SiouxATC
DL's West Coast Widebody Routes
Mon Feb 12, 2007 3:51 am
Ive been reading on a.net that DL is going to stop running thier widebodies in the US. Will this mean that ATL-LAX,SFO,LAS, SEA, SLC, PHX, and PDX routes will go from 763/764s to 757s? And in the case of ATL-LAX I am surprised to see a 777 still on the sched. for this summer. Will this remain? or is it just tenative?
md90fan
RE: DL's West Coast Widebody Routes
Mon Feb 12, 2007 4:28 am
I don't really know if you count it West Coast, but DL does ATL-ANC with a 763.
http://www.devanwells.blogspot.com/
Evan767
Mon Feb 12, 2007 4:36 am
Quoting SiouxATC (Thread starter):
Don't forget SAN. PHX doesn't get any widebodies for the summer.
drerx7
Mon Feb 12, 2007 4:41 am
I don't know why everyone thinks DL will stop running widebodies domestically-some routes require the lift, you will always see 767s to FL and CA from DL.
Third Coast born, means I'm Texas raised
1337Delta764
I doubt it. There will always be routes that warrant widebodies. Even with the ex-TWA 757s, Delta simply doesn't have enough 757s to handle all of the domestic widebody routes. Either way, those ex-TWA 757s will mostly be used on lesser Hawaii routes such as to OGG or KOA, and on third-tier transatlantic routes.
jkudall
Mon Feb 12, 2007 6:11 am
It isn't just west coast. Many domestic flights previously flown with wide-body aircraft are being replaced with other aircraft. DL has been shifting the wide-body aircraft to Int'l flights.
There will still be some domestic wide-body flights, but not as many as there used to be.
SESGDL
Mon Feb 12, 2007 6:53 am
The number of domestic widebodies has been the same as for the past year and will remain that way. DL's 24 domestic 767-300s will continue to operate domestic widebody flights to places like JAX, MCO, TPA, FLL, SAN, LAX, SFO, SEA, LAS, PHX, DEN, etc. Eventually all 767-400 aircraft may be moved to international, but there will still be a moderately-sized fleet of 767-300s to operate domestic routes.
Jeremy
DAL767400ER
Mon Feb 12, 2007 6:43 pm
Quoting SESGDL (Reply 6):
Add in HNL and OGG, which should go 763 once DL needs another batch of 764s for int'l flights. And as a sidenote, the non-ER 763s are used for international flights as well, namely MBJ on a regular basis, and depending on season, PTY, GUA and SJO.
ConcordeBoy
Mon Feb 12, 2007 10:07 pm
That's because it's the spare that doesn't op revenue until its morning Asian flights have successfully departed.
