jetjack74
What Fuselage Is This?
Thu Jan 25, 2007 5:34 pm
I drive by BFI frequently, and for a while i've wondered what fuselage this is, located along Marginal Way on the west side of the field? It looks like a door 3 frame of a 757. The paint resembles that of KLM, but KLM never had the 757, so i'm guessing this was a non-production, static test structure. Anyone know?
Made from jets!
scouseflyer
RE: What Fuselage Is This?
Thu Jan 25, 2007 5:35 pm
The elusive first production section of 787 barrell?
jetjack74
Thu Jan 25, 2007 5:41 pm
Quoting Scouseflyer (Reply 1):
That's this
Made from jets!
scouseflyer
Thu Jan 25, 2007 5:53 pm
Quoting Jetjack74 (Reply 2):
That's this
 bigthumbsup
777ER
Crew
Thu Jan 25, 2007 7:12 pm
Those doors are massive compared to the other picture, or is the first picture of an emergency exit? The windows also look bigger
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/75/90,A319/20/21,A332/3,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC,FJ
scouseflyer
Thu Jan 25, 2007 7:19 pm
Quoting 777ER (Reply 4):
The doors and windows on the 787 are bigger than normal but not quite a big as they look here as there's a frame to plug into those holes before doors/windows are added.
oldeuropean
Thu Jan 25, 2007 7:42 pm
Looks like a KLM fusselage. I first thought it was from a DC8, but the size of the windows doesn't fit. They were larger.
Axel
[Edited 2007-01-25 11:52:17]
Wer nichts weiss muss alles glauben
ehho
Thu Jan 25, 2007 7:50 pm
Quoting Jetjack74 (Thread starter):
Quoting Oldeuropean (Reply 6):
Looks like the front section of a KLM DC8.
Nah guys, it looks much wider than any of those two. My bet it's a widebody. Perhaps a KL DC-10? Look at those blocked windows left of the door, looks like a galley on starboard...
[Edited 2007-01-25 11:52:39]
"Get your facts first. Then you may distort them as much as you please" -- Mark Twain
oldeuropean
Thu Jan 25, 2007 7:57 pm
Quoting EHHO (Reply 7):
Nah guys, it looks much wider than any of those two. My bet it's a widebody. Perhaps a KL DC-10? Look at those blocked windos left of the door, looks like a galley on starboard...
Yes, could be a DC10.
Photo © Ramon Berk - BerkAviation
But for a DC10, aren't the windows to large?
Axel
N747PA
Thu Jan 25, 2007 10:24 pm
Could it be a 757-300? If you look closely at the ATA photo, you see a production break 5 windows aft of the door.
Photo © Carlos Aleman - SJU Aviation Photography
Photo © Konstantin von Wedelstaedt
[Edited 2007-01-25 14:33:59]
oldeuropean
Thu Jan 25, 2007 11:07 pm
Quoting N747PA (Reply 9):
I don't think so. These are KLM colors.
Axel
oldeuropean
Thu Jan 25, 2007 11:34 pm
Uups, after searching the photo data base it looks that it isn't KL. The white line ist too wide for KL colors.
Axel
[Edited 2007-01-25 15:37:29]
LifelinerOne
Thu Jan 25, 2007 11:43 pm
It isn't a DC-10. If it was, there would be a white outlining of the doors. Also, a DC-10 door (looking at the KLM DC-10 picture) is higher and comes more in the light blue area.
I first thought that it could be a part of PH-BTC, a B737-406 which suffered damage beyond repair at Barcelona in 2005. However, looking at those pictures I can't seem to fix this piece into that...
So, maybe it's a fake piece of fuselage?
Cheers!  wave
Only Those Who Sleep Don't Make Mistakes
Vasu
Fri Jan 26, 2007 2:07 am
I don't think its KLM either... the grey underbelly is too low down in this photo...
Morvious
Fri Jan 26, 2007 3:44 am
It is not KLM for shure!
If I am correct it is a test fuselage (part) for painting. Ive seen it before around these forums.
have a good day,
HereThen
beech19
Fri Jan 26, 2007 4:19 am
Given that its at BFI i would assume its either a 737 or 757 fuse section.
That's this
THAT is not a production fuse for the 787... that is a test barrel (two joined together actually).
KPAE via KBVY
Magyarorszag
Fri Jan 26, 2007 4:26 am
Quoting Oldeuropean (Reply 8):
Of all the DC-10s that have been used by KLM, none were broken up while wearing KL livery. All went to another airline.
Cheers.
jetjack74
Fri Jan 26, 2007 4:41 am
Quoting Beech19 (Reply 15):
Yeah I know, but just posted that in response to a previous thread.
Made from jets!
skytony
Fri Jan 26, 2007 5:43 am
http://www.airliners.net/open.file/0756434/L/ Maybe a test painting but does anyone think its a jet escape for a 767?
Lower your expectations! You will always be pleasantly surprised!
beech19
Fri Jan 26, 2007 6:11 am
Quoting Skytony (Reply 18):
You may have it here actually... Boeing broke up one of the first(i beleive it was the first) 767 to use in various peices for various things.
The forward fues/section 41 peice is at the Future Of Flight outside. The Wingstub/Center tank and Right wing is at the ERC Training facility near Boeing and this looks to be a peice (same exact paint that is on the Wing stub section) from that aircraft.
Considering that Jersey barriers are 3ft tall so that fence would be about 9ft or so.
It COULD be a 767... i'll be down there tomorrow so i'll check it out.  Smile
KPAE via KBVY
jetjack74
Fri Jan 26, 2007 9:10 am
Quoting Beech19 (Reply 19):
It's a narrowbody, i'm positive of that.
Made from jets!
cftoa
Fri Jan 26, 2007 9:39 am
I am almost 100% sure that this fuselage section is that of a 757. One thing I always noticed when traveling on them, is the very narrow exits and emergency hatches. The windows also seem to match that of a 757.
Cheers.
Cessna057
Fri Jan 26, 2007 9:50 am
Looks like the aft section to the 753...
[Edited 2007-01-26 01:51:45]
Hold it . . . Hold it . . . HOLD THE FREAKIN NOSE UP!!
skytony
Fri Jan 26, 2007 10:34 am
If not a 767? Maybe the jet escape for the new 737-900 ER?
heavy747
Fri Jan 26, 2007 10:59 am
Could it possibly be a section of an old 707? If memory serves me right, they had a rather small emergency exit.
Andrew
Aviation Enthusiast - AvgeekYVR - RTW Travel Solutions
Vasu
Fri Jan 26, 2007 11:12 am
Quoting Cessna057 (Reply 22):
I can't imagine they'd have broken up a 753!
NorthstarBoy
Fri Jan 26, 2007 12:19 pm
didn't kl phase out their 8 door 763s recently? i'm wondering if it could be part of one of those?
Yes, I'd like to see airbus go under so Boeing can have their customers!
access-air
Fri Jan 26, 2007 1:11 pm
Could the 12385 be the construction number of the aircraft???
Looks to me like it might be from a DC10...of course there is a section where this could have fit on a 747.....it is tho definately an ex-KLM bird...
Access-Air
Remember, Wherever you go, there you are!!!!
flighttester
Fri Jan 26, 2007 2:09 pm
It is a paint test section. The thing is constantly changing colors. Boeing uses it to test paint colors and schemes prior to painting the real thing.
jetjeanes
Fri Jan 26, 2007 2:13 pm
Judgeing by the doors a Klm Dc-10.
i can see for 80 miles
beech19
Fri Jan 26, 2007 3:50 pm
Quoting Access-Air (Reply 27):
Where on a 747 could that peice fit? Its almost half the width of a 747...
KPAE via KBVY
LTU932
Fri Jan 26, 2007 3:58 pm
No. The door is too small. I guess it is a 767, because of the door. I don't know which type of door that is, but it's definitely more or less the same size as the number three door on 767s with 8 doors.
I recall seeing a picture once of something similar, I believe I saw it here in the database. It was a fuse barrel of a 767 that was being used for painting tests. Since this barrel is at BFI, it could make sense since BFI has a paintshop there and widebodies sometimes go to BFI for their paintjob before delivery.
LTU932
Fri Jan 26, 2007 4:06 pm
I found the picture in question, although it's not from BFI, but from PAE. Sorry for the doublepost, but to avoid editing my post, here it is:
Photo © Jim Newton
beech19
Sat Jan 27, 2007 10:05 am
Quoting LTU932 (Reply 31):
Someone at Boeing BFI please correct me if i'm wrong as i'm at Everett... but last time i checked i was pretty sure BFI didn't have a paint bay large enough for widebodies... 737/757 only...
I've never heard of a large aircraft being painted at KBFI...
KPAE via KBVY
LTU932
Sat Jan 27, 2007 10:44 am
Quoting Beech19 (Reply 33):
Photo © Julian Garcia
Unless I'm mistaken in my interpretation of this picture, this looks like a widebody paintshop at BFI. Feel free to correct me though, as now I'm confused as well.
pygmalion
Sat Jan 27, 2007 11:16 am
That chunk of fuse I believe is a 767 but for sure it is a paint test. The airplane chunks are leftovers from the early eighties and the static and fatigue test articles. There is a whole "boneyard" of test parts up in Everett near where the test facility is. They keep some just for future reference. There are old 747 sections (tested to 3 lifetimes) and the 777 and 767 test parts. They keep the old fatigue test articles just in case they find something is service to compare it to the test sections. But some like the static test pieces don't have much use. They hang around in case we need them for things like Lets paint one and see what the sun does to the paint. It is a controlled experiment. They know exactly how much sun it got, how much it was washed. etc. They go out every so often and check the paint to the color chip and measure paint gloss, chalking, flaking etc. The paint color is most likely what they had laying around in the right spec. The top blue looks like the KAL blue to me.
jetjack74
Sat Jan 27, 2007 1:08 pm
Quoting Beech19 (Reply 30):
Never said that. I think it's a 757.
Quoting Pygmalion (Reply 35):
It's not a widebody, it's a narrowbody for sure, A 757. But my question was is this a part of a scrapped airframe, or just a piece of a static fuselage
Made from jets!
Cessna057
Sat Jan 27, 2007 2:22 pm
It cant be a jet escape guys this an old piece of an airplane. Look at the picture of the 787 jetescape and look at how nice it looks and then look at the plane in question. If it isnt a 757, it is possible that it is an old 707 jet from somewhere, not sure of where it could be from though.
Also, it kinda looks like a freighter, if you look at how the windows are painted in that makes sense.
And how is everyone saying a KLM bird. Yes the scemes are similar but the gigantic white stripe vs. the smaller one on current KL birds are totaly different..
Vasu
Sat Jan 27, 2007 7:06 pm
Quoting Cessna057 (Reply 37):
The answer's already been found...
It was part of a 767
beech19
Sun Jan 28, 2007 1:02 pm
Quoting LTU932 (Reply 34):
Hm... that picture certainly is showing a widebody in a paintshop... i'm doing more investigation.
Buildings 3-369 and 3-380 at Boeing Field are paint hangars. From what i'm finding it looks like 3-380 COULD be large enough to paint widebodies. 3-369 i beleive is a side by side segmented bay for 737's. Since there is only one paint hangar at Renton they need them available ASAP as they have to paint a new 737 every day effectively.
I guess that picture really could be from BFI. You just NEVER see an unpainted 747, 767, 777 leaving Everett. The LCF i'm positive will be painted at PAE. Maybe not by Boeing though. It may be done by Goodrich at the south. They have a paint bay large enough for all aircraft. Only time will tell.  Smile
KPAE via KBVY
Sun Jan 28, 2007 2:29 pm
Anyone can get a side on View of the same.
regds
MEL
