LAXdude1023
When Will We See LAX-GRU Again?
Thu Jan 25, 2007 3:23 pm
Is there any possibility we will see LAX-GRU nonstop at any point in the foreseeable future? I think if an airline would do it, it would probably be TAM or another Brazilian airline. I dont think the domestic airlines would be interested.
It is what it is...
MAH4546
RE: When Will We See LAX-GRU Again?
Thu Jan 25, 2007 3:28 pm
In my opinion, no, there is not a possibility anytime soon. Ocean Air has been claiming they want to fly LAX-BOG-GRU, but we'll see if that ever happens.
a.
aircanada014
Thu Jan 25, 2007 8:41 pm
I wonder if AC uses their 5th freedom right its possible they could do YVR-LAX-GRU??? They are waiting for approval from the Australian government to do YZZ-LAX-SYD..
centrair
Thu Jan 25, 2007 9:03 pm
Maybe JL will try it when they relaunch NGO-LAX after the 787s come in. JL stated last year that they plan on rebuilding their LAX hub (never knew it was one). But it sounds that JL might even move JFK-GRU to YYZ-GRU or something like that.
However with a plane the size of the 787, LAX-GRU could be affordable and profitable...even for JL.
But I would say TAM has a much better bet.
One more might be DL. If they try do rebuild their LAX hub, I would sure like to see them connect Asia to South America and Western US.
My name is Centrair but HND is closer. Let's Japanese Aviation!
2travel2know
Thu Jan 25, 2007 9:24 pm
I would think that GRU-LAX could be a route for SA as a JNB (or CPT) - GRU tag-on.
JL flying LAX-GRU will have the problem of requiring U.S. visas for the Japan-Brazil passengers.
Now with its U.S. expansion, I think JJ may be looking into GRU-LAX.
I don't work for COPA Airlines!
LipeGIG
Fri Jan 26, 2007 12:21 am
Quoting Centrair (Reply 3):
What about ANA ? They said in Brazil that probably in 2008 they could fly to Brazil with own metal !
I doubt. They saw RG numbers for LAX route during the last year auction for RG and probably realize:
- They need a partnership with a Japanease carrier to feed the route (and they already keep this on their CDG Flagship route with 3 daily flight).
- They need also some domestic connections (as a * Alliance member, RG could use SA)">UA and US to reach domestic destinations in the United States, and SA)">AA, their partnership, does not keep a strong operation at LAX)
Quoting 2travel2know (Reply 4):
I'm not so sure about the bilateral allowing such kind of flights.
IMO, if DL obtain more 7 frequencies, probably will run a JFK-GIG flight. Their problem is the lack of frequencies.
Felipe
New York + Rio de Janeiro = One of the best combinations !
Venezuela747
Fri Jan 26, 2007 12:37 am
It would probably make more sense to have a stop between LAX and GRU....say LAX-MEX-GRU, LAX-CCS-GRU, LAX-BOG-GRU.....maybe AA will jump to that option
ROLL TIDE!!!
LAXdude1023
Fri Jan 26, 2007 3:19 am
This occured to me as well. They could better serve both Brazil and South Africa as well. I would sure like to see LAX see SAA thorugh GRU. For those of us on the west coast and particularly Southern California its is a lot quicker to go through South America to get to South Africa than to go through the east coast. Kill two birds with one stone!!!
It is what it is...
yellowtail
Fri Jan 26, 2007 5:15 am
One would think that 2 of the largest cities in the world could fill at least one 767 a day each way...
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
MAH4546
Fri Jan 26, 2007 5:25 am
Quoting Yellowtail (Reply 8):
The problem is not filling a plane, it often isn't. It is making money filling the plane.
a.
B752OS
Fri Jan 26, 2007 5:44 am
Quoting MAH4546 (Reply 9):
Does AV does well with their LAX service? That is yields. Everytime I have driven by terminal 2 in the early evening, the line is very very long at the AV counter, so I assume the flight has pretty good loads.
C010T3
Fri Jan 26, 2007 5:52 am
I never understood why UA chose to run a second IAD-GRU instead of LAX/SFO-GRU.
masseybrown
Fri Jan 26, 2007 6:01 am
Quoting C010T3 (Reply 11):
Short-term outlook, which was maybe forced on them by post-911 and South American economics. A veteran of Panagra/Braniff/Eastern told me that South American routes are not consistently profitable, but are very profitable overall. Lose a little one year, make a lot another. UA, it seems, got tired of waiting for the good times.
LAXintl
Fri Jan 26, 2007 7:40 am
Quoting B752OS (Reply 10):
Since resuming service to LAX, last summer AV has averaged 127 passengers per flights. While there have been a few B757 substitutions by far most flight have been on the the 762 which would equal a 72.6% load factor. Definitely not a bad start for only the first 6 months.
Multiple reasons.
To start with UA has self admittedly poorly positioned hubs to serve South America. While California might be a logical connecting point, its not quite feasible for UA to run the market. The most logical aircraft based on passenger demand is the 767-300. However the UA 763s cannot operate any trip beyond 12 hours scheduled block time due to a lack of crew rest facilities which are required per the FAA. In addition the cargo capacity would be near zero on such far deep South America flying from CA even without the crew rest roadblock. As such the only viable aircraft UA could assign would be the 777 or 744, however neither is supportable long term year round from a passenger angle.
Quoting MasseyBrown (Reply 12):
UA deep South America network has been in the red consistently since 2000. Its somewhat sad, considering the constant growth in the region, however UA simply has been unable to capitalize on this and has had to draw down flying thru the years including dropping of its MIA mini-hub.
With the current general lack of widebody capacity and the regions loss making state, South America is clearly not a network priority. When its comes down to a crunch equipment is getting robbed out of the region as was done recently with the late announcement that ORD-EZE was not resume this winter.
worldtraveler
Fri Jan 26, 2007 10:25 am
Latin America has changed a heck of alot since those days.... Latin American economies have "grown up" and are growing at hefty rates - and those routes are profitable, esp. to/from Brazil which is the economic center of Latin America.
We may well see DL start additional service to GRU and they will probably do it by adding gateways. As 764s come into service, DL could well increase capacity to Brazil by increasing the size of its planes and shift some of the existing flights to new gateways.
UA simply doesn't have the network structure to compete in Latin America - which is one reason why a merger w/ CO makes alot of sense. In the meantime, UA will maintain the smallest size in Latin America it can to say it competes in the market and tie up the slots from being used by someone else.
