B737-112
Amazing Video! Short Field Takeoff Onboard A 727
Fri Jan 05, 2007 3:55 am
This dirt runway has hills like a rollercoaster and the 727 experiences a stickshaker on takeoff. Truly awesome!
http://www.youtube.com/watch?v=0ghFuWv_gFE
CX747
RE: Amazing Video! Short Field Takeoff Onboard A 727
Fri Jan 05, 2007 4:22 am
I tip my cap to the 727. I highly doubt we will see 737NGs or A320s operating from dirt runways at any point during their careers.
"History does not long entrust the care of freedom to the weak or timid." D. Eisenhower
PHKLM
Fri Jan 05, 2007 4:32 am
Wow, 300 flying hours per month, 3 days without leaving the cockpit, in those conditions...
Like the guy says: "being a pilot there at that time was distinctive, mythical almost".
HAJFlyer
Fri Jan 05, 2007 6:17 am
Wow ! That is absolutely terriffic.
They sure do not make them like that any more. I do not want to image what shape an A320 would be in after operating in such an environment for even a week.
Ryan h
Fri Jan 05, 2007 8:22 am
Interesting video.
The runway did not look that level.
jetjeanes
Fri Jan 05, 2007 9:38 am
I had head about them landing on dirt runways before and seen them with ski,s on the nose gear, i just wonder about fod>> can you imagine what those engines are ingesting... that runway looked almost like it was going down hill
i can see for 80 miles
osiris30
Fri Jan 05, 2007 10:09 am
Quoting CX747 (Reply 1):
Not with the low slung engines.. They would be toast before you ever reached rotation. Those engines sitting high on the tail are great for two things, water ditching, and crap runways  Smile
I don't care what you think of my opinion. It's my opinion, so have a nice day :)
gearup
Fri Jan 05, 2007 11:43 am
Quoting HAJFlyer (Reply 3):
Why? because it's an Airbus? Make no mistake, this kind of operation will cause a problem for any aircraft (except for a DC-3!). The 27 only succeeds because of it's high lift devices, high mounted engines and large wheels and as the video shows, it was right on the margin of total disaster. Completley dumb to use an aircraft designed for paved ICAO runways instead of a more appropriate C130.
I have no memory of this place.
flyf15
Fri Jan 05, 2007 11:58 am
Quoting Gearup (Reply 7):
Actually, if you'll notice, they're getting the shaker while on the ground. They got the nose off the ground as soon as possible instead of at Vr... soft field technique. Uses up more runway due to the drag but you're getting the weight off the mains as soon as possible... and you lift off the ground at the slowest possible speed. Once off, slowly lower the nose and accelerate in ground effect until you're at normal climb speed.
crownvic
Fri Jan 05, 2007 1:50 pm
Flyf15...Are you sure that is the stick shaker? As you know, the 727 normally "ground hugs" just before rotation. This same noise is heard from from free spinning nose gear tires that have left the ground as well, but you could be right.
I actually saw this video about two years ago and it was more complete. This version cut off sooner than the original, but cannot remember where I saw it.
MCOflyer
Fri Jan 05, 2007 2:19 pm
Quoting Crownvic (Reply 9):
If you find it, please post it.
MCOflyer
KPDX
Fri Jan 05, 2007 2:32 pm
Can someone embed the vid for me? Cause the vids dont work for me on the site, but when people embed them they do. Yes, I know its weird. Big grin
KPDX  Smile
qf772
Fri Jan 05, 2007 6:07 pm
Make you wonder what they will do when the current crop reach the end of their usefull life?
Eagles may soar but weasles don't get sucked into jet engines
mighluss
Fri Jan 05, 2007 6:25 pm
Quoting KPDX (Reply 11):
Of course!
I thought that soft field technique was done only with light STOL planes!! Big grin
Miquel.
PHKLM
Fri Jan 05, 2007 6:41 pm
It's on YouTube as well http://www.youtube.com/watch?v=2BIJqb90S-8
PanAmOldDC8
Fri Jan 05, 2007 6:49 pm
That is what the 727 was designed for. Originally it was designed for the short hops in Germany, but it was also designed to take off on short runways that were rough
Barbados, CWC soon, can't wait
PanAmOldDC8
Fri Jan 05, 2007 9:27 pm
Quoting B737-112 (Thread starter):
Amazing aircraft, loved the 727. This will be my last post as I have found that this site does not meet my needs as well s I mar have said some things which were uncalled for . Good luck to you all and enjoy your discussions
PanAmoldDC8
richm
Fri Jan 05, 2007 10:01 pm
When you guys refer to it a "dirt runway", is that simply all it is? Or is it asphalt covered in dirt?
- Rich
KPDX
Fri Jan 05, 2007 11:29 pm
Quoting Mighluss (Reply 13):
Thank you!  bigthumbsup
KPDX  Smile
AS907
Fri Jan 05, 2007 11:56 pm
Quoting Richm (Reply 17):
Dirt Runway. It's amazing at what some airplanes are able to operate on. I always enjoy landing on a gravel strip. I bet it would be even better in a 727.
2H4
Sat Jan 06, 2007 12:17 am
Quoting Osiris30 (Reply 6):
737-200s have routinely operated into and out of dirt and gravel strips for decades....using their low-slung engines, even:
Nothing "dumb" about operating an aircraft within it's certified limitations...  Wink
2H4
Intentionally Left Blank
aero145
Sat Jan 06, 2007 12:22 am
As this thread is about the 727 flying to and from gravel strips, how is for example the An-124 or An-225? I saw somewhere that they're made for landing on all runways, that's gravel, dirt and grass... is it something that the aircraft could do or can do?
Nice video btw.
md80fanatic
Sat Jan 06, 2007 12:50 am
Why would it be unusual to get a stick shaker during a short field takeoff like this? Once the nose wheel is off the ground, and until the mains leave the ground, the wings are "stalling". There is not yet enough airspeed to support the airfoil AOA.
BTW, that dirt field is child's play for an MD.  Wink
sanjet
Sat Jan 06, 2007 1:16 am
They stated that dirt runway was 1800 meters. That's only 3300 feet!!! They must land heavy and take off nearly empty with that kind of runway I would imagine. Specially when you are doing soft field procedure.
By the way First Air regularly operates 737-200's on soft/gravel strips.
Photo © Peter Nickerson
You can clearly see the gravel kit installed on the nost gear and the blowers in front of both engine that blows bleed air to blow away dirt/gravel on take/landing.
Will Fly For Food!
LXLucien
Sat Jan 06, 2007 1:26 am
Thank you guys for those links! Just awesome Big grin
That's Africa as it's best! The Pilot himself says: Only here, you can make something like that.
I guess there are no charts for those Airports Big grin
BTW: The CEO of Transafrik was former Executive member @ Crossair, so he know's how to lead an airline with strange opperations  Smile
Quote "Syriana": "Beirut, it's like Paris in the Mid-East"
miamiair
Sat Jan 06, 2007 1:32 am
Dumb statement maybe.
As shown in the pictures above, the 737 can and does operate from unimproved airstrips. I have flown into places with shitter paved runways than the dirt strip in that clip.
clickhappy
Sat Jan 06, 2007 1:47 am
dirt field operations to support the mines in Africa.
Top shelf stuff, thanks for sharing!
gearup
Sat Jan 06, 2007 2:59 am
Indeed, however the 732 is specially modified for this and the gravel Runways in question are level and hard Packed. The runway in the video is an uneven, unlevel dirt strip. World of a difference.
2H4
Sat Jan 06, 2007 3:08 am
Quoting Gearup (Reply 27):
Granted, but it disproves your previous statement that the 727 "only succeeds because of it's high lift devices, high mounted engines, and large wheels". As pictured above, an aircraft without these things can safely operate out of unimproved strips, as well, modifications notwithstanding.
Are you suggesting that 737-200s equipped with gravel kits are limited to level, hard packed dirt strips?
2H4
solnabo
Sat Jan 06, 2007 3:10 am
Tu-134 n 154 can t/o from dirt/gravel strip hence the wide gap between landing gears
Micke//
[Edited 2007-01-05 19:17:17]
Airbus SAS - Love them both
dl021
Sat Jan 06, 2007 3:11 am
Really cool video...thanks for finding and posting it. Africa is one of the last places where wildcat outfits can push their equipment to the limits. I'd bet it'd be a cold day in Kinshasa before US or European authorities allowed such flights regularly.
Is my Pan Am ticket to the moon still good?
cubastar
Sat Jan 06, 2007 3:12 am
Quoting PanAmOldDC8 (Reply 16):
Awwww.....Hey, don't give up. Almost EVERYBODY on here has said something that he or she would probably like to retract. You have a lot of experience and information to share with others. It just seems like everyone wants to get too personal in their posts. Hang in there. It's still a site that you can pick up aviation related info and trivia. You just have to sift through all of the BS that some people insist on posting. Just don't let them punish you by listening to their tirades.
noelg
Sat Jan 06, 2007 3:15 am
Quoting MCOflyer (Reply 10):
The original thread is here:
Interesting 727 Video Here (by Qb001 Apr 23 2004 in Civil Aviation)
But it looks like the video is taken down Sad
cubastar
Sat Jan 06, 2007 3:16 am
Just for info, I think that Boeing actually designed a package for the 72 to operate on unimproved fields.
jamesbaldwyn
Sat Jan 06, 2007 4:00 am
And Easyjet are complaining about Bristols runway!  Big grin
cedarjet
Sat Jan 06, 2007 4:06 am
You know what, it was one of these 727s that the CIA thought had been stolen by Al Qaeda. Remember, after 9/11? The missing seven-two? And the fear was that cos the aircraft in question had been converted to a tanker, it could be filled with fuel and flown into something? Well, it had to have been one of these planes. This was brought to my attention by TUGMASTER, and it's dead-on. Fascinating to see the operation up close like this. The footage of the seven-two barrelling down the slope on takeoff is amazing.
chris133
Sat Jan 06, 2007 10:01 am
I guess yo have never seen the cargo 73s operating in Alaska to unpaved gravel and dirt runways.
Siren
Sat Jan 06, 2007 12:00 pm
I found a 10 minute version of this if anybody is interested...
Siren: 32 year old single white female based @ KLAX. Aviation nerd, political wonk, disability rights activist, German car enthusiast, Californian Independence leader & evangelist
