kaitak744
Dubai Will Have World's Longest Runway.
Wed Feb 14, 2007 4:23 am
http://i19.photobucket.com/albums/b154/Kaitak744/dubairunway1.jpg
As you can see, 30L/12R is being lengthened. I used the ruler on Google earth and discovered that when it is finished, it will be 18,700ft!. This makes it the world longest active runway. Now, this may seem like a crazy question, but why would Dubai need it?
lowrider
RE: Dubai Will Have World's Longest Runway.
Wed Feb 14, 2007 4:28 am
Density altitude in the summer perhaps?
Proud OOTSK member
adipasqu
One word...HOT!!!
Filler
Filler
707 722 732 733 734 735 73G 738 739 741 742 752 753 762 763 764 D9S D10 319 320 321 M80 M82 M83 M87 M88 M90 SF3 ERJ CRJ
CV580Freak
Maybe something to do with the summer heat, it can hit 50C and must have an effect upon payload on take off.
One day you are the pigeon, the next the statue ...
BlueElephant
Wed Feb 14, 2007 4:30 am
They're probably working on because its really hot....
And because Dubai likes to build the biggest and bestest.
But I don't understand why they're putting in so much money into DXB. Aren't they already building up on Jebel Ali?
Anyone know the progress of that airport?
N328KF
Wed Feb 14, 2007 4:31 am
Edwards will still have the longest runway.
adipasqu
Even at 18,700 ft, would that still be enough to get an A380 off the ground at 50 C without weight restrictions???
drexotica
Wed Feb 14, 2007 4:36 am
The runway at Area 51 is 25,300 ft (though some of it is on the dry lakebed). It is certainly active...
N707PA - Best looking commercial aircraft ever.
kaitak744
Wed Feb 14, 2007 4:37 am
Quoting N328KF (Reply 5):
Vostochny (Russia) 16404 ft
Gavia (Bravil) 16295 ft
Upington (South Africa) 16076 ft
Harare (Zimbabwae) 15502 ft
Kinshasha Ndjili (Congo) 15420 ft
Mafikeng (South Africa) 15158 ft
Hawange National Park (Zimbabwe) 15091 ft
Edwards AFB (USA) 15013 ft
source - http://googleglobetrotting.com/info.php/mid/10179
kaitak744
Wed Feb 14, 2007 4:40 am
Quoting DrExotica (Reply 7):
True, that is the world's longest runway (and it is actually all paved). However, it is far from active. There are Xs painted over the runway and cracks all over the pavement.
N328KF
Wed Feb 14, 2007 4:44 am
Quoting Kaitak744 (Reply 8):
17/35 at Edwards is 40,000ft, 15/33 is 33,000 ft, 05/23 is 27,500ft, 18/36 is 24,000 ft, 07/25, and 02/20 and 11/29 are 21,000ft.
SLCUT2777
Don't forget that DEN has a runway 16,000' in length!
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
N1120A
Wed Feb 14, 2007 4:45 am
Quoting Kaitak744 (Thread starter):
Why do they need that many A380s? It is a pissing contest.
Quoting CV580Freak (Reply 3):
DXB does have the counterbalance of being at sea level. At a certain point, the tires wont take the speed and having a longer runway is moot. DXB at 50C isn't particularly worse than DEN at 35-40C for density altitude, given that DEN is over 5280 feet.
Um, that must not have been updated in years, given that DEN has a 16,000 foot runway.
ZRH
Wed Feb 14, 2007 4:52 am
Quoting Adipasqu (Reply 6):
You mean a 777, as an 380 needs less runway.
LTU932
Wed Feb 14, 2007 4:54 am
EDIT: Nevermind, I misunderstood you. Anyone know when 30L/12R is going to be re-opened?
[Edited 2007-02-13 20:55:30]
OldAeroGuy
Wed Feb 14, 2007 5:00 am
But if you're at the tire speed or brake energy limit, all the runway in the world won't help you.
Evan767
Wed Feb 14, 2007 5:12 am
Excellent. This will definitely be helpful to DL's 7600 mile service to ATL.
LTU932
Wed Feb 14, 2007 5:22 am
Quoting OldAeroGuy (Reply 15):
 checkmark
Just look at LPB for example. Its elevation is 13325 ft, and its runway is 13123 ft long, which is probably barely long enough for taking off of there with aircraft such as the A320, 757 or even the 747, to somewhere close or to a fuelstop point like VVI. Even if it had an 18000 ft runway, many aircraft would still be highly weight restricted.
GoldenParrot
Wed Feb 14, 2007 5:23 am
Actually the new 30L/12R will be no where near that long. The work in progress is to stagger the two runways so traffic landing/departing from 30R/12L will not have to cross the other runway on the north side. When completed the new 30L/12R will finish about half way down the other runway.
[Edited 2007-02-13 21:24:25]
kaitak744
Wed Feb 14, 2007 5:42 am
Quoting N328KF (Reply 10):
Those lines in the desert hardly qualify as a runway. If you look at Google Earth, 1/3 of runway 17/35 is washed away by the water of that supposedly dry lake bed.
Quoting GoldenParrot (Reply 18):
Thanks for the information! Do you know when this will be finished?
LTU932
Wed Feb 14, 2007 5:45 am
What do you mean by "stagger" the two runways?
CV580Freak
Wed Feb 14, 2007 5:48 am
Quoting BlueElephant (Reply 4):
I believe EK will stay at the refurbished DXB and all other airlines will transfer to Jebal Ali.
Air Cargo will move between airports via a customs bonded highway, not sure about the self loading cargo though...
EI321
Wed Feb 14, 2007 5:57 am
What senairo would require something that long?????????????
LTU932
Wed Feb 14, 2007 5:58 am
Quoting EI321 (Reply 22):
The Space Shuttle perhaps? It does need lots of runway length to roll out.
GoldenParrot
Wed Feb 14, 2007 6:01 am
Don't know how long it will take to finish, but I flew into DXB a few days ago and the work looked about 80 per cent complete.
LTU932, The runways will remain parallel but 30L will end about half way down 30R. You can see the threshold of 30L in the picture at the beginning of this thread.
A342
Wed Feb 14, 2007 6:12 am
While the airport name may be "Vostochny", many people only know it as ULY (Ulyanosvsk, the city).
And of course you forgot Bangda, China: 5500m / 18044ft.
Edit: The Space Shuttle doesn't need the long runways at EDW. At KTTS (Titusville, Florida NASA Shuttle Landing Facility), where the Shuttle normally lands, there's a 15000ft / 4572m runway.
And no, the huge runway at Area 51 isn't paved. As it has already been stated, most of it is on the salt lake. I've read that part was de-activated, simply because it isn't needed.
2nd edit: spelling !
[Edited 2007-02-13 22:25:59]
[Edited 2007-02-13 22:27:09]
Exceptions confirm the rule.
LTU932
Wed Feb 14, 2007 6:20 am
Quoting GoldenParrot (Reply 24):
OK, I see. I think I have an idea now of what you meant.
ti717
Wed Feb 14, 2007 6:22 am
Quoting LTU932 (Reply 20):
In the US, It a process to to allow dual simultaneous operations on runways that are closer then required separation. By separating the runway threshold (ends) it reducers the require separation between the runway center lines. I believe ICAO also has a similar standard. It is a way to increase the operational capacity of the runways.
TI717
Sir, don't you think we should turn on the runway lights?" "No, that's just what there expecting us to do!"
kaitak744
Wed Feb 14, 2007 6:31 am
Quoting A342 (Reply 25):
Google Earth. See for your self. 24,000ft of it is paved, making it the longest paved runway ever.
http://maps.google.com/?ie=UTF8&z=14...6026&spn=0.050007,0.11467&t=k&om=1
Gr8Circle
Wed Feb 14, 2007 7:37 am
To enable 2 EK 380's to take off simultaneoulsy.....one starting halfway down the r/way Big grin
Pu752
Wed Feb 14, 2007 9:28 am
they might not need it, but a longer runway is always safer.
richm
Wed Feb 14, 2007 9:32 am
A little off topic, but not off topic enough to start a new thread imo;
How much runway will the A380 typically need to take-off when at/or near MTOW?
N160LH
Wed Feb 14, 2007 9:43 am
Quoting Kaitak744 (Reply 28):
A little off subject... but is that one of the mystery 737's on 30/12 at Area 51..? As I recall those 737 leave from LAS daily and do not have "N" numbers... or something like that... Curiosity killed the cat on this one sorry...
-160
"I do alright up in the air, its down on the ground that I tend to mess up..."
bimmerkid19
Wed Feb 14, 2007 11:19 am
You mean.. active . as in a landing spot of Green Men ?  Wink
Last flights: LH 3738 MUC - ZRH , LH 3749 ZRH - MUC . Upcoming: EK 50 MUC - DXB 3-aug. and EK 322 DXB - ICN 7- Aug.
v1valarob
Wed Feb 14, 2007 12:28 pm
Quoting N160LH (Reply 32):
-160
They have N #'s. You can find lots of pictures of them right here on A.net. If you look them up on the FAA website it says they are owned by the United States Air Force.
-Rob
flydreamliner
Wed Feb 14, 2007 4:28 pm
Dubai can be quite rediculous... they are more or less at sea level, even at 50C, what needs 18,000 feet?
Nothing I can think of.
An in the event they ever did make a longer runway than the USAF has at Edwards AFB or Area 51, it probably stay longer for a very long time.
If anyone will get into a pissing contest with Dubai, it is the US military. How much money has been spent on the biggest, fastest, most powerful whatever? Last year they successfully tested a mach 8 plus rocket sled.
Go figure.
"Let the world change you, and you can change the world"
unitedMSY
Wed Feb 14, 2007 5:11 pm
This new runway will service United's new "Exosphere Express" flights which will carry passengers in a rather cramped but cozy 15 seat jet that will fly up to 350,000 feet and fly roughly 10,000 mph before re-entering the Earth's atmosphere and landing at Dubai after a 1 hour flight from Chicago  Smile j/w what is the purpose of this runway anyways?
Buyantukhaa
Wed Feb 14, 2007 8:11 pm
Literally it means that they have the same compass orientation, but are not side-by-side. Think Berlin Schönefeld, BUD, LED and also runways 18R-36L vs 18C-36C at AMS. So it's not the same as "side-by-side" such as MUC, LHR, ATH, FRA etc.
I scratch my head, therefore I am.
FrancoBlanco
Wed Feb 14, 2007 8:14 pm
Quoting FlyDreamliner (Reply 35):
Please read the entire thread before posting:
Quoting Ti717 (Reply 27):
No need to bash Dubai and EK here.
Jebel Ali will not be opened until 201?, until then it makes sense to increase the capacity of the existing airport. And as already mentioned above, Jebel Ali will be opened as a cargo facility initially.
Sebastian
'Pointless!' - NY Times
OHLHD
Wed Feb 14, 2007 8:34 pm
Because some locals need to go around the Middle East to tell everybody that they got the longest runway  Big grin
jonty
Wed Feb 14, 2007 8:55 pm
What are the 4 runways in the salt (03L&R 09L&R) used for then? or what were they used for? - they are touching each other so how could they ever be used properly?
It must have been mental to land or take off in whatever they built to use that massive runway!
how long has it been that state?
anax
Wed Feb 14, 2007 9:00 pm
Quoting FrancoBlanco (Reply 38):
speaking of jebel ali , are there any pictures in the database showing the current situation? any related site?
anax
god is a spotter!!!
Dash 80
Wed Feb 14, 2007 10:55 pm
I thought Zhukovsky in Russia had the world's current longest PAVED runway at a little over 18,000 ft.
...where the rubber hits the runway...
warreng24
Wed Feb 14, 2007 11:48 pm
Quoting V1valarob (Reply 34):
FYI, they're call sign "Janet" IIRC.
A342
Wed Feb 14, 2007 11:54 pm
Quoting Dash 80 (Reply 42):
Actually, it's 17726 ft / 5403 m.
Fly-K
Thu Feb 15, 2007 12:12 am
Quoting Anax (Reply 41):
Last time I drove by the construction site (about a month ago), they have started with levelling the ground.
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been...
Dash 80
Thu Feb 15, 2007 12:27 am
Quoting A342 (Reply 44):
Pretty close. Still, it's got to be the current longest paved runway.
greggerm
Thu Feb 15, 2007 1:07 am
(Coming from a layperson - don't crucify me if I'm wrong)
The salt lake runways would most likely be used in the event of test emergencies, depending on the wind directions.
Edwards doesn't have anywhere near enough traffic to make simultaneous runway use an issue, so they are strictly additional choices for a test pilot in the event of problems.
The conjoined runways could also be used DURING tests, to allow pilot A to land on the left side, and the chase plane to land on the right. I don't have the proper google earth to see, but I'd imagine both of those runways are VERY wide indeed.
They built out the concrete runway to long lengths to support the test flight and rollouts needed for airplane projects. I'm sure the Space Shuttle also had something to do with it too, as the long rollout length would be useful to save brakes, in the event of a landing diverted from Florida.
-Greg
[Edited 2007-02-14 17:09:33]
highflier92660
Thu Feb 15, 2007 1:30 am
Regarding Area 51's prodigiously long runway: We have to get those UFO balanced field lengths down! Perhaps some Kruegers, leading edge slats and triple-slotted Fowler flaps like in the old Boeing 727. Heck lets go with the anti-gravity.
rsg85
Thu Feb 15, 2007 1:47 am
Royal Flying Doctor service in Australia uses the stuart hwy as a landing strip, one section of it is fully marked like a normal runway. The stuart highway stretches from Darwin in Australias North to Adelaide in the South, over 3200km, so 3200000m, or 10496000 feet
