GLAGAZ
Why Is There A Delta 767-300 In Cotonou, Benin?
Fri Jan 05, 2007 1:11 am
Anyone know the reason for this? Diversion i presume.
Gaz
Neutrality means that u don't really care cos the struggle goes on even when ur not there, blind and unaware
EWRCabincrew
RE: Why Is There A Delta 767-300 In Cotonou, Benin?
Fri Jan 05, 2007 1:14 am
Maybe an issue with the Accra airport? Try checking the DL website for flifo on DL's ACC flight or the DAK/JNB flight.
Edit that. Just checked the DL website. DL 166 diverted to COO. Apparently an issue at ACC. It arrived ACC at 1528 local time.
[Edited 2007-01-04 17:17:04]
You can't cure stupid
B747-437B
Fri Jan 05, 2007 1:21 am
Yes, DL 166 inbound ACC diverted COO reporting poor visibility in Accra.
Sitting right here about 100 yards from ACC airport, I cannot for the life of me imagine why they decided to do that. Every other flight has been in and out of here today without hassles. If this kind of visibility is an issue for Delta, they are going to get totally screwed when Harmattan is in full swing.
[Edited 2007-01-04 17:21:36]
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
FoxBravo
Fri Jan 05, 2007 1:56 am
Even more interesting, today's return flight (DL167), which is now scheduled to leave ACC in about 15 minutes at 5:10 pm local, is showing a scheduled diversion to SJU en route to JFK, with a scheduled arrival in NY at 1:15 am. Ouch--long day for those passengers!
Common sense is not so common. -Voltaire
EWRCabincrew
Fri Jan 05, 2007 2:02 am
Quoting FoxBravo (Reply 3):
I was thinking that might be a glitch in DL's site. I think that DL 166 continues to SJU from JFK. Maybe it is just showing the final destination, as opposed to the enroute destination. I find it hard to believe that DL would send that plane to SJU non-stop. Although SJU is closer by 600 or so miles.
Where are the DL people here to clarify?
B747-437B
Fri Jan 05, 2007 2:12 am
Its probably a payload issue. Temperatures today are stifling and the later afternoon departure may affect the ability to lift the full load of pax and cargo.
FoxBravo
Fri Jan 05, 2007 2:14 am
Quoting EWRCabincrew (Reply 4):
Yeah, that crossed my mind too (and for the sake of the passengers, I hope it is!). However, DL doesn't fly JFK-SJU. Perhaps there are unusually strong headwinds or other weather conditions requiring a fuel stop, although if that were the case there would be less out-of-the-way places to refuel, such as TFN or PDL. On the other hand, DL has operations at SJU and fuel (as well as a new flight crew if necessary) would be more readily available.
In any event, the flight is apparently now boarding for a 2:10 am arrival at JFK (and still showing a diversion via SJU).
Edit: Thanks, Sean--the heat would also explain it.
[Edited 2007-01-04 18:16:33]
worldtraveler
Fri Jan 05, 2007 2:22 am
DL does fly SJUJFK.
The return crew could be close to timing out if they waited at ACC for the arrival.
FoxBravo
Fri Jan 05, 2007 2:26 am
Quoting WorldTraveler (Reply 7):
DL does fly SJUJFK.
You're right, my mistake. But they don't use 763ERs on the route.
B747-437B
Actually, that is probably closer to the truth. The unrealistically scheduled 90 minute scheduled turn in Accra means that the outbound crew is at the airport before the inbound touches down. A diversion means that the clock would be ticking by the time the aircraft gets back to Accra.
EWRCabincrew
Fri Jan 05, 2007 2:32 am
Would be more of a pilot issue than f/a issue, I think. F/a's are more expendable than pilots when it comes to rest. Pilots are held to more rigid rules than we are.
FoxBravo
Fri Jan 05, 2007 10:33 pm
Well, it looks like last night's DL166 diverted to COO again this morning, but with much less of a delay. This time the return flight is scheduled to go nonstop, arriving at JFK about 3 hours late.
Not so bad compared to yesterday's mess--after stopping at SJU, those poor folks finally arrived in NY around 4am, 12 hours behind schedule!
louA340
Fri Jan 05, 2007 10:46 pm
If the reasons are because of the visibility issues due to the harmattan, why is it only DL that is diverting to COO? Or is it some other reason?
RyEng
B747-437B
Fri Jan 05, 2007 10:57 pm
Quoting LouA340 (Reply 12):
Good question. Ghana International came in with both 757 (LGW) and 767 (JNB) yesterday without any problems. All airlines except Virgin Nigeria and Delta have been maintaining normal schedules.
787kq
Fri Jan 05, 2007 11:54 pm
Is it confirmed that the return was via San Juan?
FoxBravo
Sat Jan 06, 2007 12:12 am
Quoting 787KQ (Reply 14):
Yes. Left ACC 6:16 pm, arrived SJU 12:11 am, departed 12:48 am and arrived JFK 3:54 am (all times local).
B747-437B
Sat Jan 06, 2007 12:59 am
Well, it appears that Virgin Nigeria is getting quite slammed now due to the visibility - they are cancelling their 3rd consecutive flight tonight and have about 300 pax sleeping in the airport. They must have RVR of 800m to operate but the tower is evidently calling it as 400m, even though I can clearly see about 1200m from my office window located right by the airport. Bellview and AeroContractors are operating to/from Lagos without any problems and no other flights have been affected.
Just spoke with some folks from Delta and they are laughing about their new 4x weekly JFK-COO service. Interestingly enough, and purely anecdotally (so this cannot be verified through any other source - it is purely hearsay whose veracity has not been determined), the visibility was even lower at COO than it was at ACC before they decided to divert but by the time they got to COO they were too short on fuel to go anywhere else. Welcome to African operations!!!
