nicogagne
Star Alliance Connection At DTW!
Fri Jan 12, 2007 12:57 am
Hi everyone,
First of all, I wish you all the best for 2007!
I am flying Lufthansa next month from MRS to DTW via FRA and once in DTW, I am connecting to a UA flight to DEN which leaves two hours after the scheduled arrival time of my LH flight from FRA.
The thing is that I am not at all familiar with DTW airport, so I would like to know if two hours should be enough to go through immigration, collect our bags, clear customs and transfer to the Smith Terminal.
I sort of find it odd to connect in an airport that is not a hub for the airlines I am flying - Sorry, I am not sure I am very clear, but I hope you'll understand. Hopefully, it won't be a problem.
Thanks guys for your help!
Nicolas
B2443
RE: Star Alliance Connection At DTW!
Fri Jan 12, 2007 1:05 am
Oh boy...LH arrives at the Mac and UA departs from the Smith!
The key is, upon arrival and clearance of Immigration (bottom level), find an airport parking/terminal shuttle at Level 5 (Ground transportation) in the giant parking structure via the bridge at Level 6 (only passage between the terminal and parking) and tell the driver you need to get to a UA flight!
Good Luck!
neilalp
Fri Jan 12, 2007 2:19 am
There are Terminal to Terminal shuttles like said above just look for Ground Transportation signs. You should have your boarding pass already, but my guess is you'd need to recheck the bags at the UAL counter then go straight to security and the lines tend to move through the tight space quickly so don't worry apon first glance.
I would say 2 hours is cutting it close, but will probably work. Move like you're on a mission. Try to get a seat in the front of the FRA-DTW flight get off quickly and husstle down to immigration, grab your bags and go.
nicogagne
Fri Jan 12, 2007 6:48 pm
Thank you very much for the information.
Do you know if there is a transfer desk inside the McNamara Terminal after customs? There may be one for Northwest but not for United.
If there is no transfer desk, I guess I'll have to take my bags to the Smith Terminal with me and check-in again as if I had just arrived at the airport for a standard domestic flight.
Thanks again!
Nicolas
aircanada014
Fri Jan 12, 2007 8:59 pm
Quoting Neilalp (Reply 2):
Since LH and UA are in Star Alliance I don't think you have to recheck your bags again. My suggestion is tell your LH ticket agent your itinerary and they should be able to tag you right through to DEN without checking your bag again at DTW.
Dtw757
Fri Jan 12, 2007 9:23 pm
Unfortunately for now, you will have to go from the McNamara to the Smith Terminal which is sort of a pain with those shuttle vans. Once the new North Terminal opens in late 2008, Lufthansa will be relocated there with the other non Skyteam members currently using the McNamara. But for now, it's the shuttle.
721,2,732,3,4,5,G,8,9,741,2,3,4,752,3,762,3,4,772,3,788,D93,5,M80,D10,M11,L10,100,AB6,319,20,21,332,3,346,388,146,CR2,7,
daumueller
Fri Jan 12, 2007 9:44 pm
Quoting AirCanada014 (Reply 4):
which would still require to pick them up for customs at least...
Nicogagne: why don't you fly LH446 non-stop to den?
dtwclipper
Fri Jan 12, 2007 10:39 pm
Quoting Nicogagne (Thread starter):
Did you book this ticket yourself? This is a disaster waiting to happen. Going from the "mac" to the smith terminal in two hours is gonna be tight.
I have a feeling you will have to carry your luggage with you between terminals.
The NW Worldgateway is a great building, but DTW was not built for interline/alliance transfers like this.
If you could rebook through ORD or fly Non-stop to DEN I would do that...not that we wouldn't like to have you here in DTW but I can just imagine the kind of hassle you are setting yourself up for.
PS....if you do this, remember before you rant about the Smith Terminal, remember it is being replaced with a brand new terminal scheduled to open in 2008
Compare New York Air, the Airline that works for your Business
PSU.DTW.SCE
Sat Jan 13, 2007 12:08 am
As everyone else has said, this will be very tight.
2 hours:
De-board: 10 min
Customs/Immigration: 10 min
Claim Baggage: 15 min
Walk to shuttle pick-up: 10 min
Shuttle to Smith terminal: 15 min
Check-in luggage at United: 10 min
Clear security: 10 min
Bare minimum you are looking at 1:15-1:30 gate to gate. Any glitch could throw this off. Especially with a late arrival from FRA, or if customs is backed up depending on the arrival of other international flights. Good possibility they will already have begun boarding your DEN flight by the time you arrive at the gate.
You will have to claim your luggage at immigration in the MacNamera terminal, however LH/UA/Star does not have a re-check station in the Mac, so will have to haul your luggage on the shuttle over to the Smith terminal and re-check in with United. Not sure if they will tag it all the way through or if United will have to re-tag it in DTW, either way you will physically have to check it in again.
Right now DTW isn't set up for this type of connections, however once the new North terminal opens in 2008, all non-Skyteam international flights (BA,LH,RJ) will move to the north terminal and customs facilities in the same terminal will make this sort of connection much easier.
D L X
Sat Jan 13, 2007 12:10 am
MacNamera terminal to Smith terminal. Be prepared for a STARK contrast. You will land at one of the most beautiful terminals in the US, and depart from one of the ugliest. I'm sorry you have to see that side of Detroit. I'm even more sorry that you'll have a difficult time getting between the terminals.
Olympus69
Sat Jan 13, 2007 12:58 am
There is another possibility, theoretically anyway. Starting on Jan 30th. PAX in transit will be able to go through YYZ's Terminal 1 without going through Canada customs. This means that a passenger arriving on, for instance LH470, would go directly to US customs for pre-clearance, then to the departure area for an AC flight to DEN. I presume that one would go through security at some point along the way.
I hope someone will correct me if this is not the way it will work. Also I don't know if there is a suitable connecting flight to DEN.
nicogagne
Sat Jan 13, 2007 1:06 am
Thanks guys for all the answers.
Yes, I did book this particular itinerary myself on www.united.fr because it was the cheapest one (600€ return MRS-DEN-MRS). Flying non-stop from FRA to DEN was actually more expensive, and as I don't mind flying, I thought that I could give DTW a try!!!!
But now that I've read all your posts, I realize that picking this itinerary was a mistake!
Anyway, I've just checked the United Airlines website and it says that there's a later flight to DEN that leaves DTW at 5:38pm (CRJ-700) - the UA flight to DEN I am supposed to catch leaves DTW at 3:22 pm (B733).
Hopefully they'll put on this later flight if I miss the 3:22pm one.
On the way back to MRS, I am flying non-stop from DEN to FRA though...so I'm not THAT crazy!
Thanks again for your posts.
Nico
B2443
The best way to avoid all of the trouble is to have your LH agent re-route you thru either ORD or IAD...
NASCARAirforce
Sat Jan 13, 2007 3:17 am
What is going to suck is lines at Security for the Smith recently have gotten pretty bad, and that gets to be peak departure times too since that DEN departure I believe is around 4 or so since the LH flight comes in around 1:30-2. Immigration and customs should be relatively easy and quick unless a lot of Northwest International flights come in around then - usually that is not the case, but if Asian flights are running behind it could be a problem.
When you get through customs - make a left instead of right. The people going right are connecting on Northwest and Sky Team flights. Left are for people staying in Detroit (and in your case connecting on flights out of the Smith Terminal.
At that point you will have to go up two levels of Escalators to go over a pedestrian bridge to the parking lot. Right after the bridge go down one of the escalators to the Ground Transporation level and find terminal to terminal shuttle
nicogagne
Sat Jan 13, 2007 4:45 am
Well, most flights from Asia come in between 10am and 1pm and most flights from Europe arrive between 1pm and 3pm. The scheduled arrival time of my LH flight being 1:25pm, so hopefully the lines at immigration and costums won't be too long!
Guys, the more I read your posts, the more I wonder why I bought this itinerary!!!!!!!!!
Have a great weekend!
Nico
JetBlueGuy2006
Sat Jan 13, 2007 4:53 am
Quoting D L X (Reply 9):
It is very beautiful terminal. I enjoy going through there as much as I can.
Home Airport: Capital Region International Airport (KLAN)
dtwclipper
Sat Jan 13, 2007 4:57 am
Quoting Nicogagne (Reply 11):
Interesting question for you. Since you bought it on United.fr, and it was sold as a legal connection, would UA be responsible for you if you mis-connect?
Is your ticket writen UA/UA or LH/UA?
nicogagne
Sat Jan 13, 2007 5:41 am
Quoting Dtwclipper (Reply 16):
If I miss my DEN-bound flight, I think that UA will be responsible for putting me on the next available flight to DEN.
My e-ticket says "LH/UA ONLY". What if it had been UA/UA??
Nico
NASCARAirforce
Sat Jan 13, 2007 6:35 am
Quoting JetBlueGuy2006 (Reply 15):
Yeah except he won't get to see much of it. When he comes in on that LH flight, he will arrive at the gate and immediately go down to FIS. So all that he will see is the FIS area, and then the escalators and baggage area. He won't get the pleasure of seeing the beautiful Concourse A.
Quoting Nicogagne (Reply 17):
Then you wouldn't be flying to DTW from FRA.
dtw9
Sat Jan 13, 2007 6:54 am
I don't know how you are going to catch either connection. Lufthansa 442 doesn't even arrive at DTW until 4:50pm
dtwclipper
Sat Jan 13, 2007 7:03 am
Quoting NASCARAirforce (Reply 18):
Sure he could have. It could have been sold as a UA Code share with a UA flight number.
nicogagne
Sat Jan 13, 2007 7:12 am
Quoting Dtw9 (Reply 19):
United 9196
Operated by: Lufthansa
Depart: FRA 10:25
Arrive: DTW 13:25
Non-stop
9h
Airbus A330-300
6 698 km traveled
That is what I've got on my itinerary.
dtw9
Sat Jan 13, 2007 7:25 am
I just checked United and Lufthansa.UA9196/LH442 does not arrive in Detroit until 4:50pm
dtw9
Sat Jan 13, 2007 7:31 am
Are you sure you're not flying Air France. The flight from CDG leaves at 10:20 and arrives Detroit around 1:30pm
nicogagne
Sat Jan 13, 2007 7:35 am
Quoting Dtw9 (Reply 22):
You're right. But as of March 25, the schedule changes: new departure time is 10:25 for a 13:25 arrival into DTW. I'll be travelling on April 16.
dtw9
Sat Jan 13, 2007 7:36 am
By your original post you said next month. I took it to mean Feb. Yes the time changes because LH will be adding a second daily flight to DTW
[Edited 2007-01-12 23:38:44]
PSU.DTW.SCE
Sat Jan 13, 2007 8:01 am
Because LH is going double-daily on DTW-FRA this spring.
DTWAGENT
Sat Jan 13, 2007 9:12 am
As per everyone here. It will be a tight conx. I can't wait until 2008 when the new North Terminal will be done. LH, BA and Royal Jordanian will be moving to this terminal. So making conx will be easier.
As for right now. Good Luck and hope everything goes ok. If we have bad weather here in DTW, it could get ugly for you to conx with UA.
Good Luck
Chuck
AlexPorter
Sat Jan 13, 2007 2:51 pm
Good luck with your connection if you try it!
This can happen in some circumstances. For example, if one wants to fly from SLC-HMO (Salt Lake City to Hermosillo), you would have a good chance of flying Delta to PHX, and transferring to Aeromexico. Both are SkyTeam members, and neither (nor any other SkyTeam airlines) has a hub in Phoenix. So while they aren't very widespread, they do happen in some instances.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
nicogagne
Sat Jan 13, 2007 9:36 pm
Why would UA offer this itinerary if they knew that two hours was not enough to make the connection at DTW?
But then again, AF offers itineraries with 50-minute connection times at CDG!!!!!
21°C here in Provence, South of France today....amazing!
Nicolas
dtwclipper
Sat Jan 13, 2007 10:41 pm
Quoting Nicogagne (Reply 29):
Because it is a legal connection, between an international and domestic flight.
It doesn't mean that it will be hassle free, but never the less according to the guidelines for DTW it's perfectly legit.
nicogagne
Wed Jan 17, 2007 1:59 am
I just called United and they kindly told me that they could not rebook me through ORD or IAD. According to the nice UA lady, 2 hours at DTW should leave me plenty of time to grab a cup of coffee or even to have lunch! She definitely had no idea of what she was talking about. Plus, when she saw the UA flight number of my flight from FRA to DTW, she told me that she did not know that UA was operating flights between FRA and DTW!!! Has she ever heard of UA's Star Alliance partners and code sharing?
Anyway, I should have thought about all this when I bought my ticket.
Thanks again for all the posts,
Nicolas
Users browsing this forum: 777ER, aal151heavy, AAlaxfan, Andy33, Bing [Bot], bohica, Channex757, Google [Bot], MGA86, msycajun, SInGAPORE_AIR, Thunderboltdrgn, ttm, webuser, Yahoo [Bot] and 181 guests
