SEPilot
Why No Streched 707?
Tue Jan 23, 2007 9:00 pm
I asked this question on another topic but received no answer, so I'll ask it here. The DC-8 acheived extraordinary life because it was stretched; I think I read somewhere that the reason the 707 was not stretched was that the tail configuration was such that stretching it would have caused the tail to strike the runway on takeoff. Does anyone have any info on this?
dtwclipper
RE: Why No Streched 707?
Tue Jan 23, 2007 9:30 pm
From what I have read, the biggest drawback was the landing gear structure. It was comparatively short and would have had to be completely redesigned to stretch the aircraft.
Compare New York Air, the Airline that works for your Business
SEPilot
Tue Jan 23, 2007 9:32 pm
Quoting Dtwclipper (Reply 1):
Thanks; that makes sense.
tjwgrr
Tue Jan 23, 2007 10:51 pm
Not to the extent that the DC-8 was stretched, but the 707 was stretched... called the -300/-400 series.
Quoting SEPilot (Thread starter):
Technically not a 707, but lots of these still around:
Photo © Gary Stedman
Photo © Phil Gilston
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
sparkingwave
Tue Jan 23, 2007 10:57 pm
There wasn't a stretched 707 because Boeing decided to go for a bigger plane altogether, the 747, to satisfy the projected increases in passenger demand for the 1970s.
The 707 basically came out in 1959, and the 747 got the go ahead in 1967, less than 10 years later.
SparkingWave ~~~
Flights to the moon and all major space stations. At Pan Am, the sky is no longer the limit!
pictues
Tue Jan 23, 2007 11:02 pm
the landing gear and the Tail would have needed re-designing, just look at the tail of the non-stretched DC-8's they look too big for the size of aircraft, Douglas did that in mind of future stretches of the aircraft
redflyer
Tue Jan 23, 2007 11:19 pm
The 707-300 series was in fact 8 feet longer than the original 707. But as others have pointed out, the landing gear and tail configuration probably kept it from being stretched further. That and the fact that, as SparkingWave has mentioned, Boeing went for something completely different and bigger in the form of the 747.
My other home is in the sky inside my Piper Cherokee 180.
FrancoBlanco
Boeing decided to abandon the 707 program in favor of the 747. A larger 707 could have killed off some orders for the 707.
Douglas had no plans for a widebody as an answer to the 747, so they stretched the DC-8. A bit later, Douglas realised that it was indeed necessary to build a widebody, too, so they came up with the DC-10.
In the end, Boeing was much more successful. Even with the stretched versions, the production of the Dc-8 ended in 1972 after 556 units produced.
Including all military versions, 1010 707s were built until 1983. Furthermore, about 750 units of the 747 classic were built, compared to 446 DC-10s.
The 707 definately had the potential to be stretched. The redesigns of the landing gear etc. were feasible, there was simply no demand for it with the 747 in mind.
Sebastian
'Pointless!' - NY Times
tjwgrr
Tue Jan 23, 2007 11:28 pm
707-600
Would have looked good:
Modified Airliner Photos:
Design © Daniel K. Stuntz
Template © Jennings Heilig
N501US
Tue Jan 23, 2007 11:29 pm
I am just adding a few thoughts to those mentioned in regards to 747. Although it did not have the seating capacity, the 727-200 with its 3 engines filled a niche for domestic US carriers. The DC10 and L1011 seating capacities were close to what a 707 stretch would be. Plus the planning, design, and subsequent delivery of 757s probably diminished the desire to stretch the 707, too.
Fools and thieves are well disguised in the temple and the marketplace.....
beech19
Wed Jan 24, 2007 3:37 am
Quoting Tjwgrr (Reply 3):
Not a 707 at all. Not even close. Different fues, different wing, similar tail but a little different, ect. In fact they basically shared nothing other than a similar look... and many of the KC-135E's had TF33's stolen from 707's.
KC-135's were Dash-80's and came a good time before the 707.
KPAE via KBVY
AirbusA6
Wed Jan 24, 2007 9:34 am
There's a big capacity difference between even a 'stretched' 707 and a 747, one wonders if it could have filled a gap until the launch of the 767 a decade later?
it's the bus to stansted (now renamed National Express a6 to ruin my username)
N231YE
Wed Jan 24, 2007 9:44 am
 checkmark  That is correct, the size of the gear was the largest limitation for stretching the 707.
pygmalion
Wed Jan 24, 2007 10:16 am
And wheel wells etc. The aircraft has to be high enough off of the ground that when you stretch it, there is enough room to allow rotation and get enough angle of attack on the wing to lift off the runway at a decent rate without tail strikes. The 707 was close enough to the ground that another stretch would have had the tail dragging. The 757 had tall enough gear that it could take a very long stretch, but even then it got a tail skid.
stirling
Wed Jan 24, 2007 11:32 am
Quoting N231YE (Reply 12):
In addition to a new wing and flap design plus, bigger, stronger engines.
Serious studies to stretch the 707 from the -320/-420 began in earnest in 1965.
-620
Domestic services
27 foot stretch to 180 feet.
Seating capacity increased to 230.
MGTOW 330,000lbs (I know some of you are scratching your heads, as this was the same as the -320/-420)
The -620 would have kept the wings and engines of the -320/-420, severely limiting it's intercontinetal capabilities.
-820
42 foot stretch to 195 feet.
9 foot increase in wingspan to 155 feet.
Seating capacity increased to 275.
MGTOW 410,000lbs.
And then of course the aforementioned landing gear extensions and flap design.
-700
One example built. No examples extant.
(Actually the designation was applied to an existing -320C frame)
Four CFM56 attached.
More economical, quieter, and more powerful....nothing came of a civilian version.
The CFMs were stripped off, JT3Ds attached, and sold to Morrocco in 1992 as the last 707.
Of course, that model lived on in a way as the foundation of the E-3 or E-6....or, retrofits to the KC-135A, which became the KC-135R.
The commentary as to why Boeing did not undertake the 707 upgrades will go on forever within the neophyte world, but the fact remains this:
In 1965, Boeing was busier than a ten-pecker rooster in a hen house.
They delivered 61 707s that year, and 83 the next, next to 727s and assorted birds for the military. The 747 programme was kicking off....
Boeing was the Airbus of it's generation.
Just like Airbus is making a quantam jump from A340 capacity to A380 capacity, ignoring the big whole between the A321 and A332....Boeing was doing the same in 1965, leaving the segment for 175 to 350 seats to McDonnell-Douglas primarily with the stretch -8s, and soon the -10, and to Lockheed with the possessed L1011.
Don't forget, the Convair 880/990 programs weren't dead...yet, at best they acted as a pressure valve to the demand for the less thirsty but slower 707s and DC-8s. (But who doesn't love a HotRod.....Even with kerosene 9 cents a gallon, they were not long for this world.)
But most importantly....the industrial spies were coming back from Europe with crazy talk of this most-unholy thing called an A300!
It took the Boeing engineers almost 10 years to take the A300 concept seriously. Is there a parallel here to today's enviroment? Hmmmmm.
The British on their own were fiddling with a 200+ seat extenstion of the Trident and VC10 which never went anywhere....that double deck VC10 was especially hideous, proposals flew around airline headquarters at the very same time Boeing was pitching inferior 707 stretches. One anectdote has them waiting in the lobby at BOAC at the very same time....poor bastards.
So there you have it. While easy to slap a sentence to a question and call it an "answer"....it's not always that easy, there are always mitigating factors that have roots in many places, which I find much more interesting!
Edited for grammar.
[Edited 2007-01-24 03:45:59]
Delete this User
N231YE
Wed Jan 24, 2007 11:41 am
Quoting Stirling (Reply 14):
Interesting...I never knew that Boeing was designing stretches of the 707 (although the shorter landing gear was a major problem with stretching the 707).
However, one could say that a few of the early 747 concepts did include a "707-like" aircraft, only much different looking.
[Edited 2007-01-24 03:44:59]
dw747400
Wed Jan 24, 2007 11:42 am
A major reason for the 747 was the landing gear issues on the 707. Any 707 derivative would have been a major undertaking, so the "low-cost" approach to meet higher capacity needs wasn't as quick and cheap as Boeing would have liked. Combined with pressure to not only make a DC-8 length 707, but something even bigger, the 747 emerged as the best option.
Quoting Beech19 (Reply 10):
Well, if you want to get technical there are a lot of difference between the Dash 80 and the KC-135. Nonetheless, KC135s, and 707s all grew out of the same program (Dash 80).
CFI--Certfied Freakin Idiot
jasond
Wed Jan 24, 2007 12:37 pm
Quoting RedFlyer (Reply 6):
Agreed, looking at the -300 for example it looks about as stretched as it could realistically be so the landing gear issue is a sound argument. What about the 737 though. I know between the -200 and what we now call the 'classics' involved some design changes but on first appearence not to the landing gear configuration as it applies to the fuselage. Extend that further into the NG world, were the changes to the landing gear so significant to allow a subsequent stretch of the 737 to a -900? Or were there a different set of issues at work here?
747400sp
Wed Jan 24, 2007 12:41 pm
-700
There was also the still born E-8B.
beech19
Thu Jan 25, 2007 1:34 am
Quoting Dw747400 (Reply 16):
Far less differences between the Dash-80 and the KC-135 than a Dash-80 and 707 (much larger, heavier ect, 100% different fues, wing ect after it was all said and done.).
The KC-135 ended up being basically a IGW Dash-80. It used the same fues, wings ect, with more powerful engines (slightly).
KPAE via KBVY
SEPilot
Thu Jan 25, 2007 1:45 am
Quoting Beech19 (Reply 19):
The KC-135 was wider than Dash-80, which had an oval shaped fuselage; the KC-135 was round. Boeing had planned on using the same fuselage as the KC-135 for the 707 but when the DC-8 offered 6 abreast seating and customers started flocking to it they redesigned it and made it what it is now.
scouseflyer
Thu Jan 25, 2007 1:46 am
Is that in addition to the BAC 3-11 which was killed by the A300?
beech19
Thu Jan 25, 2007 2:27 am
Quoting SEPilot (Reply 20):
Yes the Dash-80 and KC-135 have different widths but are both oval and the fues's are based off the same design, just increased proportionaty. They increased the height for the -135 and hence received a wider fues but still smaller than the 707's future fues. It was NOT round. Do some reading...
I have personally spent A LOT of time around -135's (55-3120 FISTA and 55-3135 FISTA II before they were retired) and they are oval for sure.
The 707 could NOT compete using the Dash-80 style fues and that is why they needed to build a new fues for the 707 (as you mentioned about the DC-8) as it couldn't compete using a smaller oval one.
Do those look round or oval?
Photo © AirNikon
http://www.defenselink.mil/DODCMSSha...oto/2006-03/060313-F-5646C-023.jpg
Trust me... if you ever get to look head on to a -135, do it... they are drastically ovaled actually.
KPAE via KBVY
rikkus67
Thu Jan 25, 2007 2:30 am
Jasond...re: 737 landing gear
Take a look at front-on pictures of a -300 to a -700. You will notice that the engine nacelle is more rounded on the -700. When the NG series came out, Boeing redesigned the wing, and tail...both are noticably larger. Among improvements was the length of the landing gear, to accomodate longer fuselage lengths.
Photo © Dan Brownlee
-300
Photo © Joseph J. Wagner
-700
note the difference in the landing gear (the -700's is "beefier"), as well as the tail height, and the rounder intake on the -700
back on topic....
When the CFM's were attached to the 707, there must be minimum ground clearance? What I mean to say: Is there a clearance difference between the 707, and the KC135's in regards to CFM engine installation (knowing only the last civil 707 had the CFM's temporarily)....
AC.WA.CP.DL.RW.CO.WG.WJ.WN.KI.FL.SK.ACL.UA.US.F9
stirling
Thu Jan 25, 2007 3:04 am
Quoting Rikkus67 (Reply 23):
The bottom of the inboard engines of the 707s were about 5 feet from the ground; outboard engines higher.
When the CFM56s were attached the clearance was reduced to around 3 feet....about the same as the 737-300.
Delete this User
A999
Thu Jan 25, 2007 7:32 am
The 707 wing was swept back more than the DC-8's and this limited the amount of stretch possible, as there would be tailstrikes if the fuselage had been lengthened more than eight feet. In contrast the -8 was far less restricted, thus allowing up to 37 feet stretch.
scouseflyer
Thu Jan 25, 2007 5:34 pm
Have you photo-shopped a bigger tail onto that plane as it looks massive Big grin
SEPilot
Thu Jan 25, 2007 8:21 pm
Quoting Beech19 (Reply 22):
You are correct; I had never looked that close; I'm not sure why I thought it was round. I knew the 707 was; I just assumed it for the KC-135. Thanks for the correction.
rikkus67
Fri Jan 26, 2007 2:20 am
SEPilot...
If you compare front-on shots of the 707,727,737,757... you will notice that the upper lobe on all are the same*, while the lower lobe varies between each model. Boeing standardized the upper fuselage lobe on all its aircraft, changing the lower lobe to accomodate different cargo levels for each aircraft due to the different missions they would be flying.
737
Photo © Michael Carter
727
Photo © Yu Ming
757
707
*the 757 had the same upper fuselage, but mated to an all new nose.
off topic completely: I wonder why Boeing didn't adopt the 757 nose with the 737NG series?
SEPilot
Fri Jan 26, 2007 4:51 am
Quoting Rikkus67 (Reply 28):
Could it be because it would have raised more issues with certification and pilot type ratings? Thanks for the photos, by the way.
JAM747
Sat Jan 27, 2007 9:44 am
Quoting Jasond (Reply 17):
The 737-900 looks close to the length of some of the 707s to the point where it looks like a twin 707. I wonder if this will the last stretch of the 737 and if it will ever get a quad wheel boogie.
Viscount724
Mon Jan 29, 2007 10:35 am
Off topic, but it's often overlooked that the longest Boeing narrow-body type prior to the 757 was the 727-200 which is 3 inches longer than the 707-320.
Returning to the topic, the early non-stretched DC-8 seemed to have a slightly nose-down, tail-high attitude on the ground. The 707 was the opposite. That made the DC-8 much easier to stretch. Without a major redesign of the landing gear, any significant stretch of the 707 would have resulted in the rear fuselage almost dragging on the ground even when it was parked. With the DC-8's tail-high attitude, this wasn't a problem.
jasond
Mon Jan 29, 2007 1:12 pm
Quoting JAM747 (Reply 30):
According to Boeing (look under Out of Production Models) they quote the length of the 707-320B as 152 feet 11 inches. Using the same source they quote the 737-900 as 138 feet 2 inches a difference of 14 feet 9 inches which while being a little different is not huge by any measure. As mentioned though the restriction on 737 length appears to be related to ground clearence to some degree so I couldn't see the current 737 being anymore stretched than it is. Fitting a quad bogie would also be problematic as there isn't a lot of space to play with around the wing box area, not without sacrificing some centre fuel tank capacity plus the issue of the exisiting structure dealing with the extra weight. Doing such a thing would probably result in a whole new design.
[Edited 2007-01-29 05:15:19]
