micstatic
When Did DL Change There Same Day Change?
Fri Jan 12, 2007 2:24 pm
When did Delta impose a 3 hour before the flight change on their same day confirmed change policy? I hadn't noticed this change, and to be honest it sucks.
S340,DH8,AT7,CR2/7,E135/45/170/190,319,320,717,732,733,734,735,737,738,744,752,762,763,764,772,M80,M90
deltajet757
RE: When Did DL Change There Same Day Change?
Fri Jan 12, 2007 3:23 pm
You mean you have to change your flight 3 hrs prior to your original flight?
If that's the case it does suck.
-DeltaJet757
FLY DELTA JETS
deltairlines
Fri Jan 12, 2007 3:59 pm
Quoting Micstatic (Thread starter):
Always been this, at least as long as I can remember. Believe it came about when they abolished Same-Day Standby for non-Plats/Golds.
Personally, I don't mind it. Call up SMS 3 hours before if the flight is pretty full; if not, just show up at the airport and have them do it. Relatively painless procedure - only problem is if you want to do a SDC on a later flight, and it ends up going Sold Out - then you're in trouble.
deltadawg
Sat Jan 13, 2007 3:41 am
If you want to change your flight - if it 3hrs or more then it incurs a $50.00 charge. If it is under 3hrs til your scheduled flight then there is no charge.
GO Dawgs, Sic' em, woof woof woof
