airbusA346
LH Technik Hangars @ FRA
Tue Dec 19, 2006 8:17 pm
I just saw a photo comment on the 'other site', which basically said that the 'old' LH Technik hangar at FRA will be pulled down.
The photo was taken on the 12th Dec 06.
Comment: The anniversary aircraft in front of the old Lufthansa hangar which will be pulled down in a few weeks.
Why are they pulling it down?
What's going in its place?
This is the hangar:
Photo © Mario Aurich
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
PanHAM
RE: LH Technik Hangars @ FRA
Tue Dec 19, 2006 8:41 pm
I am not sure if it is going to be pulled down that quick, I am not even sure if it is this hangar which is shown in the picture. Actually, the old 707 hangar is scheduled for demolition once the NW runway is finally OK'd, they need the space for a taxiway connecting it. Actually a shame because it is a landmark building.
What anniversary aircraft is that 733 supposed to be? Would be interersting to read the full article.
Was Erlauben Erdogan!!!
airbusA346
Tue Dec 19, 2006 8:53 pm
Quoting PanHAM (Reply 1):
No that isn't the photo the comment is for. That photo is just to show the hangar, the comment is of the 'Other Site'
I am not going to show the photo in fear of getting banned.  Sad
If some one else want to show it?
Tom.
johnnybgoode
Wed Dec 20, 2006 7:38 am
the hangar will be pulled out in the forthcoming months as the airport will expand Terminal 1. other buildings of the LH Base will also be pulled down.
quite a number of departments have moved to the new Lufthansa building which was opened last summer which in turn frees up space in the buildings.
rgds
daniel
If only pure sweetness was offered, why's this bitter taste left in my mouth.
airbusA346
Thu Dec 21, 2006 2:47 am
Quoting Johnnybgoode (Reply 3):
expand Terminal 1
What parts are they expanding?
Which 1's?
How are they replacing what they are pulling down?
Any photos of the new building.
Tom.
LHStarAlliance
Thu Dec 21, 2006 2:52 am
Quoting AirbusA346 (Reply 4):
Which 1's?
Maybe the one that has been constructed new ...
Boycott The Olympic Games In Beijing !
johnnybgoode
Thu Dec 21, 2006 4:05 am
expand Terminal 1
well, obviously they're expanding the western part of Terminal 1, to be more precisely, Terminal 1A.
sorry, I can't show a pic.
Tom.
you will probably find some by searching google. type in Lufthansa Base or LAC (for Lufthansa Aviation Center). awesome buidling, by the way.
airbusA346
Thu Dec 21, 2006 4:23 am
Quoting Johnnybgoode (Reply 6):
COOOL!!!!
Here is the website: http://lac.lufthansa.com/en/index.php
Tom.
PanHAM
Thu Dec 21, 2006 4:59 am
OK, the T1 extnesion does not affect the old hangar.
The T1 extension is a straight line from the terminal. If they rename the piers,m it should be A, the old A should be B and so on,m butg I think they will find another solution. That new poier will extend over the space still occupied by the old LH base, those offices have been moved "across the road" to that new building,
The hangar must be torn down once the new runway is build, they need the space for the taxiway.
airbusA346
Thu Dec 21, 2006 5:18 am
Quoting PanHAM (Reply 8):
So is that hangar being replaced by the new LH Technik hangar.
Tom.
johnnybgoode
Thu Dec 21, 2006 8:18 am
I think you are referring to the wrong hangar. the extension of T1, while being built on space occupied by today's LH Base, will require one of the three hangars to be torn down, so that aircraft will have ample space to taxi to and from the new gates. the one I am referring to is called 'Schmetterlingshalle', i think, and it houses the maintenance stations for the 737 fleet IRIC.
rgds
daniel
PanHAM
Quoting AirbusA346 (Reply 9):
the new LH technik hangar is on the south side, was actual build as Condor Cargo Technik and I really don't know when it was renamed, I am driving past the building several times a week and I noticed the name couple of months ago. Next to that, the A380 hangar is under construction right now.
The old hangar's fate is more or less concluded but the final decision must come once the NW runwaqy is authorized, which is scheduled for 2007 - hopefully.
airbusA346
Thu Dec 21, 2006 7:24 pm
Quoting PanHAM (Reply 11):
Any Pics of the hangar under construction??  Smile
Tom.
PanHAM
Thu Dec 21, 2006 11:05 pm
Quoting AirbusA346 (Reply 12):
you find a lot of information here,
http://www.fraport.com/cms/capacity_growth/rubrik/2/2830.expansion.htm
there is an image of the A380 hangar as well. A picture of the contruction wouold not give much informaiton. Right now, there are a couple of concrete structures, the foundation is more or less finished.
