B752OS
AC Moving In BOS
Fri Feb 02, 2007 4:35 am
Per the Massport website, AC will be moving to terminal B, from their original location in Terminal C.
Could this mean more gates for FL and B6?
PVD757
RE: AC Moving In BOS
Fri Feb 02, 2007 4:46 am
hmm, AC (Air Georgian) is moving at PVD too starting in March, they will be with CO at gates 7 & 8 instead of UA at gates 9 & 10...
N1120A
Fri Feb 02, 2007 4:50 am
Quoting B752OS (Thread starter):
Not if United has anything to say about it, given that those are their gates. Also, B6's gates are on the other side of C, which has a different checkpoint.
Probably to be handled by US.
SNATH
Fri Feb 02, 2007 4:52 am
You're kidding me... I hate Terminal B... If this is true, that'd be AC's 2nd move at BOS (in the late 90s they were actually based in Terminal E).
Terminal C has two non-connected peers. B6 are actually on a different one where UA/AC are located. So, I can't see how B6 will get more gates.
Tony
Nikon: we don't want more pixels, we want better pixels.
COERJ145
Fri Feb 02, 2007 4:54 am
Are they moving to the B1-B3 gate area(the Ex-DL Shuttle gates)? I heard on a past topic they would be.
SNATH
Fri Feb 02, 2007 4:55 am
Quoting SNATH (Reply 3):
Quoting N1120A (Reply 2):
Actually, good point. If it's US' part of Terminal B, it'd be fine. I automatically thought of AA's B peer...
Tony
B752OS
Fri Feb 02, 2007 4:56 am
Both B6 anf FL have expressed interest in getting more gates at BOS. When you consider that BOS is not a large transit operation for both airlines, having gates in both piers of C is not a problem.
SNATH
Fri Feb 02, 2007 4:58 am
http://www.massport.com/about/press_news_AirCanada07.html
Effective February 1, 2007, Air Canada and Air Canada Jazz will relocate from Terminal C to Terminal B (U.S. Airways side).
N1120A was right...
Tony
SNATH
Fri Feb 02, 2007 5:00 am
PS Will this mean that AC's passengers will have to use the US FF lounge? I'm not complaining! It's actually much nicer than UA's...
Tony
[Edited 2007-02-01 21:00:45]
quickmover
Fri Feb 02, 2007 5:02 am
How many gates did they have?
COERJ145
Fri Feb 02, 2007 5:07 am
Actually 4(add the former DL connection one and the former "D" gates where FL is).
It could. It would be more conveinent if FL made a connector hall from their gates on the UA section of C to their main gate area(the former "D" gates).
deltairlines
Fri Feb 02, 2007 5:10 am
I don't know if the former DL shuttle gates (B1-B3) would be able to accomodate a plane the size of an EMB-190 - the DL Connection gates (A9-A12) are right there, so it would be tough to get anything more than a Dash into B1-B2 (B3 should be able to take an A320 sized plane fine)
COERJ145
Fri Feb 02, 2007 5:20 am
Quoting DeltAirlines (Reply 11):
Apparently they can, I just checked the Arrival/departure board for BOS, according to it AC is arriving/departing from B1/B2. I havn't seen B3 up there yet.
airbazar
Fri Feb 02, 2007 6:20 am
Yeah, this was announced last month. Sort of makes sense since US is the largest *A member at BOS and AC does not need FIS facilities (which they did not have at C either but were just a stone's throw from terminal D formerly known as E). It's ironic that of all the legacy carriers at BOS, UA is the one that's better positioned to offer International service (after NW), and yet they don't offer anything.
I say this because for those who know BOS, transfering between terminals C and D is not all that difficult, whereas transfering between A/B and D is a bit of a commute.
SafeFlyer
Fri Feb 02, 2007 7:53 am
Interesting, I had heard of it for a fairly long time now. AC was apparently partly unsatisfied by UA ground handling and the fact that they had 2 gates only in C causing constant delays (been there, experienced it several times) since for instance, we would come in from YOW while the YHZ flight was still at the gate. When you have 20-30 minutes to turn around a CRJ, you can't take that delay. I just wonder where AC will move it's check-in counters since they won't be handled by US Airways CSA as they have their own staff in BOS.
'Safe
COERJ145
Fri Feb 02, 2007 7:57 am
Quoting SafeFlyer (Reply 14):
There is some counter space next to the HP/US desks. There may be some over by the US Shuttle/AS counters, I'm not sure though.
easyfriday2000
Fri Feb 02, 2007 8:14 am
Hey there.
US airways will be ground handling. This is due to a couple differnt factors. one being United did not do a very good job for us. Also AC wanted another gate to increase flights and decrease delays and United would not work with us. We will be in gates b1 b3. It wont be a problem with the aircraft we fly to bos. The gates were designed for 3 737. We can park up to a 321 on 3 and a 320 on b2 a e190 on b1. All the computer systems will be updated and we will have self checkin kiosk. the ticket counter is in the corner by the gates and US airways. Hope this helps
RP TPA
Fri Feb 02, 2007 8:27 am
Quoting Easyfriday2000 (Reply 16):
Have you heard anything specific about new flights?? Rumors??
easyfriday2000
Fri Feb 02, 2007 8:38 am
Well there have been rumors of a quebec city in the summer. More flights to yyz in the peak seasons. A 4 yhz flight and a yvr flight. But i have heard that the yvr flight will not happen until 2008. But who knows. Until this summer i dont think we will be getting any flights. I think the best thing to come out of this move is that the gates are actually air canada gates. Before this we have always used someone elses which sooner or later became a problem. And at terminal c there was always at least one flight holding for a gate at around 7pm sometimes for an hour. This will give us more options
LH423
Fri Feb 02, 2007 8:42 am
Quoting SNATH (Reply 5):
Knowing that you have status with AC you won't like this move. They'll be using B1-B3 which are the former DL Shuttle gates, therefore pax travelling on AC will no longer have lounge access (if they previously enjoyed that perk through the UA lounge).
You can. When the gates were vacant US would park A319s on those gates all the time for RONs. And, at least this winter AC isn't scheduling anything larger than a E195.
There are several available counters at Terminal B, actually a perfect number for Air Canada's requirements. Also with larger floor area than what they had in Terminal C they have a possibility for kiosks, if Air Canada offers that service in the States (I don't know). It's US' counter space but several airlines have, and have had, their own agents despite using those counters. Spirit and Independence are two that come to mind that use(d) the US counters but were staffed by their own people.
Having been a frequent traveller on AC, I will appreciate the move simply for the fact that AC was strapped for gates at Terminal C. They didn't have the option of using another gate in a pinch and was commonplace to arrive and have to sit on the tarmac for 15-20 mins for a gate to become free. With three gates they'll have more flexibility. Also, apparently according to an Air Canada employee in BOS they weren't that happy with UAs ground handling, so we'll see if US can do it better. From a passenger point of view, this SUCKS. Star Alliance gold passengers will lose lounge access as the gates AC will be using will have their own checkpoint not allowing access to the US Airways club. The departure lounge is literally a room with doors. There are no amenities beyond the checkpoint and the only services on that side of the terminal are a newsstand and a Starbucks. There is a restaurant and a Dunkin' Donuts on the other side down by the US Airways Shuttle counters. But nothing like what US Airways has inside security. I know they laid new carpet down so at least it won't be the gross, stained red carpet that has been there since Piedmont was still flying. But in terms of passenger services this is a bad move.
LH423
« On ne voit bien qu'avec le cœur. L'essentiel est invisible pour les yeux » Antoine de Saint-Exupéry
easyfriday2000
Fri Feb 02, 2007 8:56 am
So
Quoting LH423 (Reply 19):
so not having to sit on the tarmac for 30 minutes is not a improvement in passenger service. I know that AC is making it possible for our passengers to use the US lounge the only thing is they would have to go through security twice. But security to the AC gates should be a breeze since there is no other airline there. Also there will be a little sanwich bar in the holding area with coffee bagels stuff like that. I do agree that you wont have as much room but i think most pax are wanting an on time flight more than a meal. oh and we have 319s in the schedule right now. Also i put in my last post that the gates will take anything we ever see up to a 321. So if we had two 320s and a e190 it would be no problem. And we will have 6 self check in kiosk for the pax in boston
regards
COERJ145
Fri Feb 02, 2007 10:00 am
Quoting Easyfriday2000 (Reply 20):
Any possibility of AC adding a walkway like US has between their main and their shuttle gates?, or at least a walkway to the US club?
deltairlines
Fri Feb 02, 2007 10:06 am
Quoting COERJ145 (Reply 21):
Probably would cost too much money. It's no more than a 3-4 minute walk over to the US security area, and the number of connections will probably be minimal. If anything, a small bus would probably be more cost-effective than a walkway (US needs one since there's a good amount of connectivity between the Shuttle gates and the regular gates), but for the number of people that would be affected, it's probably not even worth the cost.
BTW, at MHT, CO is already handling the Air Alliance flights...I've seen them park Beechs at Gate 1 lately instead of Gate 5, which is a UA gate.
COERJ145
Fri Feb 02, 2007 10:44 am
Quoting DeltAirlines (Reply 22):
They actually installed a walkway between mainline/express and the shuttle gates, very convienent.
easyfriday2000
Fri Feb 02, 2007 10:50 am
Ya i dont see why Massport would put a walkway. Honestly if you want to go to the Us air club and you had 2 hours to kill it would take maybe 15 minutes to go through security and back. Im not saying this move will be 100% better but it will be better for the pax in terms of on time departures as well as more flights
LH423
Fri Feb 02, 2007 12:48 pm
No, I was saying the opposite. This move will be a good thing for that. More gates equals less wait time.
Good to know they'll at least have something. Yes, even with Toronto being the longest flight at not even 90 mins, it's still nice to have the option if you decide you want something quick and last-minute.
Speaking of long flights, any chance that the BOS-YVR flight will be returning at any point?
LH423
easyfriday2000
Fri Feb 02, 2007 1:23 pm
Hey LH 423
I know that the yvr flight is a possibility especially in the summer. I have been told that the reason it was taken away was gate space in BOS and aircraft availability. The flights were always full and we made money on the cargo alone. So we will see. I know that with the extreme makeover going on there is a limited # of 319 320 available.
LH423
Fri Feb 02, 2007 3:55 pm
Quoting Easyfriday2000 (Reply 26):
Figures! I always wanted to nonrev on that flight but it never was around when I worked at BOS. Now I don't live there and it possibly might come back!  banghead
LH423
SNATH
Fri Feb 02, 2007 11:12 pm
Yikes and bummer! This is pretty disappointing.  Sad
The UA lounge is basic at best, but it beats sitting in the terminal any day...
Why do they need to make it possible? I thought that *A rules are that, if you have a boarding pass on a *A flight and you can get lounge access, then you can access any *A lounge. Ah, you probably mean that you'll be allowed to go through security to access the lounge...
Quoting Easyfriday2000 (Reply 24):
Given what a pain in a  butthead  going through security is these days, I doubt I want to do it twice... The bus that DeltaAirlines recommended would actually be a good idea...
Tony
