WINGS
Boeing 757 - A Tribute By Wings.
Thu Jan 11, 2007 2:42 am
Boeing 757 -- A Tribute By Wings.
First of all I would like to thank all the members that have approached me to congratulate me on my effort with the Tribute threads. Your positive support and feedback is very much appreciated. It is also for that very same reason that it's always a rather hard task to choose my next Tribute due to the numerous requests from so many members.
My following Tribute, goes to one of the most loved airplanes among A.netters, which unfortunately saw it's last delivery in November 2005 to Shanghai Airlines.
The Boeing 757, is a twin-engine, single isle, short-to-medium-range jetliner manufactured by Boeing Commercial Airplanes, between 1982 and 2005. A member of the popular 757/767 family of medium-sized airplanes, with 1050 frames being produced.
During the 70's Boeing initiated a research into a successor of the B727. Designated as ''7N7'' initial proposal offered to airlines was a stretched, re-engined 727-200, known as the 727-300. Due to the lack of interest from airlines this initial proposal was abandoned. Another early concept for the B757, featured a "T-tail" with under-wing engines. Finally Boeing adopted a conventional tail, and the same fuselage diameter used on previous Boeing narrow bodied airplanes such as the Boeing 707, 727 and 737. It would also feature two high-bypass turbofan engines, mounted below the wings. The B757 would also feature a nearly identical flight deck to the B767, which was also in development at the time. In doing this Boeing was able to provide pilots of the B757 and B767 a common type-rating. Pilots qualified to fly one of the aircraft also can fly the other with only minimal additional familiarization.
In early 1978, the B757 program was officially launched, and latter that year, Boeing booked it's first orders from Eastern Airlines and British Airways. On the 13th of January 1982, the first B757-200 rolled out of the Boeing Renton, Wash plant. In the following month 19th of February 1982, the first B757 equipped with Rolls Royce RB211-535C engines, made it's maiden flight. It would also mark the start of yet another successful airplane manufactured by Boeing. The B757 is among one of the seven commercial airplanes to have sold more than 1,000 frames. During the following 10 months and over 1,380 of flight testing, the B757 received FAA certification for the aircraft on the 21st of December 1982.
POWERPLANTS:
The B757 was the first Boeing airliner launched with engines produced outside the U.S, with the Rolls-Royce RB211-535 taking the lead.. Pratt & Whitney soon offered the PW2000, launched by Delta Airlines. General Electric offered an engine option early in the program, the CF6-32, but eventually abandoned the engine due to insufficient demand. With the -300 series, only Northwest Airlines ordered the 757-300 with the Pratt & Whitney engines, making them unique among the series.
RollsRoyce RB211-535
Pratt & Whitney PW2000
VARIANTS:
Boeing 757-200
914 frames built
Counting for the largest chunk of B757 sold the series -200 was designed to carry 200 passengers in a typical mixed-class configuration. It also had the ability to accommodate up to 228 passengers in charter configuration. The -200 was available in two different door configurations. One version used three standard doors per side with an additional, smaller door aft of the wing on each side for emergency evacuations, while the other option offered was equipped with three standard doors per side (two towards the front and one at the aft of the cabin) with two "plug-type" overwing exits per side replacing the smaller door aft of the wing.
757-200PF
80 frames built
The cargo version of the B757 (B757-200PF ) was launched in December 1985, when UPS placed an order for 20 frames.The 757F has no passenger windows or doors and no interior amenities. A large main-deck cargo door is installed in the forward area of the fuselage on the left-hand side. The flight crew boards the aircraft through a single entry door installed immediately aft of the flight deck on the left side of the aircraft. The basic maximum takeoff weight of the B757F is 250,000 pounds (113,400 kilograms), with an option for 255,000 pounds (115,600 kilograms). When carrying the maximum load, the 757F has a range of about 2,900 nautical miles (5,371 kilometers).
Boeing 757-200M
1 frame built
The B757-200M (combi) is a convertible version where the seats can be removed in order to place cargo on the main deck. Launched for Royal Nepal Airlines, the B757-200M failed to capture the success of previous combis produced by Boeing with only one example being produced.(9N-ACB)
Boeing 757-300 Condor
55 frames built
The series 300 was the last variant to be launched for the B757. The B757-300 is a stretched version of the 757-200, measuring 23 feet 4 inches (7.1 meters) longer. The extra length allows it to carry 243 passengers in a typical, mixed-class configuration. It also has the ability to accommodate up to 289 passengers in charter configuration. Launched on the 2nd of September 1996, with an order from Condor Flugdienst, a German charter airline. Apart from the stretched fuselage the series -300 also featured new tires, wheels and brakes; a tail skid; and strengthened wings and landing gear.
SPECIFICATIONS:
(* B757-300)
FLIGHT CREW: 2
PASSENGERS: 200 ( 2 class) *(243)
LENGTH: 47.32 m *(54.47 m )
WINGSPAN: 38.05 m
HEIGHT: 13.56 m
CABIN WIDTH: 3.54 m
CABIN LENGTH: 36.09 m *(43.21 m)
MAX TAKE OFF WEIGHT: 115,680 kg *(123,600 kg )
CRUISE SPEED: .80 Mach
RANGE: 7,275 km *(6,421 km )
MAX FUEL: 43,490 L *(43,400 )
SERVICE CEILING: 12,800 m
Boeing 757-200
Boeing 757-300
ACCIDNETS/INCIDENTS:
The B757 has suffered a total of 8 hull loss accidents with 576 fatalities + (125 fatalities on ground due to terrorist hijacking and subsequent crash)
10.02.1990 China Southwest Airlines, 46/144 fatalities.
The aircraft was struck by a Xiamen Airlines B737 that went out of control on landing due to being hijacked.
12.20.1995 American Airlines, 160/164 fatalities
The aircraft crashed into terrain after the crew became disoriented while on approach to Cali. Contributing to the accident was the fact that after the activation of the GPWS, the crew applied full power and pitched up, but failed to retract the speed brakes.
02.06.1996 Birgenair 189/189 fatalities.
The aircraft crashed shortly after takeoff after the failure of the pitot system. The airspeed indicators indicated a higher than actual speed, which caused the pilots to reduce power and slow the airplane until it stalled and crashed. The pilots had noticed an anomaly regarding the airspeed indicators during the takeoff roll, but did not abort the takeoff.
10.02.1996 Aeroperu 70/70 fatalities.
Five minutes after takeoff the crew reported problems with their instruments and stated they wanted to return to the airport. During the initial climb, the airspeed and altitude indications were too low. While returning, the captain's airspeed and altitude indications were too high, causing an over speed warning. At the same time, the co-pilot's airspeed indications were too low, triggering the stick shaker. The aircraft kept descending and impacted the water with the left wing and no.1 engine at a 10° angle and an airspeed of 260kts. The aircraft pulled up to about 200ft and crashed inverted. The captain's airspeed indicated 450kts and the altitude 9500ft. The investigation into the accident showed that the aircraft's three static ports on the left side were obstructed by masking tape. The tape had been applied before washing and polishing of the aircraft prior to the accident flight.
12.24.1997 Transavia 0/125 fatalities.
The aircraft suffered a nose-wheel collapse on landing in high winds and departed the runway. Failure of the flight crew to align the aircraft longitudinally with the runway before touchdown. Crew error.
09.14.1999 Britannia Airways 757-204 0/245 fatalities.
On its second landing attempt at Gerona in heavy rain, the aircraft departed the runway after a nose gear failure. The aircraft slid into a muddy field, where it broke into three pieces.
09.11.2001 American Airlines 64/64 fatalities.
American Airlines Flight 77 departed Washington's Dulles International Airport at approximately 9:20am local time on a flight to Los Angeles. Shortly thereafter, Washington TRACON lost contact with the aircraft's crew, and the plane's transponder was switched off. A primary target representing the aircraft was seen proceeding directly toward the White House. The plane was seen to veer away from the White House, enter a high speed dive, and impact the side of the Pentagon building in Washington, D.C. This event was the third in a series of orchestrated terrorist acts that affected the United States on September 11.
09.11.2001 United Airlines 45/45 fatalities.
United Airlines Flight 93, on a flight from Newark, New Jersey to San Francisco, California, crashed shortly after being hijacked. It was the fourth and final aircraft to crash in a series of coordinated terrorist hijackings on September 11. The aircraft crashed in a wooded area, apparently somehow diverted from its intended impact target.
07.01.2002 DHL Aviation 2/2 fatalities.
The aircraft, on a cargo flight from Bergamo to Brussels, collided with a Bashkirian Airlines Tupolev TU-154 near Ueberlingen on the northern shore of Lake Constance, which borders Switzerland and Austria, around 11:43pm local time. Both aircraft were level at FL360, under Swiss air traffic control (Zurich). Approximately 50 seconds before the collision, Swiss ATC instructed the Russian Tupolev to descend from FL360 to FL350 to avoid a conflict with the DHL Boeing 757. No response was registered by the Russian crew. A second descent instruction was made by Swiss controllers seconds later, and the Tupolev crew acknowledged the instruction. The TU-154 initiated its descent about 25 seconds before the collision. At nearly the same instant, the Boeing 757's TCAS (Traffic Collision Avoidance System) issued a Resolution Advisory (RA) in response to the threat of a collision with the TU-154, and the pilots began a descent in an attempt to avoid the Russian aircraft. The aircraft collided at FL354, broke apart and crashed, with debris scattered over an area nearly 40km wide.
INTERESTING FACTS:
-The 757 was the first Boeing airliner launched with engines produced outside the U.S, with the Rolls-Royce RB211-535, being chosen for this role.
-In 18 years of operation, the 757 fleet has flown the equivalent of nearly 25,000 roundtrips between the Earth and the Moon.
-The 757 fleet has produced over 24 million hours of service for its operators, equivalent to about 2,750 years of continuous service.
SOURCES:
www.Airliners.net
www.boeing.com.
www.757.org.uk
www.airdisaster.com
www.wikipedia.org
I hope that everyone has enjoyed taking a look back into the history of this magnificent airplane.
Wings
Aviation Is A Passion.
desediez
RE: Boeing 757 - A Tribute By Wings.
Thu Jan 11, 2007 3:04 am
once again really professional work!
You are welcome on my RU-list
desdiez
cxb744
Thu Jan 11, 2007 3:05 am
Great tribute to "the flying tube."  bigthumbsup
What is it? It's A 747-400, but that's not important right now.
kellmark
Thu Jan 11, 2007 3:43 am
Great job, Wings.
A few more points about the B757. First of all, it just "looks right" and is beautiful in the air and on the ground, although it looks like a turkey when it is approaching to land, with its long landing gear.
But another thing is the performance capability of the aircraft. It is able to get out of fairly small airports and climb like no other airliner in its category. The B757 enabled many new routes to be introduced because of that, which simply were not possible before.
Also, its ETOPS versions have also allowed many overwater routes that were not economically possible before, particularly over the Atlantic.
And, both it and the B767 introduced the "glass cockpit" into commercial airline aviation.
It is in fact my favorite airliner, with the L-1011 coming second. Although the new B787 will probably also win me over.
Boeing Nut
Thu Jan 11, 2007 3:56 am
Quoting WINGS (Thread starter):
Wasn't that pitot failure also a result of human error like the Aeroperu loss?
Nice job Wings. The 757 has become my second favorite airliner, second only to the 747.
AirEMS
Thu Jan 11, 2007 4:03 am
Wings again you have out done yourself!
Oh and welcome to my respected users list
-Carl
If Your Dying Were Flying
a3
Thu Jan 11, 2007 4:15 am
One more GREAT tribute !!!
Don't spend your money on airlines that don't respect your business.
ClassicLover
Thu Jan 11, 2007 4:21 am
Superb picture of the EA 757! Kudos as usual on the tribute!
MX757
Thu Jan 11, 2007 4:22 am
Excellent job!  bigthumbsup
I wanted to add this too:
CONTINENTAL AIRLINES ADDS WINGLETS TO ITS BOEING 757-200 AIRCRAFT
Continental Airlines became the first airline to add winglets to Boeing 757-200 aircraft, with eleven of the carrier’s 41 Boeing 757-200 aircraft this year scheduled to be equipped with winglets. The winglets reduce the amount of drag on the aircraft and are expected to achieve up to a five percent fuel savings – as much as 300 gallons per aircraft per year – and give the aircraft approximately 200 nautical miles of additional range. The installation of the 8-ft, 2-inch tail winglets was approved by the U.S. Federal Aviation Administration (FAA) after a stringent set of tests and certifications
Photo © P R D Jones
Photo © Dan Rabolt
Is it broke...? Yeah I'll fix it.
andaman
Thu Jan 11, 2007 4:30 am
Great job Wings *****!
At HEL the most common B757 is Finnair's B752 charter version, a pretty bird.
Photo © Michael Durning
Chinese cookie in SFO: "You're doomed to a life of forever travelling abroad and to be able to afford it!"
EddieDude
Thu Jan 11, 2007 4:41 am
Thanks WINGS!!! As always, a very enjoyable tribute! Keep them coming!
Just a few random thoughts:
The 757 is perfect for airlines operating out of hot and high airports like MEX, BOG, etc. It is a shame that AM and MX are retiring their few workhorse 752s (who did routes like MEX-JFK, MEX-LIM, MEX-LAX, etc.) because the lease payments have soared... I guess this goes to show how appreciated and demanded they are in the market.
Speaking of demand, I don't understand why not more frames were ordered. I mean, flying 752s across the Atlantic is now very much en vogue due to the economics of doing so and, as I said, many Latin American carriers could certainly use more 752s. The demise of the 757 (early in my opinion) will contribute to it becoming a cult-type of plane.
MX at some point flew to South America (SCL and EZE) from MEX using 752s (with a stop along the way... PTY if I am not mistaken but it could have been CUN too). I think on a particularly cold day when the passenger and cargo load was very light, MX even sent a 752 non-stop to EZE from MEX.
Upcoming AM MEX-LAX 73H, VA LAX-MEL 77W.
777jaah
Thu Jan 11, 2007 5:10 am
Thank you very much WINGS for this superb tribute!!! Welcome to my RU list.
As EddieDude states, latam carries could have used more 757s than what they did. I really enjoy flying in AVs 752, specially in short hops like BOG-MDE, a 25 min flight, with few fuel, you can really enjoy the power of those RRs powerplants.
For me, the 757 is the BEST single aisle bird around.
JAAH
Next flights: AV BOG-ADZ-BOG, AV-UA BOG-IAD-ORD-IAD-BOG, BOG-FLL-BOG, LA BOG-MIA-BOG J
astuteman
Thu Jan 11, 2007 5:19 am
Great tribute, WINGS
Special memories of a special aircraft.
(Not to mention special memories of working as a consultant with RR on the -535E4 programme (long story, but great fun  Smile ) )
kc135topboom
Thu Jan 11, 2007 5:34 am
I have to agree with everyone else. You have done another great job. BTW, the B-757 is my personal favorite, of all the "modern" jet airliners (those built after 1980).
solnabo
Thu Jan 11, 2007 5:40 am
@ WINGS
Sorry, but don´t agree with you on 757, ´specilly -300
Waaay to narrow fuselage compared to the engines...
Micke//  twocents
Airbus SAS - Love them both
Boeing Nut
Thu Jan 11, 2007 6:08 am
Quoting Solnabo (Reply 14):
Why am I not surprised?  eyebrow
LHStarAlliance
Thu Jan 11, 2007 6:16 am
I Love your Tributes , may I suggest you an Airline Tribute would also be interesting, ...  Big grin Hope we get much more tributes "by wings" thanks Wings !  Wink
Boycott The Olympic Games In Beijing !
LY777
Thu Jan 11, 2007 6:17 am
Excellent work, Wings!!!
I didn't know about the 757M!!!
I love the 757 with winglets!!!
gkirk
Thu Jan 11, 2007 6:37 am
Just a small correction, charter config 757-200s seat up to 239  Wink
Great thread anyway Big grin
columba
Thu Jan 11, 2007 6:55 am
The 757 is a wonderful aircraft and great to fly on but a little boring when it comes to looks.....same goes for the A320, great aircraft, wonderful achievement but a bit boring to look at compared to such beauties as the Dc 10, L1011, A330/A340, 707, Dc 8, 707, Vc 10, CV 990, 747 and the best looking jet airliner of all time the 727-200
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
solnabo
Thu Jan 11, 2007 7:32 am
Guess I´m a wide-body lover...
Micke//  Wink
fridgmus
Thu Jan 11, 2007 7:59 am
Great tribute to a great aircraft Wings! You're on my RU list!  praise
I don't care what anybody thinks, a "skinny" 757 with big blowers on it is downright sexy, and with the winglets? Shweeeeet!
Many thanks my friend.  thumbsup
The Lockheed Super Constellation, the REAL Queen of the Skies!
Scooter01
Thu Jan 11, 2007 8:28 am
Another winner! bigthumbsup
Scooter
AmericanB763ER
Thu Jan 11, 2007 8:48 am
I love these 'tribute'-threads they are always interesting to read-no matter what aircraft type is being treated.
Quoting Kellmark (Reply 3):
While this is totally true on the -200, the -300 on the other hand is a definite no in the aesthethics department. Way too long and narrow! But it does it's job well.
May I add the fact that the -300 is the world's largest single aisle twin airliner and it'll probably remain so forever.  old
Marco
skytaxi
Thu Jan 11, 2007 8:53 am
Thanks for the great tribute. I'll be flying on a 757 for the first time in May
2007.
Quoting Fridgmus (Reply 21):
 checkmark
coiah756ca
Thu Jan 11, 2007 9:12 am
WINGS,
Thank you for the tribute. Very professional. You portrayed the aircraft I make a living on in a great way! Big grin
Long live Denver-STAPLETON. RIP the old and best KDEN
PM
Thu Jan 11, 2007 9:16 am
WINGS asked me for the following information and I'm happy to oblige. (Especially 'cause RR "win" this one!)
1049 produced (-200s + -300s)
617 (59%) with RR
432 (41%) with PW
56 original customers
4 (AWAS, ILFC, Condor, UPS) bought both PW and RR
40 chose RR (77%)
12 chose PW (23%)
But it's a great looking plane with either engine!
Mexicana757
Thu Jan 11, 2007 10:15 am
Great tribute Wings to my favorite airliner out there. bigthumbsup   bigthumbsup   hyper  Let me add a few more pictures:
Photo © Ricardo Morales Centeno - APM
Photo © Greg Gabbidon - t.dot photography
Photo © Luis Tena Orozco - AeroImagenes de Mexico
Photo © Adam Wright
Photo © Krzysztof Godlewski (EPGD Spotters)
Tan Flyr
Thu Jan 11, 2007 10:28 am
add my thanks to the list..great job.
and I sorta like the idea of an "Airline tribute" if you have the time...you certainly have the ability to a great job.
Valcory
Thu Jan 11, 2007 11:50 am
The 757 one of my favorite airplanes.The 757 was suppose to be more like a 727 but end up being more like a 767,shares a lot with the 767.757/767 first jets to pioneer the concept of commonality,first planes to share a common cockpit and a common type rating so pilots qualified to fly one airplane can also fly the other.Introduced the glass cockpit to commercial jets ETOPS twins.The 757 will always hold a special place in my heart.I remember doing heavy checks on the 777,i did a few then i was told we won't be doing anymore 777 checks for a while but we will be working on 757 instead.Needless to say i was i was pissed off i am like going from a 777 to a 757.Once i started to work on the 757 i like it.it was an advance airplane more advance than i thought.I have been working on them ever since and i like it.i work on bothe the 757-200 and 757-300 P&W powered and RR powered.I prefered the pratt much easier to work on even though they were lots of bleed problem.( i think the RB 211 were much better engines just not mechanic friendly)The P&W 2000 series engines were the first comercial engines to be FADEC.I also learn to taxi and do engine run ups on the 757 (fun times)
The 757-200 and 757-300 are a little different besides the obvious length.The 757-300 is equipped with a tail strike system which incorporate sensors.The tail strike sensor send signal to the PSEU(Proximity Switch Electronic Unit) The PSEU sends data to EICAS.The flight crew will take appropiate actin if they get the message etc etc.The electrical power is a little different also ,on the Stand By Power Control Panel the 757 have an additional annuciator light for APU Bat Disch(757-200 only had main batt disch)
On the 757-200 when all electrical power is lost and you are down to stand by power with the main battery you only have like 30 to 40 minutes.On the 757-300 there is a tie Remote Control Circuit Breaker (RCCR) connects the Main battery and APU battery in parallel so you have 90 minutes on stby power.When starting the APU with external power the 757-200 uses the Apu baterry the 757-300 uses the Transformer Recifier Unit (saves the apu battery) Flight controls,on the 757-200 there is a RCM(Rudder Changer Modules) YDM(Yaw Damper Module),SAM(Stabilizer trim and elevator asymmetry module).On the 757-300 you have a YSM(Yaw damper stab trim module). The YSM replaces the RCM,YDM and SAM.The Spoiler/Auto Speed Brakes works a little different also.The 757-200 uses gear tilt pressure switches to validate ground mode inputs to the auto speed brake system from the air ground sensing system.The 757-300 use YSM to validate ground mode imputs.Besides that both work the same when on the ground auto speed air ground relay(energizes) to energize the auto speed brake extend relay to extend the auto speed break acuators.(with spoilers in arm position and both thrust lever less than 8.5 degress the spoliers are up and working). Long Live The 757
zippyjet
Thu Jan 11, 2007 12:32 pm
WINGS! Another great tribute in the books by you! We thank you and thouroughly enjoy them. I feel the 757 is one of the sharpest looking birds flying. Well proportioned, a classic. I never warmed up to the chubby tubby 737-3, 4 and 5 hundred generation with those flattened weird looking engine nacelles. The 737 NG 6 through 9 series incorporate more of the 757s sleekness.
That's Hot!
Photo © Serge Bailleul - AirTeamImages
Photo © Chad Thomas - Jetwash Images
Photo © Nir Ben-Yosef
Photo © Bob Garrard
I'm Zippyjet & I approve of this message!
Garri767
Thu Jan 11, 2007 12:51 pm
Wings, you have outdone yourself again. Congratulations on another great review. We should talk more, its been a while . Seems you have many users following you, and just wanted to say congrats on how much progress you are making on these reviews. They get better and better.
Keep em coming wings.Keep em coming.
Garri767 (personal fav : L-1011 Tribute By wings)
Edit - For those of you who want to read some more of this guys awesome tributes (there are probably more, im just a lazy searcher Big grin)-
McDonnell Douglas DC 8 -- A Tribute By Wings. (by WINGS Nov 25 2006 in Civil Aviation) Airbus A310- A Tribute By Wings (by WINGS Nov 2 2006 in Civil Aviation) Bristol Britannia (175) A Tribute By Wings (by WINGS Oct 27 2006 in Civil Aviation) Dassault Mercure- A Tribute By Wings. (by WINGS Oct 24 2006 in Civil Aviation) Boeing 727- A Tribute By Wings (by WINGS Oct 18 2006 in Civil Aviation) L-1011 A Tribute By Wings (by WINGS Oct 11 2006 in Civil Aviation) Tupolev Tu-144 - A Tribute By Wings (by WINGS Oct 10 2006 in Civil Aviation)
[Edited 2007-01-11 04:59:02]
Two wrongs may not make a right, but three lefts do!
PennPal
Thu Jan 11, 2007 1:11 pm
Great job, as always, Wings! I'm wondering if there are any other aircraft *cough* Convair jets *cough* you can think of to pay tribute to???
 Wink
Boeing727flyer
Thu Jan 11, 2007 1:27 pm
Yet another excellent tribute and to such a great aircraft. Great work WINGS. What next I wonder perhaps the Boeing 747sp?
[Edited 2007-01-11 05:29:24]
Hail the mighty Boeing 727
IFlyTWA
Thu Jan 11, 2007 1:40 pm
Great tribute to a great plane!
A couple more pictures:
Photo © Oliver Brunke
Photo © Juan Carlos Guerra - APM
Quoting PennPal (Reply 32):
Agreed!
"To express the excitement of travel" - Eero Saarinen
Arecibo
Thu Jan 11, 2007 3:15 pm
Wings.....THANK YOU; I so much love the 757 that I do book my trips based on the availability of this airframe as my first option. This was a Very professional presentation.
Life is tough; It's touher if you're stupid. John Wayne.
Thu Jan 11, 2007 4:16 pm
Great Tribute Again. bigthumbsup
Not to forget the Many B752SF flying today.Very few with the older RB211-535C Engines.The newer RB211-535E4 powered are very sucessfull.
regds
MEL
WINGS
Thu Jan 11, 2007 5:51 pm
Thank you so much everyone. I'm very pleased to read all the positive feedback regarding my latest tribute to the B757. I had a strong feeling that the B757 would touch a soft spot on many hearts.  Smile
With so much support and encouragement, from so many members, I'm more than pleased to continue with my Tribute threads.
Wings
A300605R
Thu Jan 11, 2007 6:00 pm
Once again, Wings, great job!
Thank you for writing all of your tributes!
I really enjoyed every minute of my hours on board the 753!
 wave
300 319 320 321 332 733 734 735 738 753 763 F27 M83
September11
Thu Jan 11, 2007 7:03 pm
Quoting Gkirk (Reply 18):
Great thread anyway
I second that.
I liked Eastern Airlines 757 the best -- the "757" scheme on tail -- fantastic
Airliners.net of the Future
brettbrett21
Thu Jan 11, 2007 7:53 pm
Excellent tribute!
The 757 was the first plane that I fell in love with and probably sparked my love of planes all those years ago, waiting in the departure lounge looking out the window at LTN.
No tribute would be complete without a photo of it in the best livery to ever grace a 757:
Photo © David Unsworth - WorldAirImages
i'm so excited i wish i could wet my pants!
helvknight
Thu Jan 11, 2007 8:14 pm
An excellent review.
I refuse to join any club that would have me as a member - Groucho Marx
nema
Thu Jan 11, 2007 8:35 pm
I hav'nt read this tribute yet WINGS, ive just browsed through it and will come back later, but i know i can say well done again already cause you always do a great tribute.
Well done buddy.
There isnt really a dark side to the moon, as a matter of fact its all dark!
WINGS
Thu Jan 11, 2007 11:37 pm
Does anyone know if UPS will also be equipping their B757PF's with winglets? How much range/fuel savings would one expect from such a modification?
Wings
sstsomeday
Fri Jan 12, 2007 12:01 am
What an incomparable contibution you make to the site. Bravo.
I come in peace
727tiger
Fri Jan 12, 2007 12:02 am
Nice job on one of my favorite airliners. I first flew on an Eastern 757-200 in March 1985, Charlotte to Atlanta. Not a long ride, but the take-off power was tremendous.
ltbewr
Fri Jan 12, 2007 12:53 am
Thank you 'Wings' for your tribute to the 757 series, one of the most popular aircraft of a-netters. No wonder they sold over 1000 examples, with their excellent performance (especially at take off), economic efficiency, good weight capacity and pax comfort. They also were a surprise hit with European based charter operators due to their efficiency.
Like many, I have been on both 200, 300 & ETOPS versions, on several airlines including CO, NW, BA and UA. I wasn't aware there were that many made as Freighters. They are a great workhorse of a number of airlines, In recent years they have become critical for some airlines like CO with it's transatlantic range to serve non-stop to smaller cites in Europe. It's a shame that the financial conditions of USA based airliners along with the extension of the 737 series reduced the demand for new 757's to uneconomical levels. I expect a number of even early 757's to have many more years in pax service, and then as freighters.
Comanche
Fri Jan 12, 2007 1:34 am
Parabens Wings! Great job with your latest tribute thread. Please keep them coming.
777Dad
Fri Jan 12, 2007 1:36 am
R.E.S.P.E.C.T.
Jeff  bigthumbsup
"I love to fly,I just don't do it enough"
SANMAN66
Fri Jan 12, 2007 2:08 am
Although production stopped on the "Fabulous 57's", I hope they continue to be popular with the airlines many years to come. I've only seen the 757s with the new winglets during the past year.That gives me an indication that they will still be flying for awhile.The winglets look very attractive and modern on the 757s.I love how graceful they look when they are seen landing from a distance,far more graceful than a 737, A320,or even an Rj  bigthumbsup
PSA Gives you a lift!
