T773ER
757 With Fly-By Wire
Mon Feb 12, 2007 6:02 am
I was watching a documentary on building the 777, called "The Building of a 21 First Century Jet", when I heard that Boeing had a 757 outfitted with the fly-by wire a 777 uses. I was wondering, does anybody know were or what happened to this plane?
N1120A
RE: 757 With Fly-By Wire
Mon Feb 12, 2007 6:03 am
Quoting T773ER (Thread starter):
That plane is the first 757 off the line and serves as Boeing's test mule, mainly operating out of BFI.
AA777223
Mon Feb 12, 2007 8:59 am
Why was this technology not translated into the production versions? If this technology was available when the 757 was built, why did we have to wait until the 777 came along to see it? Why didn't we see it in the likes of the 737NG, etc.?
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175/190, DH-8, ATR-72, DO-328, BAE-146
DfwRevolution
Mon Feb 12, 2007 9:36 am
Quoting AA777223 (Reply 2):
Airlines did not want to upset commonality with their in-service fleets. You are talking about massive system overhaul to convert an aircraft into FBW. It would neutralize any cost savings obtained by using FBW in the first place.
* - as a comparison, bear in mind that Airbus didn't convert the A300 to FBW flight controls once FBW was implemented in commercial aircraft like the A320 and A330/A340.
The technology was not yet available in the late-70s when the 757 was produced. At the time, fleets were still transitioning large aircraft into two-man cockpits and introducing the first glass instruments. However, the 757 does have a few electronically activated flight controls, just not the primary surfaces.
First and foremost, the key launch customers wanted commonality with previous generation 737.
Not to mention, there was no reason to fit FBW into the 737NG. FBW is used to reduce aircraft weight, increase dispatch reliability, and improve safety. The 737NG series are already lighter than the A320 variants, they have demonstrated higher dispatch reliability, and have incurred fewer fatal accidents. It would have also cost millions and millions of dollars to retrofit FBW, prolonged the development cycle, and required additional certification. All in all, it just didn't make sense for the 737NG.
[Edited 2007-02-12 01:37:46]
N1120A
Mon Feb 12, 2007 9:41 am
The technology was available in military aircraft before the 757, but the 757/767 program was not developed with it. The 757 in question was retro-fitted with the FBW system as part of the testing for the 777.
Because that was Boeing's first new airplane project since the test.
If Boeing had gone FBW on the 737NG, it would not have been able to use the same type certificate and have a common type rating with previous 737s. Further, the 737NG's lighter relative weight to the A32S and high dispatch reliability show less of a reason for FBW
Max Q
Mon Feb 12, 2007 9:46 am
There is one FBW flight control on the 757 /767, that is the speed brake.
AA777223
Mon Feb 12, 2007 1:33 pm
Quoting Max Q (Reply 5):
Hence the movement of the spoilers when banking?
flyboyseven
Mon Feb 12, 2007 2:03 pm
Quoting AA777223 (Reply 6):
Dont the spoilers on all Boeing aircraft move with bank?
As long as the number of take-offs equals the number of landings...you're doing fine.
Mon Feb 12, 2007 10:43 pm
Spoilers are FBW on the B757.
regds
MEL
Max Q
Tue Feb 13, 2007 3:49 am
The speedbrake operates the spoilers.
mcdu
Tue Feb 13, 2007 4:33 am
Quoting DfwRevolution (Reply 3):
I would be very interested to see your supporting data on this statement. Having flown both Boeing and Airbus I am not a huge AB FBW fan due to the logic of the system, especailly in crosswinds. However, your statement I believe is off the mark. The safety record of the 737 is not flawless, lest we forget about the serious issues it has had with the rudder and the flight/ground spoiler switch. Also, the bus sits higher off the ground giving a much better field of view from the cockpit than the runway hugging, cramped cockpit oven that is the 737.
DfwRevolution
Tue Feb 13, 2007 5:39 am
Quoting Mcdu (Reply 10):
None of those issues have effected the 737NG series. The 737NG series has just two fatal accidents after more than 2,000 deliveries and nearly a decade of service. Please find me any aircraft with that distinction. Not even the FBW A320 has performed that remarkably.
Has this been cited as a contributing factor to any accidents with the 737NG series? None that I know of...
N328KF
Tue Feb 13, 2007 5:43 am
Quoting DfwRevolution (Reply 11):
Not only that, but one of those accidents (or 50%) were caused by faults on another aircraft. The remaining accident investigation is not yet complete, but could be either pilot error, or improper component selection by the operator (WN).
AirEMS
Tue Feb 13, 2007 5:49 am
Even though the 777 has FBW doesn't it still have cable / hydraulic back up systems? Does Airbus offer back up systems like this? IIRC Airbus doesn't
-Carl
If Your Dying Were Flying
A342
Tue Feb 13, 2007 6:22 am
Quoting AirEMS (Reply 13):
I don't know, but IIRC, the Airbus FBW system itself is triple-redundant (or was it quadruple ?).
Exceptions confirm the rule.
SEPilot
Tue Feb 13, 2007 6:55 am
I believe it does not; one of the big advantages of FBW is eliminating the cables, as they are a big maintenance headache. The FBW of course retains the hydraulic systems; the actuation is electornic instead of mechanical through the cables.
Wed Feb 14, 2007 12:29 am
Quoting Max Q (Reply 9):
Rather the Aileon mvmt operates the Spoilers in Air to assist the Bank & The Speed brake lever operates the Speed brakes except #4 & 9 in Air & all on Grd.
regds
MEL
mcdu
Wed Feb 14, 2007 12:49 am
Sure the 757/767 had and has had a remarkable safety record. The 777 is even better. The 737NG of course should have better safety record due to the maturation of the product. The 737 has and had many design issues and it is the time in service and previous accidents that have produced a decent safter record to date. I would suspect the Airbus NG will be just a well served but it does have a very good safety record for its advanced systems and controls.
Also to answer the one of the other posters. The 777 is FBW and is not backed up with cables.
