346 are HGW versions. That includes the three delivered in the last couple of months, as well as G-VWEB which arrives next week.
I believe later options can be converted to HGW versions if required.
So long 701, it was nice knowing you.
scouseflyer
Sat Dec 16, 2006 1:14 am
Quoting SevenHeavy (Reply 5):
IIRC AB said when the HGW (or IGW as it's sometimes called) was certified that only the HGW of the A346 would be produced from then on?
gokmengs
Sat Dec 16, 2006 1:29 am
Does the HGW has considerable advantages over the stock Smile 346 if thats the case how come VS didn't choose the option even after it became available for the rest of the deliveries?
Gercekleri Tarih Yazar Tarihide Galatasaray
sevenheavy
Sat Dec 16, 2006 1:34 am
As far as I remember airbus have been delivering HGW A346 for a few months but the VS aircraft are so far all identical.
I assume that airbus have been a little flexible on this.
egnr
Sat Dec 16, 2006 3:37 am
They will be HGW by default. The non-HGW variant is no longer offered or produced.
7late7, A3latey, Sukhoi Superlate... what's going on?
sevenheavy
Sat Dec 16, 2006 3:49 am
Quoting EGNR (Reply 9):
Do you know when this came into effect?.
VS received G-VRED last month and that was non HGW. Also it seems that G-VWEB will be non HGW, and that aircraft has yet to be delivered.
brendows
Sat Dec 16, 2006 3:57 am
Quoting SevenHeavy (Reply 10):
I believe all A340NGs produced and delivered since mid-summer have been of the HGW-version.
VS might have done the same thing with these birds as with their 744s, certifying and operating them at a lower MTOW...?
airbusA346
Sat Dec 16, 2006 6:46 am
Quoting Brendows (Reply 4):
What are the differances between the HGW and non-HGW.
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
brendows
Sat Dec 16, 2006 7:07 am
Quoting AirbusA346 (Reply 12):
A twelve ton increase in MTOW (which needs some structural reinforcements, and leads to a ~5ton higher OEW,) engines with a higher thrust rating, laser welded fuselage and a larger fuel capacity, that's some of the changes. It can carry more payload further (but burns more fuel when it's doing so) than the A340(non-HGW.)
UAEflyer
Sat Dec 16, 2006 7:01 pm
as i understood, that the non-HGW can be HGW, QR is the only airline that operates the A340-600HGW.
I was thinking about the 777-300ER, can a non-ER convert to ER version, i mean is there a major different between the two, i know the engine and fuel tanks but they have the same fuselage
airbusA346
Sat Dec 16, 2006 8:08 pm
Quoting UAEflyer (Reply 14):
The 773ER has differant wingtips (raked) compare to the 773.
Tom.
PADSpot
Sun Dec 17, 2006 2:53 am
Nope, LH also received HGW versions. In the end LH will have 10 non-HGW (10 delivered) and 14 HGW models (3-4 delivered, 10-11 yet to come))
gigneil
Sun Dec 17, 2006 3:28 am
Quoting AirbusA346 (Reply 15):
The 777-300ER is a massively different plane to the 777-300.
The A340-600X is different structurally to the A340-600. The structure of the A340-600X is actually lighter, there are control surface differences, and the MTOW of the plane is higher.
NS
airbusA346
Sun Dec 17, 2006 3:52 am
Quoting Gigneil (Reply 17):
Yeh, I know that I was just one thing that is differant as in looks.
Tom.
PADSpot
Sun Dec 17, 2006 4:59 am
Quoting Brendows (Reply 13):
How can these two statements function together?
gigneil
Sun Dec 17, 2006 1:52 pm
They're not contradictory if you know the story.
The A340-600X uses a higher proportion of composites. It is lighter than if you had just bulked up the previous airframe to that MTOW linearly.
NS
PADSpot
Sun Dec 17, 2006 5:37 pm
Quoting Gigneil (Reply 20):
Saying "light structure" is quite misleading here, because it IS 5 tons heavier. One could call it a more efficient structure, if you will
Standard version MTOW/OEW ratio: 368/177 = 2.08
HGW version MTOW/OEW ratio: 380/182 = 2.09
Hence the HGW is structure-wise exactly 0.49% more efficient. Not really impressing but ok ... still better than nothing.
Did you think of the mere 12t/5t ratio which is 2.4? Well, just the structural cannot fly ... you need to compare whole airplanes.
Jan
jdevora
Mon Dec 18, 2006 9:49 am
Quoting UAEflyer (Thread starter):
From Airbus press release, looks like their latest 346 are HGW.
Qatar Airways is the first customer to take delivery of this new higher gross weight A340-600 with first deliveries due to begin in summer 2006, followed by deliveries to Lufthansa, Virgin Atlantic and Etihad Airways.
They claim that the HGW is a 18% better than the normal 346. The problem is that they don't say better in what Sad
Benefiting from A380 technology, reduced maintenance costs, and the latest development of Rolls-Royce Trent 500 engines, the new 380 tonne A340-600, with typical seating of 380 passengers in three-class comfort, provides up to 18% higher compared to earlier variants and travels 250 nm (463 km) further, up to 7,900 nm (14,600 km).
(enfasis added)
Both quotes are from Newly certified A340-600 brings 18% higher productivity
JD
