AA757BOY
Tracking An Aircraft
Tue Jan 16, 2007 5:08 am
I know that on the BTS it shows the reg. of the aircraft with the statistics but is there a way for me to track an aircraft. Like say I want to track N677AN, where could I go to see where its been etc... any help would be great
S12PPL
RE: Tracking An Aircraft
Tue Jan 16, 2007 5:12 am
A good free one is:
www.flightaware.com
Next Flights: 12/31 AS804 PDX-MCO 2/3 AS19 MCO-SEA QX2545 SEA-PDX
AA757BOY
Tue Jan 16, 2007 5:13 am
Quoting S12PPL (Reply 1):
Flight Aware doesnt show the reg. but thanx anyways
beech19
Tue Jan 16, 2007 5:15 am
Quoting AA757BOY (Reply 2):
You can search by Reg...
if you don't like flightaware.com use Aeroseek.com or flytecomm.com
or use the Flightaware flight finder...
http://flightaware.com/live/findflight_route.rvt
You will be able to find the craft you are looking by narrowing two points down.
[Edited 2007-01-15 21:17:30]
KPAE via KBVY
MidEx216
Tue Jan 16, 2007 5:18 am
Quoting Beech19 (Reply 3):
On FlightAware, the reg number search is only for non-commercial flights. Such as a corporate jet that filed an IFR flight plan.
OPNLguy
Tue Jan 16, 2007 5:20 am
A good free one is:
www.flightaware.com
Quoting AA757BOY (Thread starter):
ASD-based flight trackers like flightaware and others will be of no value to you with repect to a registration number of an airliner, since airlines file flight plans by flight number, and not aircraft registration numbers.
I don't know of any way you can do what you're hoping to do...
beech19
Tue Jan 16, 2007 5:29 am
Quoting MidEx216 (Reply 4):
Hmm... could have sworn i was able to do it before. Or i could be smoking crack...
KPAE via KBVY
S12PPL
Quoting OPNLguy (Reply 5):
Are you sure? I've tried to track one of Paul Allen's 757's that he uses to fly the Blazers and Seachickens around to games in, and it seems to know that company keeps it's planes reg's, and movements private.
OPNLguy
Tue Jan 16, 2007 5:37 am
Quoting S12PPL (Reply 7):
In the case you cite, yes, you could probably track it (unless they have opted to have the info blocked), but I meant "airliner" in the context of a commercial airline with a fleet of airliners. If the airline has N123XX assigned to flight 789, and N123XX breaks down :30 before departure and the airline assigns N124XX to the flight, the flight plan never gets changed--as far as ATC is concerned, it's still flight 789.
S12PPL
Tue Jan 16, 2007 5:40 am
Well I understand that. I just know you can track a reg. number on flight aware. They give you the option. They have to provide an aircraft registaion number with every flight plan...
bond007
Tue Jan 16, 2007 6:03 am
Quoting S12PPL (Reply 9):
No they don't. You have 2 options when filing a flight plan - use a callsign or use a registration number.
All airline flights (or 99.9%), use a callsign which cannot be tied to a registration number using flight plan data.
Some non-airline flights also use callsigns (some corporate/charter operators). Only some can be tied to a registration (example EJA, LXJ, OPT).
Most GA and corporate aircraft use registrations.
Any owner/operator can have their registration blocked from flight tracking systems.
That's about it.
Jimbo
[Edited 2007-01-15 22:04:23]
OPNLguy
Tue Jan 16, 2007 6:06 am
An individual with an airline-type aircraft may have to file the registration number when they file the ATC flight plan, but I know of no airline that has to, and the computer interface at my place doesn't even have a field for the registration number.
If we swap aircraft, I don't have to do anything if it's the same type, but if we swap from a 735 to a 733 or 737, those I have to change, but again, I'm changing the aircraft type, and not the specific registration number, since it was never filed to begin with.
bond007
Tue Jan 16, 2007 6:20 am
Quoting OPNLguy (Reply 11):
Correct!
In fact individuals/companies can apply for a callsign as long as they meet certain criteria (number of flights is one). For example, John Deere JDC, in which case they don't need to file using the tail number and have full control over the other 4 digits.
Jimbo
S12PPL
Tue Jan 16, 2007 6:56 am
Oh...Thanks for the info  Smile
Users browsing this forum: A60Stock, AR385, Baidu [Spider], Bing [Bot], groundbird, Heavierthanair, intotheair, ktachiya, rutankrd, steman, strfyr51, Vos and 186 guests
