flyboy80
Embraer 170 Engine Sounds
Sat Feb 10, 2007 1:57 am
I may be mistaken, but the E jets feature the same engines as the CRJs correct? CF-34? Im just curious if they also sound like the CRJs with the high pitch sounds, or if they are a deeper grumble simular to that of other wing mounted engine types, such as the 737, Or A320series...
eraugrad02
RE: Embraer 170 Engine Sounds
Sat Feb 10, 2007 2:15 am
Actually no. The more powerful CF-34's from the CRJ-700/900 are the same as the E-JETS. The sound is to me more inline with the CFM International engines from the 737/A320's. This is my .02.
Desmond MacRae in ILM
mrocktor
Sat Feb 10, 2007 2:41 am
The E170 has CF34-8 engines, similar to the CRJ700/900 engines. The E190 has CF34-10 engines, which use an altogether different core (scaled down from the CFM56).
Both E170 and E190 sound less whiny than the CRJs, in my opinion. Engine placement may have more to do with that than the engine type - as you mentioned.
NASBWI
Sat Feb 10, 2007 3:10 am
Quoting Mrocktor (Reply 2):
True...from the inside. I haven't flown on an E170, but sitting forward of the engines on a 190, it sounds much like a quieter 737 (very faint 'groan' of the compressors on takeoff, and a little whine). From the outside though, I've noticed, the E-jets are rather loud. Compared to the CRJ series, they have a much louder roar from their exhaust (about as loud as a 737-3/4/500). Anyone else notice that?
Fierce, Fabulous, and Flawless ;)
flyboy80
Sat Feb 10, 2007 3:22 am
perfect guys, thats just what I wanted to know!
drewwright
Sat Feb 10, 2007 6:05 am
Also it depends on where you are sitting on the plane. The back is like riding in a 767, or like we like to think the space shuttle. Its a roaring noise. While in the front, its a fan noise with a rumble. If you are lucky to sit in the front, some pilots use a "climb 1" power setting that actually adds more power to the engines after takeoff. There is a definate whine during these takeoffs.
http://www.youtube.com/watch?v=poQ6VeXFU04
http://flightlevel350.com/Aircraft_E...ir_Canada_Aviation_Video-4286.html
B6JFKH81
Sat Feb 10, 2007 6:23 am
I love the sound of the E190 when it starts up here at the Hangar. It is such a low-pitched moan that you feel it through your body.
Cody
Sat Feb 10, 2007 6:37 am
Does anyone else feel like the 170 puts out a LOT of thrust on take-off. It really seems to push you back in your seat. I would compare it to the same feeling that a 757 puts out on take-off.
S5FA170
Sat Feb 10, 2007 6:47 am
Quoting Cody (Reply 7):
The E-170 has the highest thrust:weight ratio of the E-Jet series. It is quite a powerful little airplane. I enjoy working on them, and the takeoff is one of the reasons why! Also, go-arounds in the -170 are fantastic, and so are ferry flights. When that plane is empty - their is no holding it back.
Prepare doors for departure and cross-check.
drewwright
Sat Feb 10, 2007 7:19 am
I worked a repo from JFK to LGA last year. Awesome. No PAX and 8k in fuel. I took a vid from takeoff to touchdown and the flight lasted just over 14 minutes. BTW our cruise for the flight was 2,000. It was awesome. Takeoff roll was on 22R and we were off befoer the displaced threshhold. About 2000 ft.
Drew
PS. anyone who wants the vid email me.
flyboy80
Sun Feb 11, 2007 1:41 am
Does anyone know where the 170/175 play in with wing area compared to the CRJ900, and the 737/3/4/5? Just curious about that as well.
Cody
Sun Feb 11, 2007 1:52 am
Quoting Flyboy80 (Reply 10):
The 170 wing-span is 85 feet 4 inches. Is that what you mean? I don't know about the others.
rikkus67
Sun Feb 11, 2007 2:35 am
Drewwright...
Sure, love to see the vid...but yer email addy is withheld!
AC.WA.CP.DL.RW.CO.WG.WJ.WN.KI.FL.SK.ACL.UA.US.F9
flyboy80
Sun Feb 11, 2007 8:33 am
No i mean actual wing area of the 170...sq feet...etc
drewwright
Mon Feb 12, 2007 12:31 pm
I fixed my addy prob. Email me ifyou want the vids.
Seeya,
Drew
