sk909
Wheels Out
Thu Feb 01, 2007 5:45 am
Hi there,
I was in EWR Monday, leaving for CPH. While waiting to board my own plane I was watching some of the many planes taking off.
During this I watched a NWA A330 take off. What struck me was that it was not retracting its gear... I watched the plane for a long, for longer than 60 seconds, and it still didn't retract the gear. And it didn't return to the airport. Now is that normal procedure for NWA to spend money in this way? I mean having the gear out must create some kind of drag... Or is it a way to keep speed down so that it won't catch up with the slower moving Boeing...  Wink Just kidding... No need for reprisal...  Smile
Any I idea why the gears were down for that long?
Life's for Living!
Scooter01
RE: Wheels Out
Thu Feb 01, 2007 5:52 am
Hi Denmark!
If you had read some of the previous topics in this forum, mainly in Tech/Ops.
you might also think about cooling the brakes to avoid heat transfer to the tires. Wink
S
sk909
RE: Wheels Out
Thu Feb 01, 2007 5:58 am
Quoting Scooter01 (Reply 1):
Great answer... That may just have been it...
Life's for Living!
RE: Wheels Out
Thu Feb 01, 2007 3:41 pm
At Times The Landing Gear is left Extended Delibertly by the Crew to assist in quick cooling of warm brakes from the Previous Landing which did not get enough Cooling time of the Ground.
As mentioned a Search will find a few posts on this topic in more detail.
regds
MEL
S12PPL
RE: Wheels Out
Thu Feb 01, 2007 4:01 pm
NW flies A330's into EWR????
Next Flights: 12/31 AS804 PDX-MCO 2/3 AS19 MCO-SEA QX2545 SEA-PDX
HPLASOps
RE: Wheels Out
Thu Feb 01, 2007 6:16 pm
I've had that happen to me flying LAS-MSP on an A320 - capt left the gear down for approx 5 mins after dept to let the brakes cool down.
"Just because I know how to get off a freeway doesn't mean I know how to get back on!" - Retard Joe
Mir
RE: Wheels Out
Thu Feb 01, 2007 6:41 pm
Quoting S12PPL (Reply 4):
Must be the EWR-AMS flight that they've been splitting with KLM for the past few months.
-Mir
Charliejag1
RE: Wheels Out
Fri Feb 02, 2007 12:27 am
Why are the brakes that hot after takeoff? I mean, you use the brakes taxiing, but that shouldn't heat them up enough to necessitate cooling. Also, if you hold the brakes when spoolnig the engines up this will NOT heat them up, as there is no friction.
It's no coincidence that this thread only mentions Airbus aircraft having this issue . . .
IAHFLYR
RE: Wheels Out
Fri Feb 02, 2007 12:40 am
Quoting Charliejag1 (Reply 7):
I have seen it done many times with Boeing and Douglas aircraft as well in the past, so not sure it is simply an Airbus issue.
RE: Wheels Out
Fri Feb 02, 2007 2:38 am
The Brakes would have been hot after the Previous landing & not aving enough cooling time during its transit time,hence was extended for further cooling.
Remember sometimes long taxiing can heat the Tyres not brakes.
regds
MEL
Charliejag1
RE: Wheels Out
Fri Feb 02, 2007 2:52 am
Quoting IAHFLYR (Reply 8):
I'm not saying it has only ever happened on Airbuses, that would be incredulous.
Quoting HAWK21M (Reply 9):
True, that is possible, expecially depending on load, location, and conditions.
S12PPL
RE: Wheels Out
Fri Feb 02, 2007 3:25 am
Quoting Charliejag1 (Reply 10):
But you are accusing the thread starter of only naming Airbus...For whatever your reasons....
Quoting Mir (Reply 6):
Ah. I hadn't heard about that yet. Cool.
