ramerinianair
Cheap Transceiver
Thu Dec 28, 2006 4:51 am
I'm looking to buy a cheap transceiver for my-self so I can tune to both ground and Tower Frequencies at the same time while spotting. Does anybody know where I can pick up a VHF COM Transceiver for cheap?
SR
W N = my Worst Nightmare!!!!!
seattleflyer
RE: Cheap Transceiver
Thu Dec 28, 2006 10:17 am
Have you looked at these? I don't know what you consider cheap, however.
http://www.sportys.com/pilotshop/pages/transceiver.cfm
graphic
Thu Dec 28, 2006 10:20 am
So at your home airport we know who's calling for all the damned wind checks.
Demand Media fails at life
KELPkid
Thu Dec 28, 2006 10:59 am
Quoting Ramerinianair (Thread starter):
Don't mind me, but may I ask why someone spotting would need a transmit function? You might do better to check out the handheld scanners at Radio Shack or Fry's (if you don't have one in your area, you can go to http://www.frys.com). Also, AES (Amateur Electronic Supply), http://www.aesham.com/ should carry both scanners and airband transceivers. The site is geared toward amateur radio operators (like yours truly  Wink ), but they do have a CB/scanner/HF section in their catalog (which is in PDF form).
ramerinianair
Fri Dec 29, 2006 5:41 am
Thanks for the info . . . I don't need the transmit function. I only need the reciever part - I don't know what to call it though.
SR
BigOrange
Fri Dec 29, 2006 6:21 am
Quoting RamerinianAir (Reply 4):
You want an airband scanner.
Pick up a copy of Scanning USA or Monitoring Times in your local bookstore for some ideas.
CVGpilot
Fri Dec 29, 2006 1:40 pm
Quoting Graphic (Reply 2):
Lol, Ive watched spotters do this thru binoculars from the tower, you can always tell it not coming from a plane tho.
I don't need the transmit function. I only need the receiver part - I don't know what to call it though.
You want a RECEIVER, go w/ the Sporty's SP. FYI I pretty sure the FCC can fine for miss-use of a VHF X-mitter, as they are usually pretty powerful, also check out the Hobby forum you will get lots of help there as this question is asked about one a week.
AsstChiefMark
Fri Dec 29, 2006 1:49 pm
Get your terminology right. Asking the wrong person where to you can buy a transmitting aviation radio so you can "listen to airplanes" could get you a few guys wearing black suits and driving black cars showing up at your work or home.
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
