ricardofg
YYZ - Will Terminal 3 Be Renamed?
Fri Jan 26, 2007 1:40 am
This may be a silly topic, but I was curious...with Terminal 2 closing the doors for good next week, there will now only be Terminal 1 and Terminal 3 which makes me wonder, would they rename T3 to Terminal 2??? It would only make sense would it not? Or would it only cause confusion with travellers???
N1120A
RE: YYZ - Will Terminal 3 Be Renamed?
Fri Jan 26, 2007 2:05 am
The general consensus has been to not renumber terminals when one is consolidated out of existance, though that is not a steadfast rule. For example, there is no Terminal 1 at PHX in honor of that airport's first terminal that was torn down some years ago. Similarly, BOS recently stopped calling the stub gates between C and E Terminal D and include them with the connected Terminal C now. They have not, however, renamed international terminal E.
airbusfanyyz
Fri Jan 26, 2007 2:08 am
No.
It will be T1 and T3 at YYZ.
Kaz
Gr8Circle
Fri Jan 26, 2007 2:29 am
Doesn't really make sense to me.....in the short term there could be some confusion, renaming the existing T3 to T2, but in the long term it makes a lot of sense to rename if there are going to be only 2 terminals.....
cayman
Fri Jan 26, 2007 2:43 am
I think in the very long term T3 is either going to be torn down or eventually linked into the new T1 superterminal anyway so way down the road there may not be any need for numbered terminals but rather perhaps lettered piers etc.
apodino
Fri Jan 26, 2007 2:48 am
Quoting N1120A (Reply 1):
However the plan is for them to rename terminal E to terminal D sometime later this year.
airbusfanyyz
Fri Jan 26, 2007 4:34 am
Quoting Gr8Circle (Reply 3):
See page 18 in link below.
http://www.gtaa.com/documents/news/MasterPlan/master_plan_chapter4.pdf
Excerpt:
"The ultimate terminal development plan, illustrated in Figure 12, calls for a unified, single terminal building with 6 piers radiating from a common horseshoe-shaped central processing facility. The ultimate concept, which would be developed once Terminal 3 has reached the end of its operational
life, will have 135 bridged gates, and the capability to process up to 55 million passengers annually, matching the ultimate capacity of the six
runway system."
Kaz
swissy
Fri Jan 26, 2007 5:01 am
Quoting AirbusfanYYZ (Reply 6):
That is a long term plan as of today, who knows what will happen until then
But for now it is T1 & T3.
sunrisevalley
Fri Jan 26, 2007 5:58 am
runway system."
There is four at present ?
YYZatcboy
Fri Jan 26, 2007 6:29 am
5 and they are building another east west rwy.
DH1/3/4 MD11/88 L1011 A319/20/21/30/80 717 727 735/6/7/8/9 744 762/3 77E/W E40/75/90 CRJ/700/705 CC150
J/S DH8D 736/7/8
Gr8Circle
Fri Jan 26, 2007 6:33 am
I do suppose T3 still has another 15-20 years useful life remaining....it would be a shame to tear it down sooner than that....
ricardofg
Fri Jan 26, 2007 7:39 am
I really think the new extension on T3 is quite beautiful
