BigGSFO
AA/Eagle Post Record Year At MIA
Tue Jan 16, 2007 12:46 am
http://biz.yahoo.com/prnews/070115/dam012.html?.v=74
AA/Eagle carries 19.7MM passgenrs to/from MIA for 2006, up 6.5% from 2005.
doug
RE: AA/Eagle Post Record Year At MIA
Tue Jan 16, 2007 1:25 am
With all the increases at MIA it is still 140,000 off in terms of take offs and landings from there 1998 high of 536,000 for the year.I applaud all that American does in Miami but that is still a huge void of flights to fill.Understanding that it was a different time and era (911,other carriers reducing their flights,fuel,FLL,etc) but most other major U.S airports have recovered and then some will MIA's numbers are nothing to celebrate about.If not for gate restraints and lack of enough aircraft AA could stand to add dozens of flights out of Miami with load factors to back it and I am sure the same goes for the other AA hubs.
BALAX
Tue Jan 16, 2007 3:55 am
Nothing to celebrate about? What planet do you live on?
Delta787
Tue Jan 16, 2007 4:01 am
Quoting BALAX (Reply 2):
I though he outlined his point very well in his post. If you had read it, you would have known what he meant when he said that.
Fly Delta!
BALAX
Tue Jan 16, 2007 4:08 am
Quoting Delta787 (Reply 3):
That's the thing, I read it all but I couldn't understand where the sentences started or ended.
MAH4546
Tue Jan 16, 2007 6:26 am
I read it too, and I still don't understand how it is "nothing to celebrate about" just because there are less daily landings now. Times have changed. Back in 1998, American Eagle was running 5 daily Saab flights to Palm Beach, at least three flights a day to almost every landing strip in Florida, and hourly props to Tampa and Orlando. Nowadays, Palm Beach and small market intra-state flights are gone and all flights to Tampa and Orlando are operated with big jets and significantly more capacity. And the future will be very bright for American Airlines and American Eagle at MIA as terminal work progresses and when American Airlines and American Eagle begin recieving new planes again.
a.
Delta787
Tue Jan 16, 2007 6:34 am
Quoting MAH4546 (Reply 5):
No doubt there. However, I will continue to use PBI and FLL and avoid driving down through that dump called Miami just to get to MIA.
[Edited 2007-01-15 22:36:16]
Fly Delta!
MAH4546
Tue Jan 16, 2007 6:37 am
Quoting Delta787 (Reply 6):
Awesome. And I and others will continue to use MIA while you avoid it so that I don't have to venture in the suburban wastelands of Broward and Palm Beach.
a.
AA767400
Tue Jan 16, 2007 8:07 am
Quoting MAH4546 (Reply 7):
Exactly. I guess that growing up in Miami and flying out of MIA all my life make me bias, But I find MIA not bad at all. I like all the great food options that most airports in the states don't have, and as soon as the new terminal is done things will be even better.
I think that the attitude towards MIA is do to most Americans feeling like they are different there. And that is something they are just not comfortable with.
"The low fares airline."
doug
Tue Jan 16, 2007 8:35 am
I have been one of the biggest cheerleaders for AA and their continued growth at MIA.But when you ask what planet I am on read and fully understand what I wrote.AA carried 19 million last year I say they can easily do 23 million.I am just pointing out the very steep delcline MIA took after 911 and that while AA has expanded overall their are a few more lulls in activity at MIA than years past even with AA dominating.Also if AA continues to transfer more mainline to Eagle such as CLT.IND,IAD,and PIT naturally American Eagle will post record numbers.
MAH4546
Tue Jan 16, 2007 9:51 am
Quoting Doug (Reply 9):
Yes, they can, if they had the equipment. They don't, not right now.
You act as if this has been a problem. It hasn't. Very little has been "transfered" from mainline, and there is no sign that more stuff will. You named the only four examples, and in each case:
Charlotte - One daily S80 became 4 daily ERJs.
Indianapolis - One daily 738 became 2 daily ERJs.
Pittsburgh - launched as an Eagle route, even though it did see mainline for one flight
Washington Dulles - One daily mainline flight is now two daily year-round flights, on each on mainline and Eagle.
The use of Eagle on certain routes has more to do with lack of mainline aircraft. MIA-IND will probably be back to at least one 738 in the near future when equipment is available.
a.
miaskies
Tue Jan 16, 2007 1:13 pm
Congrats to AA and my hometown of MIA! I just moved to the RDU area and sure is nice seeing the AA 738's fly by my house as I know they are coming in from MIA!
Nothing better than making love at 35K Feet!
